If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure to many popular brand TVs are given by one among the posts.
Magnavox sets use a
four digit code to control the v-chip. The override code for Philip sets is
0711, although it may say "Incorrect code" the first time to trick
you. If "Incorrect code" is displayed, simply enter 0711 again. To
use it hit the MENU key to get to the menus. Go up or down until you reach
AUTOLOCK or SMARTLOCK, depending on the model, and push the "right
arrow" key on the remote. Enter the override code, and enter it a second
time if it says it is incorrect. ON".
The v-chip is Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the
"right arrow" key. Go to BLOCKING OPTIONS and press the "right
arrow" key. Go to MASTER DISABLE and press the "right arrow" key
so that it says "MASTER DISABLE now reset.
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect. Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
I think if you can get hold of a Philips universal remote it might help to get hold of most of the functions. please check this link; Philips Remote controllers
hi, For unlocking you tv you have to reset its v-chip. Do the following for the same.
"MASTER DISABLE ON". The v-chip is now reset. ok
Chek in the back of the tv if there is a tiny button, probalbly that you have to use a ball pen to hit it, that says "RESET". press and hold it for 10 seconds an release it.
I used the following that I found on a site that compiles v-chip reset solutions:
Philips and Magnavox:
A model number for your Magnavox TV would be helpful because the Parental Control Reset procedure varies. There should be a sticker on the back of the TV showing the model number.
If you have a newer LCD model, the unlock code is usually 0711. Ignore any "Incorrect" warning and enter 0711 again. Then set or clear the Parental
Access Code.
