Doesn't leak oil until the car has been running 10-15 mins. Starts just fine, there is no pinging or other noise. The serpentine belt starts to make a squeking noise while running when the oil starts to leak.
SOURCE: oil light ....?
This is a faulty or damaged oil pump and screen as well. replacing the oil pump and screen will fix this issue. i would do this asap. your rod bearings are suffering at this time.
SOURCE: car dies when it heats up and won't crank back up until cooled
normally a speed control sensor can solve this problem, but also check the crank senson.
SOURCE: car shuts off when it gets hot
your ignition coil are going bad, they need to be replaced. once the car gets hot the circuit shut down the car when hot. once they cool your riding again until they get hot. thats your problem. Good Luck
SOURCE: car will start and run
Have an OBII scan performed (fault scan) Any good parts store - Autozone, Advance, etc can scan it for you and give you list of possible faults. Could be any # of faults and it's easier to have it scanned and fix what is wrong the first time vs throwing parts at it from suggestions
