My A/C evaporator is freezing up, and wont cool the house below 85 degree
    Scholar:
  • 70 Answers
Check your filter and make sure you have one in place and it is clean. This is either a low inside airflow problem or system is low on freon. If you have strong air flow from vents and filter is been kept clean then low freon is most likely. Run system in on position with cooling off to make sure ice is melted. When water stops draining. then restart system . If it starts frosting up at outside unit shortly after start up it most likely is air flow. If you don't have at least 15 degree drop from registers in a few minutes and indoor humidity is not too high inside and airflow decreases and air gets colder just before it freezes up then it is low freon.
Posted on Jun 29, 2009
Your system could be low on freeon, that is always the first option.
This second option can be rare. If you live in a condo/ 2 over 2/ or 1 over 1 home these systems have a fire damper at each vent and one above the indoor unit. These dampers can shut by accident. If the fire damper above the unit indoor shuts this will cause your lineset to freeze and shut your air flow down to almost nota..........
  • 1,056 Answers
Is the vent fan working? There may be a substantial leak somewhere up in the attic. This could cause the ac system to keep on working until it freezes. How does the air coming out of the vent feel like? Is it blowing hard? If not then there is a leak or even a blockage somewhere. One way eveaporators freeze is because there is not enough air circulatting through it.
D50BP keeps freezing up with frost
That model number refers to a dehumifier made by Freidrich. this is the refridgerator section. For a dehumidifier to work right the temp in the room needs to be 65 degrees or better. The machine is designed for use in temps over 65. A freezer or Fridge will do the same thing if used in a cold area. It works by cooling the coils to close to freezing in normal temps, but when it is colder than 60, the evaporator may cool below freezing temp of water and the condensate will then freeze on the coils.
Dec 31, 2017 | Frost Refrigerators
How much r410 gas pressure in 1.5 ton inverter ac
Usually on any 410a freon system you can use a pt chart, and for any other freons also. At 120psig yours indoor coil temp is around 40°f. You want this temp/pressure above freezing. Your pressures are going to depend on indoor/outdoor temps. Hope this helps!
Mar 23, 2017 | Inverter Heating & Cooling
Samsung model#rs2577bb freezerworking good refridgerator not maintaining temperature
Not really a permanent solution for Samsung refrigerators with a evaporator inside the fresh food section. You will need to remove the shroud housing the evaporator and clean out the drain opening along with removal of any ice buildup. User Manual HERE
Here is a link to a troubleshooting page that covers your model=> HERE You need to clean and make sure the sensors at base of evaporator are clean and function properly. Also insure condensate drain below evaporator remain clear of blockages ice/gunk. Parts breakdown can be found HERE. I am here should you need me, Thanks John Tripp Appliance 911
Contact Me Here
Mar 12, 2014 | Samsung RS2534 Side by Side Refrigerator
Heat won't shut off
Take the wire off of the W terminal on the thermostat and see if heat shuts off .If yes maybe bad thermostat, also check to see if W and R is jumped because it should not.
Feb 16, 2018 | Honeywell Programmable Thermostat Heater
Air not cold enough to cool house
Make sure the outside fan is running. Also check the high side pressure, I assume the 70# is the low side pressure, so you can tell what the compressor is doing. If the fan and compressor are both working, make sure there is good airflow through outdoor coil and check that it is clean. Let me know what you find.
May 17, 2010 | Goodman CLJ24AR32 Air Conditioner
My brand new HVAC unit is not able to maintain the heat in the house. The unit itself seems to be running fine but there was an accumulation of snow and ice on the fan unit. When I knocked all the snow and...
i hope the air condition is feet to your home ,if u have ceiling tall
the heat will stay high point ,and the air condtion will be on most of the time. if not
and the mode is heat
firrst:
clean the filter in evaporator (out side the house).
check and see if the engine of the evporator work and runing.
without wibrtion.
but the main reason is most unit hvac are not inverter,
so that mean if the tempratore out side is beneed to 5 degree Celsius (most of the time night) the unit will be frozen.
60 degrees f = 14 degrees c
you can defrost the buy chnge to mode cool.
other cohice ic to check the dieicer if u have it.
Feb 05, 2010 | Goodman Heating & Cooling
Does not hold temperature, warms up.
if you hauled on its side then it is very possible you have oil in evaporator. replace all sealed system parts. compressor, drier and evaporator.
Jun 21, 2009 | Roper Refrigerators
The AC will not cool below 71 degrees. Can it be adjusted to cool down to 65. It appears that it was set at the factory to not cool below 71. I do not care for that at all.
you have a air conditioner not a refrigerator. The reason that its locked to not go below is because any lower then that and the evaporator will freeze up and then liquid refrigerant will go to the compressor.
Mar 28, 2009 | Amcor A12000E Nanomax Portable Air...
Heating & Cooling Logo
180 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
