Question about Cub Cadet Street Sign- tractor lawn riding mower parts
I own a cub cadet LT1042. I started mowing tonight as usual when the PTO just quit. What is my likely problem and how do I fix it?
Replace your drive belt
Posted on Jun 30, 2009
I have a LT1042, cub cadet. PTO clutch burnt up. I replaced it and the solenoid, fuse, and relay. Thinking that when PTO clutch burnt out that something else like a wire or sensor went out also.
Check all the safety switches u have a bad one look under the seat first that one is a common problem so I take it your PTO won't engage I bet your old PTO is still good the safety junk they put on these mowers fails a lot causing problems running your mower also look under the back side by the tire there is another safety switch that gets corroded that's switch is the one that will not let you mow in reverse if you want to bypass it u can just put the wires together then beware your mower will work in reverse also I hope this helps you have a great day Regards Chris
Aug 03, 2016 | Cub Cadet Garden
Rider will not turn over more than once no matter how many times I try.
I sounds like there's significant resistance to the engine turning over. I experienced this when the electric PTO/clutch seized - and the mower was trying to turn over the engine AND the mower blades because the PTO wasn't disengaging. Try taking the mower belt off the PTO and see how the engine turns over. If it's still slow, the problem is in the engine. If it spins normally, replace the PTO clutch. BTW - when my clutch seized, it also burned out the PTO switch. The switch is pretty inexpensive, so if you're replacing the PTO/clutch (I found one online for about $175.00 - MUCH more expensive at the dealership) - you should probably replace the switch as well.
Jun 28, 2014 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Cub Cadet LT1042 PTO keeps shutting off after mowing several feet, will turn right back on but keeps shutting off
I have a Cub Cadet 1605 and it does the same exact thing. Try the PTO switch on the dash. I replaced mine and it works fine. Hope this helps.
Oct 12, 2013 | Cub Cadet Street Sign- tractor lawn riding...
I have no power to the pto on my LT1042 mower I found broken wires and fixed the but still no power. Where are the fuses that would blow? I only found one fuse and its ok
Did you check for power at the pto switch? Start with checking that, then check the wire from the PTO switch to see if it has power all the way to the PTO clutch. If there is power to the clutch, and the belt is good and routed properly it's probably the PTO clutch.
Aug 11, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Hi...I have a 2005 Cub Cadet 2042. With the switch in ''normal'' and the PTO engaged, when going forward cutting the grass the PTO will disengage for no apparent reason. You have to push the PTO knob in...
In the cub cadet, the PTO power is maintained via a latching circuit that includes a reverse switch and a reverse relay. Locate the reverse switch that senses whether the tractor is in reverse -- either it's come loose, become misadjusted, or it's failed, or the wiring and connections are loose. You could bypass the switch to confirm this as the problem.
Jul 10, 2010 | Cub Cadet Garden
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
2008 Cub Cadet LT1042 Won't Start
If there is a fuel cup on the bottom of the carb take it off and clean it out real good. Take the fuel jet out and clean out the little hole by blowing it with air compressor or a real fine wire.The fuel jet is most likely the problem.
Jun 21, 2017 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet LT1042 PTO won't disengage
If its an electric PTO then the switch on the dash is bad, Its a lever type ungagement then the little break shoes that rub on the blade spindles are either worn out or mis adjusted.If it started when you changed the blade drive belt its possibly the wrong belt??
Oct 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
1,134 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
