Question about Briggs & Stratton Pressure Washer Projectpro Spray Nozzle
I can't start my 6.5hp b s power washer. choke on, in run mode , pulling cord won't start
  • Keith Parker May 11, 2010
    Did it sit all winter with fuel in it?
If my generator shut off due to low lubricant will it reset automatically? If not is there a reset valve/button?
The pull cord is like a starter on a car (separate from the motor/engine). If the pull cord will not turn it could be because the motor/engine is seized.
Mar 04, 2013 | BlackMax 3000 Watt Gas Generator - Powered...
Sym red devil feels sluggish
Instructions
    • 1 Locate the red button on the top of the handlebars. This is called the "kill switch." When you pull it up the engine can run; when you push it down, the engine will shut off immediately.
    • 2 Pull the kill switch up.
    • 3 Turn the key to the "on" position.
    • 4 Make certain the cord running from the key is attached to the steering column. This device acts in the same manner as the kill switch - the engine will run only when it is secured.
    • 5 Pull the start cord, which looks like an enlarged lawnmower pull-cord and is generally found on the right side of the machine.
    • 6 Listen to the engine - if it starts, let it get going slowly . If it "pops" but does not continue to run, try pulling the start cord a few more times. If you do not hear the engine turn over at all, proceed to the next step.
    • 7 Find the pull tab under the right side of the handlebars. This is called the choke - it often has a circle with a diagonal line through it. The choke helps to start an engine when the weather is very cold or the machine hasn't been used in a while. When using the choke, try leaving it on only long enough to hear the engine fire a couple times, then return it to the "off" position. A choke left on too long can flood the engine.
    • 8 Place the choke in the vertical position - this is called the half choke position. Pull the start cord several times. If the engine fires up, place the choke back down to its original position and let it slowly warm up. If the engine still has trouble starting, proceed to the next step.
    • 9 Pull the choke 180 degrees from its original position - this is called the full choke. Pull the start cord until the engine sputters a couple times.
    • 10 Replace the choke to the original off position and continue to pull the cord. The engine should fire up and settle into a steady hum, ready for fun in the snow.
Jan 15, 2013 | Motorcycles
Instructions
Jan 15, 2013 | 2008 Sym Jet Red Devil 50
Motor wont rev up when starting cold with choke on trys to run on idle but will not rev up
the motor wont rev high on choke.the motor is suppose to fire once on choke. then turn the choke off.pull the start cord and the motor should start and run.check that the throttle conrol is on full. it should run fine.
Dec 26, 2010 | Honda 8 HP Engine
How to start a Husqvarna 445?
Set choke to full on. To do this depress throttle all the way down and set choke lever to on. Pull starter rapidly until saw fires . Once it has fired set to start and pull starter cord until it starts. If it doesn't start in ten - twelve pulls,reset choke for two or three pulls,then switch back to start. Pull starter cord until it starts. When it starts it wii be at full R.P.Ms. Let run for twenty to thirty seconds. then move switch to run. Hope his helps, Thanks
Nov 18, 2010 | Husqvarna 16" Chainsaw Chain Saw Bar...
I lost my manual ,how to start the pressure washer
Check gas and oil. With water OFF, pull out choke on washer. Pull the start cord until it starts. Let run for about 20 seconds. Push in choke. Turn on water. Bleed wand line. Insert desired tip. You should be good to go now.
Oct 08, 2010 | Honda Pressure Washer PSI 3000
When pull the cord and the chock is on it starts but stops right a way
Often times in warm weather you may only need to have it half choked or you may not even need any choke...experiment to see how much you need to get it to start and run...
heatman101
Aug 12, 2010 | Honda Pressure Washer PSI 3000
How can you start a Ariens 824 snowblower
Ignition key on, throttle three quarters on, full choke, press primer 3 or 4 times, pull cord. Should cough, maybe start and run rough, then as it's chugging, turn choke to half, then quarter choke, let it warm up slightly, then choke off.
Dec 05, 2009 | Ariens Garden
Briggs & Stratton Pressure Washer Projectpro Spray Nozzle  Logo
395 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
