I have followed instructions to unlock the control locked feature but my control lock is flashing and beeping every 3-4 seconds and nothing seems to help
SOURCE: Whirlpool Duet HT
Mine just did the exact same thing. I unplugged it, then plugged it back in, and it worked perfectly. Good luck!
SOURCE: control lock
The sound button is the button that you wish the sound to go on when the load is finished drying. Thanks for the advice, I was worried I just bought them and already broken.
SOURCE: Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
NOTE: If the error remains on the display, call for service.
SOURCE: control is locked
Have you tried pushing and holding the End of Cycle Signal" button in for 3 seconds? This button is used to lock and unlock the control panel as a safety feature to prevent small children from manipulating the controls. The instructions should be printed on the control panel near the button.
