Question about Jandy Levolor Water Leveling System - Fill with High Level Switch, Controll
Electronic sensor valve with four prong handle
I am the maintenance person at the YMCA in Suffolk VA. We have a water spray park with a3000 gal. under ground tank with the levolor K1100 filling system. I do not have the operator's manual. So, I am not sure the sensor is operating correctly. How can I be sure.? There is also a small swivel stop **** on the side of the sensor. What position should it be in UP or down?
    Problem Solver:
  • 11 Answers
If the system is operating correctly you should see a yellow sensor light when the water is low and a green filling light when the water is filling. If the filling light is red or flashing the system has timed out. Turn it off, then on again to reset the time limit.
Posted on Aug 11, 2009
Idles too low and dies
How long since a tune-up? Has your Sierra been parked for awhile? Dirty gas, add Lucas Oil Injector cleaner to gas tank...water in tank, add Liquid Heat...dirty air filter, replace and clean out throttle body...Idle Air Control valve...spray, wipe out with rag...also spray the MAF sensor with special spray ONLY...injector spray erodes the sensor finish...:(
Sep 19, 2015 | 2004 GMC Sierra 1500 Crew Cab
Air leak coming form the pressure switch
Air leaking from the pressure switch indicates that the in-tank check valve is leaking. Follow the air discharge hose from the compressor to the tank. The brass valve at the tank is the check valve. With air in the tank remove the inlet hose from the checkvalve and spray soapy water on valve to check for leaks. If leaking, remove the valve and check for debris under seat or replace. If the check valve is not leaking then pressue switch is leaking from within switch(spray soapy water below switch) . Good luck
Sep 23, 2011 | Dewalt 2 Hp 4 GAL Air Compressor
I have a 50 gallon power vent lp water heater. the water was under water this weekend. when i try to ignite the heater i can not see the spark at t he burner. When I remove the blue ignition wire from the...
Your power vent water heater with electronic gas control went under water.
http://waterheatertimer.org/Flooded-water-heater.html
I suspect the gas control valve is bad, and possibly the ECO and FVIR sensors shorted.
Repairs might require replacing gas control, eco, fvir, igniter, and then clean burner and combustion parts.
Open following link to identify typical gas valves: and possibly read service manual for troubleshooting that model.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
Might be easier to replace water heater
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 30, 2011 | Rheem 50 GAL FVR Propane Gas Water Heater...
I have an Atwood electronic ignition 6 gal. water heater. When I flip the switch to light, I can hear the ignitor sparking but there is no ignition. How can I isolate the problem?
Use a multimeter or test light for 12volt DC, and check at gas valve for 12 volts when it is trying to ignite (you here/see it sparking ). If no 12 volts to there, it will not ignite because no gas is flowing through valve. Try removing the connectors on the circuit board/module ( with switch in off position ) and cleaning the board contacts with a pencil eraser, and spray WD-40, or preferably an electrical spray/contact spray on connector contacts and retry. Board, or module may be located outside , or inside on top of tank, depending on what year and set-up. If that doesn't work, there is a small cut-out enclosed in plastic sleeve right near pressure relief valve area, that looks like a resistor that may be faulty. Remove it from the circuit and try it then. Simply pull the wire off at thermostat, pull that out of the sleeve by disconnecting it from the female spade connector, then put female spade where it used to be on thermostat terminal. If it works, buy a new thermal cut-off. If all that is done and tried, and still doesn't light, replace module.
Aug 09, 2011 | RTO Atwood Water Heater - 6 Gal LP
Vacuum valve leaking water
Question is unclear.
What is a vacuum valve?
You posted under electric water heater.
Water heaters are associated with TP or 'safety overflow' valve, water shut-off valve, tank drain valve, pressure-regulating valve, mixing valve and possibly a few other plumbing valves.
Vacuum valve implies that a compressor is creating pressure on one line while creating vacuum on another line. I don't know of a water heater that uses air compressor.
Open following link to help troubleshoot leaking water heater:
http://waterheatertimer.org/Leaking-water-heater.html
Jul 23, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have an Atwood 6 gallon water heater with electronic ignition that works well, but after running a while my vapor sensor in the RV goes off. By process of elimination we have determined it is the water...
Obviously something ( propane or carbon monoxide ) is leaking inside the unit either while water heater is running or after. I hope I don't need to warn you how dangerous this can be, and that you should have it checked by a qualified technician A.S.A.P. , and propane should be shut off until such.
With that said, 3 things come to mind that should be inspected or considered. Look at where propane line comes through housing of water heater and attaches to gas valve. There should be a rubber grommet in the hole and it should be air tight so as not to allow any fumes or gas to enter back inside trailer. If it's not air tight, use a silicone type sealant and seal it good at that location. Another thing I would look for is any window or opening above water heater that may be allowing fumes or gas to enter inside trailer. Next, I would take a spray bottle, fill it with water and squirt some liquid dish soap in and mix it to test for leaks around all fittings at water heater, and especially spray orifice where gas comes out of valve and enters burner tube, when heater is off, to see if any bubbles form at end of that orifice, which would indicate a leaking gas valve. Again, I urge you to have it checked by an experienced technician for the safety of yourself as well as your family and friends.
Jun 23, 2011 | RTO Atwood Water Heater - 6 Gal LP
My Bosch Axxis washing machine is about 6 years old...it used to work very well (motor is absolutely new and electronic water valves as well).from advice i got a few months ago from a maintenance person...
In my experience a lot of these electronically controlled appliances the electronic control do go out. They are supposed to last forever because electronic do not have moving parts. The way I look at the main reason most appliance today has electronic controls should be so that the controls will last longer. It seem to me they just do it for marketting purpose. After all if appliances lasted forever they would go out of business.
Jun 26, 2010 | Bosch Axxis WFL 2060 Front Load Washer
The pump has pressure applied, but no spry comes out.
These sprayers get rust in spray handle, they taking apart and lubing sprayer. If you leave chemicals in tank you will ruin the spray handle.
Jun 20, 2009 | H.D. Hudson 1 Gal Poly Deck Sprayer
Drain valve on air compressor won't open or close
I would use an ajustable wrenck to try and open the valve. Being at the bottom and in the water, this is a common occurrence. to replace the valve, there is a Hex nut outer fitting (part of the valve) that you have to remove right by the valve "T" handle. Put a wrench on this and remove the complete valve. It too will be very hard to remove. When you install the new valve, use some anti-seize compound to make future removal easier.
May 31, 2009 | Porter Cable Cable 135 PSI, 60 Gal. Oil -...
Will not spray the water
if this is a new model take of the handle ,If you look down were the handle plunger fits into machine you should see a valve.
press the top of the valve in ,if the machine sprays water then the fault is the handle plunger is not making full contact with the valve, ad a small pad to the end of the handle plunger ,
this should make the machine work
Nov 12, 2007 | Vacuums
Jandy Levolor Water Leveling System - Fill with High Level Switch, Controll Logo
240 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
