Question about Panasonic PV-9450 VHS VCR
Records picture noise - Panasonic PV-9450 VHS VCR
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 40 Answers
Try upgrading your cables that are the sources input on the unit. I have found this to be the problem on numerous accasions. What type of cables are currently being used?
Posted on Jun 29, 2009
Sound noise feedback during recording
Noise can be a big problem when trying to record into a computer. Reducing and canceling out noise using several simple techniques will help increase recording quality and increase your satisfaction with recordings. Solutions range from complete room overhauls to simple changes in the placement of the microphone and other objects in the recording.
Use a stabilized microphone to reduce vibrations. Many hand-held or headset microphones will pick up on vibrations and movements from the user. These vibrations can carry over into the recording and reduce the quality of the recording. Using a microphone stand or stationary microphone will reduce noise while recording. Mic stands will help increase recording quality and off a possible solution that requires very little financial investment. Set up a designated sound room that is set away from the rest of your home. The farther the recording area is from windows and doorways, the better. Windows allow very small amounts of noise to filter in from the outdoors and create white noise in the recording. Hang blankets on the walls around the recording station and use many rough objects in the recording room. Sound travels in waves that bounce back and forth between smooth objects. Blankets and other rough objects will help reduce sound vibrations. These additions to the recording room will reduce ambient sounds from both the room and outside the building by blocking sound waves from bouncing back and forth in the room. If you can make a considerable investment in the room, there are several acoustic products on the market than help nearly eliminate echoes and outside noises. Install software that filters out unwanted sounds and echoes. Many computer applications exist that use programs to increase the quality of recordings and reduce the ambient noise levels in a recording room. Software is used to reduce echoes and feedback in a recording studio. Several free applications can be used to achieve the desired effects when recording. A program called Audacity is one of the most effective software packages that can help reduce noise in recordings. http://audacity.sourceforge.net/ Software can also be used to reduce electronic humming and other white noise that can be picked up during a recoding session. Buy a high-quality microphone with noise and echo cancellation. One of the best investments that a recording specialist can make is a high-quality mic. The microphone itself can reduce many unwanted noises and echoes in the recording room by filtering the actual sounds that are recorded.
b>
Jan 15, 2013 | Computers & Internet
When I try to record a show. There is no picture on the disc when I'm done. Its just a white noise screen. I finalize the disc too. there is no prompt to tell me to format the disc.
If the disc playes back then the problem is not with the DVD unit. In order to record white noise, the channel selected for record is probably not tuned in. Try recording the same channel on to video tape and see what results you get.
Mar 09, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Direct TV DVR sound/no picture or pict. no sound
My Direct TV has no sound or picture but does show channel info at the top. Any help is appreciated.
Dec 13, 2008 | Directv (R10) DTV Receiver / 70-Hours...
Making noise
I would take that into a repair and have someone look at it. It could be serious.
Jun 15, 2008 | Canon ZR300 Mini DV Digital Camcorder
Video Recording causing Picture interference
When you are recording, do you hear the vhs tape(motor) moving? Is the tv\vcr combo connected to the same power(electrical) plug with ANYTHING else ? On the SAME wall outlet with anything that generates noise?. Do you have ANYTHING ( electric clock ) WITH a motor connected to the same line\wall\outlet\power adapter?
2nd) Any loose ground [wires that go to any menal part inside TV\VCR will cause problems. Be very carful inside electronics parts and when they are alive [pluged in & turned on], Some times loose VHS rubber bands cause problems by slipping and jerking the tape recording.
Apr 29, 2008 | Televison & Video
Not recording
What camera are we talking about here? Have you tried resetting the camera?
J. DeRuvo
Digital Camcorder HQ
Dec 04, 2007 | Video Cameras
Noise while playing VHS
It sounds like the tape is cocked slightly. some VHS tapes did make noise. I'd take it to the store and show them the noise.
Nov 04, 2007 | Philips DVDR3320 DVD Recorder/VCR
How Do I Make An MPEG Recording?
You can record video with audio onto the Memory Card. Follow the instructions below. Recording moving pictures onto a MEMORY CARD 1. Insert a Memory Card into the slot on the camcorder. 2. Set the mode switch to MEMORY CARD position. 3. Set the power switch to CAMERA mode. 4. Press the START/STOP button, the images are recorded on the MEMORY CARD in MPEG4. * You can record 10 ~ 20 seconds continuously. * You can record a still image on the Memory Card by pressing the Photo button instead of the START/STOP button. 5. Press the START/STOP button to stop the recording. Notes: * Moving images that you recorded are saved in *.asf file format on the Memory Card. * The moving picture images on a Memory Card are smaller size and lower definition than those on a Tape. * The sound is recorded in mono. * The following functions cannot be operated in M.REC Mode. - DIS (Digital Image Stabilizer), Digital Zoom, Fade, Program AE, Digital Special Effect, Slow Shutter. * Don't insert or eject a tape during Memory card recording as it may record noise. * Don't eject the Memory Card during recording as it may break the data on the Memory Card or the Memory Card itself.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Unclear picture
For Models: CC6254, CC6364, CC6374, CC6384, CC6394. When using Quick Review to check the end of your last recording, some distortion at the beginning of the playback is normal. When using the Retake mode to record a scene, the video may darken or become monochromic. Noise bars may also appear. This is normal.
Sep 06, 2005 | RCA CC-432 Camcorder
Panasonic PV-9450 VHS VCR Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
