Question about Motorola Mobility TracFone w175 PayAsYouGo Cell Phone
The service is disabled - Motorola Mobility TracFone w175 PayAsYouGo Cell Phone
Call your phone service carrier and get a code entry mode "code" from them.
Posted on Jul 25, 2009
Is veterans pension the same as being 100% disabled veteran service connected
No. Veterans a pension is based on rank and years of service.
Disability is calculated based on % of disability and would be in addition to any eligible pension. A veteran can receive disability payments and veterans health benefits without receiving a Pension (of course visa-versa).
Jun 29, 2017 | The Computers & Internet
Tip
Speed/tune up windows vista
Not all steps are mandatory !!!
1. Turn off Windows Search Indexing
Windows Vista search indexing is constantly reviewing files on your system to make their contents available for quick searching. This is handy, but can severely impact system performance.
To disable this constant indexing:
Click Start then Computer
Right Click the C: Drive
On General Tab, Uncheck Index this drive for faster searching
On the subsequent dialog box, Select Include subfolders and files
2. Turn off Remote Differential Compression
Remote Differential Compression measures the changes in files over a network to transfer them with minimal bandwidth rather than transferring an entire file that has previously been moved. By constantly checking for file changes, this service can hinder system performance.
To disable this service:
Open Control Panel
Switch to Classic View
Select Program Features
Choose Turn Windows features on and off
Scroll down and uncheck Remote Differential Compression
3 Turn off Automatic Windows Defender Operation
Windows Defender real-time protection against malware continues to run despite having Automatic operation disabled.
To disable this feature:
Open Control Panel
Select Windows Defender
Choose Tools from the top menu
Select Options
Uncheck Auto Start at the bottom of the window
5. Turn off Automatic Disk Defragmentation
Windows Vista and its always-on defragment feature isn't really that necessary and can cause system slow down. Just remember to run a defrag manually every week or so.
To disable this:
Select the Tools Tab
Uncheck Run on a schedule
6. Add a 2GB or higher USB Flash drive to take advantage of Windows Ready Boost (Additional Memory Cache)
Ready Boost is Microsoft's name for using a USB thumb/flash drive to provide some quick access memory the operating system can use as extra RAM. The Ready Boost system can significantly improve system performance.
To set this up:
Insert a USB Flash Drive (preferably 2GB or more)
Right Click the USB Drive in My Computer
Select the Ready Boost Tab
Choose Use this device
Select as much space as you can free up for RAM usage vs. Storage
7. Turn off Windows Hibernation
Windows hibernation background services can use a large amount of system resources. If you don't use the Hibernate feature on a regular basis you may want to disable it to give Vista a performance boost.
To disable Hibernation:
Select the Control Panel then Power Options
Click Change Plan Settings
Click on Change Advanced Power Settings
Expand the Sleep selection
Expand the Hibernate After selection
Crank the selector down to zero
Click Apply
8. Turn off System Restore
Analysis and restore point creation by Windows Vista can eat a fair amount of system resources. Disabling this service will obviously mean the system restore feature in Vista will not be available in the event of a system crash. Change this at your own risk.
Control Panel>System
Click System Protection on the left panel
Uncheck the main system drive
Agree to the confirmation
9. Disable User Access Control (UAC)
10. Disable excess Windows Services that Auto-Launch at Startup
Just like Windows XP, Vista ships with all kinds of services enabled that load at startup and may never be used by most users.
To see what loads at startup and disable the ones you likely won't be needing (they can always be started manually later):
Click Start then Control Panel
Select Administrative Tools
Choose System Configuration
Click the Services Tab
You can safely deselect:
Offline Files (unless you're using Offline File Sync)
Tablet PC Input Service (unless you have a tablet PC)
Terminal Services
Windows Search (If you have already disabled indexing)
Fax (unless you're using a fax modem)
11. Disable Excess Windows Features
Windows ships with other features that are listed separately in the Vista operating system from the startup services.
You can view and disable these features by:
Clicking Start then Control Panel
On the left panel, select Turn Windows Features on or off
Indexing Service
IKE and AuthIP IPsec Keying Modules (Disable) VPN service stuff
IP Helper (Disable) Until IPV6 is commonly being used----it's worthless
IPsec Policy Agent (Disable) Not many Internet Providers require this---mine doesn't.
KtmRm for Distributed Transaction Coordinator (Disable) High level networking
Remote Registry (Disable) I really don't want someone else in my Registry, remotely!
Secondary Logon (Disable) No need----I'm the only logon----ever!
Security Center (Disable) No need if you are running another Security Program
Tablet PC Optional Components
Tablet PC Input Service (Disable) I don't have a tablet PC!
Windows Error Reporting Service (Disable) I don't want to inform MS of errors.
Windows Media Center Extender Service (Disable) Unless you hook to an X-Box.
Windows DFS Replication Service
Windows Fax & Scan (unless you use a modem for faxing)
Windows Meeting Space (unless you use the Live Meeting Service)
Windows Firewall (As long as you are running another Firewall)
Windows Search (If you never search the internet without your browser)
12. Stop Security Notifications
You must do this BEFORE you disable the Security Center Service. In the Notification Area which I call systray (bottom-right where the time is), right-click on the Security Shield and choose Open Security Center. On the left choose Change the way Security Center alerts me, then choose Don't notify me and don't display the icon. The shield will disappear.
