Question about Maytag Neptune MAH5500B Front Load Washer
Display shows LR. machine stops in midcycle - Maytag Neptune MAH5500B Front Load Washer
  • 15,935 Answers
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Maytag upgraded the motor and motor control board because this problem was so prevalent. Big rash of these a few years back... and insludes replacement instructions with the kit.
The LR code means "locked rotor" - the control is not seeing the motor turning.
The image below contains the wiring diagram for this washer as you requested but there are some other things to consider.
Usually when the LR code is displayed the motor has stopped turning for some reason.
By definition the LR code means the control has tried to turn the motor but was unable to.
The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing.
The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down.
You don't mention in your question if the LR code occurs every load or once a week.
Try running a rinse and spin cycle empty and see if the washer completes the cycle.
The 2nd image contains the information on how to enter and run a diagnostic cycle which may help pin the source of the problem down.
This test completes all functions of the washer is a short time. It will fill, tumble, drain and spin all is a few minutes.
At the end of a successful test cycle a PA should display which means "Passed" and is what you want to see.
Image 1: http://media.fotki.com/1_p,sqwrrqkkqkstsftxgtqsskgwtqkq,vi/kkwrfdskkxkgbffwfww/1/1303472/5961857/image53872img-or.gif
Image 2:http://media.fotki.com/1_p,sqwtrsgdwsqtqsqxgtqsskgwtqkq,vi/kkwrfdskkxkktggsfsw/1/1303472/5961857/image53908img-or.gif
From another source...
"Installing replacement motor, motor control harness, and motor control circut board.
Pretty easy install. On a scale of 1 to 10 I'd call it a 3.5.
If you can use a screwdriver, a wrench, and have played with legos before, you can probably do this job.
It took me about 3 hours to do, but this was with inferior tools, and two smoke breaks included.
Minimum tool requirements: Adjustable-head cresent wrench (8 or smaller handle), phillips head screwdriver, utility knife.
Recommended tool equirements: Small ratchet with socket set, ratcheting screwdriver with phillips head and small socket attachments, brew.
The instructions are pretty clear.
Once you pull the front panel off, there are two braces at 45 degree angles on the lower corners of the washer.
The instructions don't ask you to, but I would remove the brace on the left to make life easier.
This gives your arm more room to work and makes it easier to pull the motor out the front.
They ask you to remove the wiring harness from the motor first and then pull the harness out with the control board.
My wrench was too big to get to the bolt to remove the harness from the motor.
All I did was cut the harness - since they supply a new one - then pull out the control board, then pull out the motor.
As far as getting the pulley off, slip it on and off at the large wheel, this is much easier than taking it off at the small motor drive shaft.
The only other thing of note is to make sure you look at the diagram for the conectors a few times before you snap it together.
There are a few ways you could hook it up wrong so pay attention. There should be no loose ends when you finish.
Also, I couldn't get the flange back on on the rear acess panel when closing it up, but it doesnt seem to serve muc purpose besides asthetics, so I tossed it.
The $200 for the parts and shipping was well worth it. I saved about $150-250 to do it myself...."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%&YTHF
Posted on Oct 01, 2010
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: washer stops midcycle with a LR showing on the digital screen
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question $%^
Tub filled with water, Lr code
To pump out the excess tub water while failing to complete spin cycle;
Enter Service Mode by simultaneously pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on. Stop with off button or hit the Presoak key.
This process is documented in the Service Manual. I would go to page 16 of the SM lower right hand part of page, Board Output Test and turn on the drain pump in service mode to pump out the tub.
If I could ask you to do a little troubleshooting;
It sounds like the wash/agitate cycle completes and you enter into the spin cycle of the selected wash cycle is that correct. When the wash cycle fails does the Cycle Status LED indicate that the washer is in the Spin cycle?
With a empty wash basket no wash load in the basket and you start a Spin Only cycle will the Spin Only cycle complete?
If the washer will start the cycle do you hear and loud Spin Only cycle noise such as metal against metal grinding noise?
With the washer off and no clothes in the wash basket can you open the lid then Spin the wash basket as fast as you can in the CCW direction the only direction. The wash basket should spin CCW several rotations and coast down to a smooth stop dose it?
I’m checking for Outer Tub increased bearing resistance…..Rich
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Jun 28, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Lr message
THIS WEBSITE IS VERY USEFUL FOR YOUR MACHINE
http://www.applianceaid.com/neptune8.html
HERE IS THE OUTLINE FOR THE CODE LR
Lr Locked Monitor Rotor Based in signal information from motor control board, the machine control board senses the motor is not turning when requested to run 1.Run motor control board diagnostic test. 2.Check motor control board for damaged components.
3.Check wire connections in harness leading from machine control board to motor control board.
4.Replace responsible component.
May 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer stops in midcycle and F displays, what could be the problem
washers stops in midcycle and F displays whats could be the problem
Mar 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer stops and the display shows Lr.
This is your control board that is going out on this washer. It is simple to repair and you can save a lot of money by making the repair on your own.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and let us know the brand and model number, and we will get the correct part out to you asap.
You can contact us from 7 AM until 9 PM CST Monday through Saturday.
We want to get you washing your laundry again soon.
Happy Holidays to you! Thanks, Ella
Nov 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer stops midcycle with a LR showing on the digital screen
May 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Lr code on display
it is a problem with the motor .this is confirmed.
Issue
Washer stops in mid-cycle and/or flashes a code.
Warranty Standard product manufacturing warranty applies.
Action The motor drive system experienced a momentary loss of neutral feed from the power cord to the
Motor Control Board. The neutral line for the Motor Control Board passes across the water valve
solenoids. Neutral to the motor drive system can be momentarily lost If there is poor crimping of any
of the wire terminals in this circuit. This situation could result in a misdiagnosis and unnecessary
replacement of the Motor or Motor Controller Board.
Current Neptune front load washers will indicate a false locked rotor signal to the Machine Control
Board. Washers with a LED display will flash code “LR” in the display. LCD washers will display
“Locked Rotor.” The earlier built front loaders will not display a code, but simply shut down in midcycle
or will not start.
Pull each terminal of the white wire harness connected to each water valve solenoid and verify the
wire is properly stripped and crimped to the metal terminal connector of the wire harness. Make sure
the wires fit snug on the terminals of the water valve solenoids.
A product improvement has been made to the following models. The neutral wire is routed across
the pump only, and now by passes the water valve solenoids.
MAH55FLBWQ/W ..................... Series 12
MAH5500AWQ/W ..................... Series A7
MAH6500AWQ/W ..................... Series 33
MAH7500AWQ/W ..................... Series A6
May 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune front load has Lr on Time display
Im having the same problem what is the lr code and how do you get rid of it?
Nov 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Oe comes up on the display
The drain filter is located on the bottom left corner behind the little door.  Remove the door and the filter is located there.
Jun 27, 2008 | LG WD-1280FHD Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
41 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
