Question about Kenmore 24032\24036 Top Load Washer
Our Kenmore Model 110 70 Series washer is overfilling the tub on all load sizes. Can you please suggest what the problem might be? We moved recently and the washer was working fine before the move, but after connecting everything today it is overflowing out of the tub.
  • 5,911 Answers
If you just recently moved, you may have a simple problem of a disconnected air hose on the pressure switch. The following link explains:
http://www.fixya.com/support/r762094-washer_overflows
The washer water level is controlled by a pressure switch behind the load level selector knob inside the operator console. Often what appears to a major problem turns out to be something minor. Since you moved recently, the vibration from moving the washer may have caused the small plastic air hose on the pressure switch to fall off. Read through the link provided and let me know if you have any questions. I hope this helps you.
Posted on Jun 29, 2009
I have a Kenmore washing machine model # 11020854990 which recently had a loud banging and knocking sounds during the final spin cycle. Now I notice the drum seems to have dropped down about an inch plus...
Could be a loose basket nut, or on the bottom tub support there are a few springs that help locate the tub. One of the springs could have come off or broke.
Nov 28, 2017 | Kenmore 24032\24036 Top Load Washer
How many cubic feet are in the Kenmore Washer Model 110 80 series
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
Oct 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I have the kenmore 90 series top load electric washer. Model #110.92291100. I am trying to find out if it's a 3cubic or a 4cubic size. I am replacing it and I want the exact same size. It says Heavy Duty...
I couldn't find the exact size using the model number provided... i would bet that it's a 3.5 - 4 cu.ft. model... My suggestion is to get something other than a GE washing machine... Go with a Kenmore, Whirlpool or Maytag
Sep 24, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer leaking
you probably have a bad pump. I am on my 3rd one
Sep 08, 2009 | Kenmore 22422 Top Load Washer
GE WJRR4170 washer comes out of overflow tube on super load. It does not on Large load size. I have the front off and can see a large difference in water level from large to super size. Is this adjustable?
I have a 2005 model GE washer that would overfill only on SUPER size load. After looking around on the web, then inside the machine, I checked the tube from the tub to the switch, no problem there. Then I found an adjustment screw on the load size selector / pressure switch (all one piece). I moved it one turn clockwise, then ran a test cycle. I got lucky on the first try... no more overflow, the water comes up just above the top holes in the tub. I hope this will help others.
Mar 15, 2009 | GE WVSR1060A Top Load Washer
Kenmore 90 series washer overfills
your pressure switch may be bad or your hose that goes from your tub to your switch may be clogged with gunk
Mar 07, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 series spins but won't ring out clothes
Check for buildup of detergent/foaming while washing. Check for oil leaks around the clutch area. Could also be the clutch lining is worn out. Replacement parts kit includes all parts
Mar 06, 2009 | Kenmore 22422 Top Load Washer
Washer overfills
hi thanks for the question i would check the water level hose. it sometimes gets lint in that small hose remove hose anc clean thanks the appliance doc
Sep 13, 2008 | Kenmore 98702 Stacked Washer/Dryer
What is the capaity of 2005 Kenmore Elite Washer and Dryer, models 110?
Starting in early 2002, the capacity sizes were changed around a little bit. A normal sized washer now all have the same sized tubs (pretty much) in the 110 series (Whirlpool Manufactured) washers. The capacity is now rated somewhat by the agitator action the washer comes with. Depending on the type of agitator you have, will determine the capacity. King size capacity means you have a pretty good capacity (size wise) than others. You have normal capacity, large capacity, super capacity, king capacity, and I even think they have canyon (yes canyon) capacity. Capacity sizes dont really mean to much though. In order for you clothes to get clean, the must have room in the tub to move. The must be able to float up, then get pulled down by agitator action. That should determine the size of what goes in the washer. Always use same type clothing when doing laundry (i.e. towels with towels, sheets with sheets, etc, this will keep the load balanced better). Watch what you load, comforters are ok (per manufactures ok) but I do not tlike the idea unless its a front loader, and only by itself. Let me know if this helps you out any.
May 10, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
358 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
