Question about General Electric WBSR3140GWW Top Load Washer
The magnet is not working on my lid in ge washing machine wbsr314og1ww
SOURCE: GE washing machine, wont spin
Same problem (but without any smell). You should try to reset the two computer boards in the washer. You do this by 1) unplugging machine and wait for 30 secs; 2) plug in machine; and 3) open and fully close the lid at least 5 times. This resets computer boards, which can get messed up by power surges, etc.
Posted on Sep 04, 2008
MNfisherman
  • 11896 Answers
SOURCE: have a wjrr417og1ww washing machine. it is about
Check to see if the motor is spinning the belt. If the motor is not spinning, check to make sure there are not loose or broken wires. you can use a mutli-tester or ohmmeter/voltmeter to check any relays and fuses. If all fuses and relays are good, check to see if there is power coming from power supply to motor. If there is power, the motor is bad, if there is not power, the power supply may be bad.
Posted on Jun 15, 2009
gbaker30
  • 4 Answers
if ther was a power surge or power went out machine needs to be reset unplug for 1 minute then replug unit in and open lid 6 times in 12 seconds it should reset . that is what i had to do with mine
Posted on Jun 26, 2009
SOURCE: When the installer tested my newly purchased GE
Hi, open lid , look carefully there's a slot where you can activate switch, use something none metalic, like pen and press to activate.
Posted on Aug 02, 2009
  • 172 Answers
SOURCE: My washing machine will not spin...
I would replace the belt first. It is easy to change and if you are smelling a burning smell, it is the belt burning. You may have other issues but if the belt is burning we know you need that. To change the belt you will need to remove the front of the washer. You will need to insert a small flat screwdriver under the front lip of the washer. The front top left and the front top right, you will simply push the screwdriver into the clip to release the front. The belt will be easily changed by reaching under the motor and around the pulley. This is one of the easiest belts to change. Give it a try and call if you need help. Good luck.
Michael Anderson
Anderson Appliance
(865)945-3808
Posted on Feb 10, 2010
Ge profile top load washing machine won't agitate or spin. Fills and drains fine. Tried motor reset (lift lid 6 times). To no avail. Lid switch is magnetic.
make and model information might help. try contacting the factory for guidance if you have those pieces of info.
age might be a factor...... how old is it ?
Mar 24, 2018 | GE Washing Machines
I have a GE WJRE5550KWW it fills and drains but will not agitate or spin
Possible bad lid switch. On that model the lid switch is the flat plastic square on the right front recess area that the lid closes into. The switch is activated by a magnet mounted on the washer lid on the front right corner.
Dec 22, 2014 | GE Washing Machines
My magnetic lid is not working
WH12X10334 lid switch after you get it I will help you install it
Jan 09, 2014 | GE 3.9 cu. ft. Stainless Steel Capacity...
Washer would wash, or spin. the water appears to drain ok and fills ok
the magnetic lid switch is bad,its located underneath the lid toward the right side of where the lid lays,yoiu will see the magnet under the lid,the switch is below this
Jul 06, 2011 | GE WBSR3140DW Top Load Washer
Dosen't spin, dosen't fill water
your lid switch is a magnetic switch. make sure you have the magnet attached at the lid. if you do still the switch may be bad. question : did the washer fill with the lid open?. if it not then that would be an indication the switch bad. let me know
good luck to you.
Feb 07, 2011 | GE WBSR3140D Top Load Washer
What is sensor magnet in LG 6.5 kg washing machine? Recently I got a dE error and when technicians attended, they said, there was problem to closing door lid. To resolve this, technician replaced sensor...
The machine has a small magnet on the front of the lid. There is a sensor (Hall Effect probably) in the electronics block that senses if the magnet is there (lid closed) or not there (lid open). They aren't that well attached and seem to fall off and wind up in the wash, which means they get lost when the washing is being hung out.
The machine will not start without the lid closed you get a dE error code which means the lid is not shut. You can trick it temporarily by putting a small round magnet inside the front housing if you don't have a proper replacement, as the real one needs to be quite strong. Not sure what they cost, my husband just did the 'trick' to our daughters machine, but a small button magnet wasn't strong enough to trip the sensor from the lid position, he had to stick it right next to the sensor.
Shouldn't be that dear, you can buy blocks of very powerful neodymium magnets in varying sizes for under ten dollars.
Sep 09, 2010 | LG WFT1071TP Top Load Washer
I realized that my GE washer was not spinning because the lid actuator pad is missing. I can pull the hook to make it work, but it needs the pad. They cost about $30 for a small piece of plastic! Is...
all that lid pad is ;is a strong magnet in plastic. find a strong magnet in a craft store. fridge magnets wont work they arent strong enough.
Sep 12, 2009 | GE Washing Machines
No spin
lid switch sounds like some ge had a plunger type switch operation ck for broken pin on lid that pushes switch lever down ..others had a magnetic type switch magnet on lid front right corner that closed switch on cabinet front corner
Jul 31, 2008 | GE WBSR3140DW Top Load Washer
Close the Lid problem on GE Profile Harmony
Kevin, the switch is magnetic operation. You will have to remove the top to get at it. Do this by removing the back panel. Inside the panel on the left side will be 4 harnesses. Disconnect them. Remove the pressure switch hose from the tub. Remove the ground wire. In back on each side of the top panel there will be 2 phillip screws, remove them. Now lift the top from behind and slide foward. The whole top comes off. The lid switch will be on the underside just in front of the dispensor. You can test the sensor by using a magnet. Just open the lid and place a magnet just in front of the dispensor on the left side. The washer should work with the lid up. Catriver
Nov 30, 2007 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
General Electric WBSR3140GWW Top Load Washer Logo
109 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