13. Disable Windows Vista Sidebar and prevent it from running at Start-up
Right-click in the Sidebar area and choose Properties. Then uncheck Start Sidebar when Windows starts. If you want it back for some reason---You can start it any time by simply typing "sidebar" in the search bar of the start menu. This one is a big memory user and WILL slow things down on a normal machine. I found it fairly useless.
14. Speedup Start Menu Search
Start Menu Orb >>>>Run>>>>type in regedit
HKEY_CURRENT_USER/Software/Microsoft/Windows/CurrentVersion/Explorer/Advanced.
Find and right click on Start_SearchFiles and select Modify. Set the Value to 0.
Don't reboot yet till you have done Step 6
15. Speedup Menu Display
HKEY_CURRENT_USER/Control Panel/Desktop
Select MenuShowDelay from the settings on the right
Set Value to 200 (I find 0 way to fast...)
Reboot
16. Do an Advanced Disk Cleanup
Start Menu Orb >>>>>Run, type: cleanmgr /sageset:50
Select the options you want, I think it is fine to choose them all. Click OK and close out the window. (there is a space between the r and the /)
Start Menu Orb >>>>>Run, type: cleanmgr /sagerun:50 (there is a space between the r and the /)
on May 03, 2010 | Computers & Internet
Tip
Disable UPnP and SSDPSRV Services to increase your PC security
Windows XP includes support for Universal Plug and Play (UnPnP) which allows UnPnP devices to be connected over a network. Also the SSDP Discovery Service (SSDPSRV) need to be disabled also as shown
There are currently limited UnPnP devices available and due to a recent security flaw it may be advisable to disable these two services. Download THIS tweak and then restart your PC it will set both to DISABLE (0x4)
NOTE: These two services can also cause your Task Bar to malfunction and remove your icons from the righthand side so disabling them will prevent this from happening as well
on Apr 01, 2010 | Microsoft Windows XP Professional
I have dell inspiron laptop and operating system is runing on my laptop is window 8.There is blinking problem in my laptop when it remove from charging. In every 5-7 sec it blink 2 times.please give me the...
The only definitive solution to this problem (rather than disabling various options) is to go windows service and disable the sensor service.
Do the following:
1. Press "Windows Key + R" to open the command menu.
2. Type "services.msc" and press enter
3. Scroll through the list of services and look for "sensor monitoring service"
4. Permanently "Disable" the service.
The "sensor monitoring service" may be used for multiple sensors, but most Dell Laptops have a ambient light sensor that dynamically changes the screen contrast and brightness. This is the only sure way to disable it.
For other solutions see this page
For other solutons see this pa thewindowsclub com
Jan 22, 2015 | Dell Computers & Internet
Why does it says service disabled?
Troubleshooting > Prepaid Disabled/Unit Disabled
  • What should I do if my phone displays "Prepaid Disabled", "Unit Disabled", or "Prepaid Service Disabled"?Please go to "Service and Support" and select the technical support, on our website and follow the instructions provided.
  • Why does my phone display "Prepaid Disabled" or "Unit Disabled"?
    When you unsuccessfully attempt to enter the same code more than 3 times, your phone will lock and disable the Prepaid funtion. Please go to "Service and Support" and select the technical support on our website and follow the instructions provided.
May 12, 2014 | tracfone.com
How does the disabilities services support the empowerment of people with disabilities
The current use of the Americans with Disabilities Act and other disabilities services is to provide the help for the disabled in areas they may be effected. It helps people with disabilities live a normal life. Many have argued for reform because of abuse, but for the most part those who need the services are greatly helped. If all it takes is a wheelchair accesable bus to get someone to their job, it gives that person in a wheel chair the complete ability to live out their life any way they want.
Apr 30, 2013 | Health & Beauty
How do I disable Macafee security system on compaq laptop
Try to check in the services that are running in your laptop.
Follow this step:
1) Right click My Computer. Go to Manage.
2) Computer Management window will appear. Go to Services and Applications.
Here's what it looks like:
If you see any service that is related to Macafee, right click on it and go to Properties.
(NOTE: Don't go away disabling anything if you're not sure. Feel free to get back on me.)
A window will appear.
On the Startup Type field, choose Disable. Click Ok.
That will disable Macafee on your system.
Hope it helps. Let me know!
Thanks!
Feb 01, 2011 | Computers & Internet
The computer doesn't start fast? I have tried scanning the hard disk to fix this problem, but i didn't get satisfactory resultL
Try disabling startup items and services. Just follow these steps:
for Windows XP:
1)click on Start>run>type msconfig
2)go to startup tab, click on disable all
3)next, go to services tab. put a check on "Hide all Microsoft Services", then click disable all
4)Click on Apply, then OK
5)restart the system
for Windows Vista/7
1)click on start>type msconfig on the searchbox
Nov 01, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
''service Disabled''
Depending on the phone, it most likely means that your carrier has cut off service. Or you could be trying to access a feature that has been disabled.
Jun 15, 2009 | Lands Phones
Timeslips & Windows XP Services
well, hard to tell you which one you disabled that is needed, but I can tell you which ones are considered safe to disable, go to this article : http://www.cas411.com/ShowArticle.aspx?ID=82 and try to see if this list matches the ones you disabled.
Alex
Oct 17, 2007 | Timeslips 11 (TSW11RT) for PC
Motorola Mobility TracFone w175 PayAsYouGo Cell Phone Logo
201 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
