Question about Garden
Washer won't start tried everything , I could think of changed spark plug tried new gas , Two things that bother me are . if i take out the spark plug and put my thumb over the spark plug hole theres no pressure and the wire that comes from the coil to shut off the pw it has continunity from the coil to the pin that sticks up to shut off the pw but it also has continuity from the coil to all parts of motor.
  • 18 Answers
SOURCE: Karcher 2400R
You have a poor signal to the spark plug usually caused by a rusty fly wheel found underneath the pullcord casing. clean it with releasing ajent such as wd 40. common when not in use for a while.
Posted on Sep 19, 2008
  • 2692 Answers
SOURCE: Unable to start gas engine on a NorthStar pressure washer
Disassemble and clean the carb. If it ran briefly with the starer fluid then gasoline is not coming through the carb.
Posted on Dec 30, 2008
  • 4 Answers
SOURCE: Can't start the Honda GX160 5.5 HP Electric motor
Is there an oil sensor unit if it is going bad it tells the engine the oil low and engine wont start. I had same problem with my pressure washer, i just unplugged the sensor unit and it started fine ever since
Posted on Apr 27, 2009
  • 3 Answers
SOURCE: Karcher pressure washer with Honda GC160 engine only runs on chok
You need to remove the carb bowl, then with a small flat screwdriver remove the jet. ( on the side, at the bottom of stem.) take a small wire or toothpick and clean the gunk out of the jet, reassemble and open fuel valve, start, and pat yourself on your back.
Posted on Aug 04, 2009
  • 18 Answers
SOURCE: 11 hp honda pressure washer
if you replaced the coil,check the wire and boot,check with meter for continuity.could be loose connection to spark plug
Posted on Sep 20, 2010
Craftsman 2400psi 6.0hp briggs & stratton pressure washer won't start
try and start it with starting fluid if so rebuild the carb
Aug 07, 2012 | Garden
Coleman powermate clean machine 1500 won't turn over any ideas
A new spark plug should solve the problem. Had the same thing for the last 2 days would not start no matter what including starting fluid. Cross referance the plug with a Autolite Extreme Start plug $4.00 at Advanced Auto Parts and did not change the gap. 2nd pull it started and ran great!!
Jun 12, 2012 | Garden
Got spark and gas can't get it running what is the conpression supposed to be
i have a honda power washer EXHA2424, I replace new spark plug, new gas., cleans the cabureetor, and it still won't start please advice me what to do
May 21, 2011 | Devilbliss DeVILBISS Devap DVH2600...
I have DeWalt3750 psi pressure washer, its been long time since I used it, now that I wanted to use it, I can not start it. I already changed the oil and filled it up with new oil but still can not start,...
Here is the long answer with everything we learned while using a power washer twice a day for years::
This assumes you did not turn power washer over or on its side to drain oil, or dirty oil will flow into carburetor requiring complete carburetor cleaning.
It sounds like could be one of the problems listed below or a combination of those things.
1) The exhaust is partially blocked. Check the screen covering exhaust port for carbon and dirt build-up. High-speed exhaust air must pass freely. We finally broke the exhaust screen out with a screwdriver to get our machine going one day.
2) Gas is not flowing freely to carburetor > under gas tank, find the rubber hose connected to carburetor. Pull off rubber hose and make sure gas flows freely. You can use this hose to drain gas tank of old gas ... and then put in fresh gas.
3) Carburetor is partially gummed up and engine cuts off when gas flow slows down. Buy some gum out, and then don't store power washer with gasoline in the tank. Or put additive in gas when storing machine.
4) The choke is letting in too much gas or not enough gas. Try different adjustments. The choke-lever on our power washer got so bad that we could not set throttle at full open or the machine would die. We still use the machine at 2/3 throttle, and then start it each time using WD-40 as described below.
5) Dirty air filter that won't let engine breath enough air to keep up with combustion. Take off air filter and see if problem persists.
6) The spark coil is going bad?? Change spark plug to see if problem persists. Is spark plug wire pushed all the way onto the spark plug?
Now the nitty gritty: we're gonna start that thing right now
7) Take off air filter. Spray WD-40 directly into carburetor. Yes, we use WD-40 every time to start my power washer, and we use the washer twice a week.
Spray in the WD-40, Pull the engine cord. The engine will fire on WD-40. Guaranteed.
Once it starts, keep spraying WD-40 directly into carburetor to keep engine going.
If engine will not fire and keep going on WD-40, then your spark is suspect.
If your engine fires and runs on WD-40 but dies without it, then your gas supply or carburetor are suspect
8) Carburetor problem >>> try Gum out >>> and then take machine to small engine repair shop
9) Spark ... take out spark plug. Put spark wire back on. Hold spark plug by spark wire. Touch metal threads of spark plug to metal opening where plug came out. Metal to metal. Pull back start cord and look for spark between the metal.
If you have no spark, then spark coil is bad >>> take machine to small engine repair shop
Add a comment if you need more help
Nov 28, 2010 | Dewalt 3800 PSI Pressure Washer
I have a pressure washer at work that has good spark and starts when I put gas in the carburetor.But it wont stay running. I have the gas turned on but it doesn't seem to be getting to the carb. It's...
Here is the long answer with everything we learned while using a power washer twice a day for years:: It covers the things you already tested, but doesn't hurt to repeat. Your problem is actually #8 on list below.
4) The choke is letting in too much gas or not enough gas. Try different adjustments. The choke-lever on our power washer got so bad that we could not set throttle at full open or machine would die. We still use machine at 2/3 throttle, and then start each time using WD-40 as described below.
If engine will not fire on WD-40, then your spark is suspect.
Nov 22, 2010 | Honda Pressure Washer PSI 3000
Motor has been sitting for a while changed out old gas put new in drained carb bowl put new spark plug wont stay running
Here is the long answer with everything we learned while using a power washer twice a week for years::
Nov 21, 2010 | Garden
It starts but it shuts off immedially.
Nov 01, 2010 | Karcher 2500 PSI Pressure Washer
Can not start the engine
Nov 01, 2010 | Karcher G3025OH Pressure Washer
I have a Craftsman 2700 psi pressure washer with a Briggs and Stratton 850 engine (80 year anniversary special addition) . It is about 2 years old and used very little and will not start. I filled it with...
Let us know how it comes out!!
Oct 21, 2010 | Briggs Stratton 020273 Elite Series...
Honda Pressure Washer HP 5 not starting
You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
Jul 18, 2009 | Honda 8 HP Engine
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
