Question about Goodman CKL36AR36 Air Conditioner
No "Cold" No "Good"man.........
I replaced my entire system two years ago and had nothing but nice cool temps until now.
I have a one and a half ton unit (goodman) that I believe needs a new capacitor. Both the indoor system and outdoor system are running fine. The line set is not freezing so I am not low on juice "no leaks". I can not hear a wine from the compressor so that cant be my problem.....I hope not....
Tell me if this sounds right? Since the system has been in, the power has cut off and on from bad storms...Recently more then normal. I am thinking that after all the stops and starts, even though its only two years old, the capacitor just had it...
What do you think?
  • 66 Answers
Your on the right trackbut if the outside unit is running fine I have to say no :) . Disconnect the power from the unit and look for visible bulging in the Capacitor(will look like a frozen coke can) If no visible signs take your multimeter and check the micro farads fo the cap if 10% less than rating replace. Also look at the terminals conected to the compressor they may be melted . I would like to know the Capacitor ratings and what your measurments were.
Posted on Jun 30, 2009
Had 16 xi Trane heat pump installed 3 years ago. It ran well for the first couple of years. It began to stop heating and would blow cold air only. Have tried both aux heat and reg. heat to run and neither...
That's a complicated system that needs a qualified technician to service it. Lots of people can install them and they run fine, for a few years. Your indoor unit, operating on 2 heat elements, will feel like its blowing cold air even though its heating, just not so well. And not like you are accustomed to. Each element (5kw)=22.7amps, on average. So 3 elements operating should trip a breaker. Its probably been operating on 2 heat element plus the heat pump. And now you have trouble with the heat pump. If you can't TRUST the guys working on your equipment, try someone else. A second opinion. Normally a 3 or 4 ton unit will have 15kw heat installed, heatpump or not. 5 ton, 20kw. If yours is a 3-4ton, cooling, the 100amp(or normally two 60 amp) breaker should have been installed upon equipment change out. If yours is blowing cold all the time, something is wrong with your heatpump. The electric heat inside operates only when the heatpump can't keep up(real cold outside), the heatpump is in defrost(then it's actually in cooling mode), or if you have the tstat in aux/em. heat. Try a local trane dealer? Of a technician with 15-20 yrs under their belt. A trane dealer should have trane tech support also. BIG HELP!!!
Mar 01, 2017 | Haier Energy Star ESA3183 Air Conditioner
My 08 saturn vue has an odd chemical smell and film on the windshield. Had a shop visually inspect for foreign matter in heater box, and used a boroscope to inspect ducts, nothing found. R&I the...
There was a problem some years ago with sunlight liberating fumes from the plastic on the dash of certain cars and causing a film to form on the inside of the windshield. It could be what you are experiencing
Jan 16, 2013 | 2009 Saturn VUE
2000 chevy venture overheating problems
Sounds like you still have a cooling system leak issue like a cracked cylinder head.
Mar 15, 2017 | 2000 Chevrolet Venture
2004 Toyota Sienna XLE...overheat problem....replaced water pump, thermostat and flushed fluids and added new. Now the temp gage while driving moves up from half on the indicator to 3/4 and the air...
-Are you talking about air conditioning...?
-The fan works but not cold air at all ? that is what you asked?
-If so. then the Freon is very low or no more. Check for leak and fix before refill Freon.
Good luck
Mai
Nov 27, 2017 | 2004 Toyota Sienna
Unit leak at high pressure port. repair man replaced valve charged unit.cooled for a short time then stopped cooling.another repair man found low coolant,thought evoperator leak to be the cause. injected...
Sorry about your problems.
The StopLeak is expensive and does not work on leaks larger than 8 ounces per year.
Neither of these "technicians" confirmed the location of the leak and repaired it.
When the vacuum was done on the system a leak would have been obvious after the first tech replaced a valve.
If they did not see a rise in pressure,they are incompetent.
I apologize for not having an answer for you,but,without being there and checking your system,I do not know what your specific problem is.
Aug 16, 2010 | Ruud Heating & Cooling
In cold weather, does not produce heat until engine is under load and on the road. Engine temp is fine. Coolant fine. Could it be the thermostat?
flush the radiator and cooling system and refill with fresh coolant and distilled water. i know during extreme cold temps, it will take a while but try some good maintenance and see if the situation improves. happy new year
Dec 31, 2009 | 2006 Nissan Frontier
Do you know how I can get a Goodman Ht pmp Manual
this manual willl not help your system perform better , have a qualified tech check your sub-cooling. temp diff, and match your piston with your coil. many goodman systems may say they are 3 or 4 ton but are half a ton smaller than advertised at the compressor. a three ton system will have a two and a half ton compressor
Oct 01, 2009 | Goodman Heating & Cooling
Fridge keeps on freezing everything inside of it
This refrigerator only has one thermostat located in the fresh food compartment it is designed to activate the sealed system (cooling) until it reaches approximately 37 deg f in the fresh food compartment. The damper controls how fast the cold air can move from the freezer compartment to the fresh food compartment. Allowing you to control the temp in the freezer by controlling the flow of cold air to the thermostat.
You have one of two problems.
#1 your thermostat is no longer opening when it achieves set temp. fix = replace thermostat pn 61005798 $35
#2 your damper arm or assemblie has broken. Fix = Replace damper or broken arm and actuator.
damper assembly pn12001377 $44
damper actuator pn 61002000 $2
damper arm pn 61001999 $2
thermostat actuator arm damper arm
damper assembly both pics
Apr 06, 2009 | Refrigerators
In Dec 07 I had a complete Carrier AC/Gas Heating System installed in my home to replace my original system when my house was built in 1983.We upgraded the new system to 3-TON AC as the old AC was 2 and...
Air conditioning requires 400 cfm (cubic feet per minute) per ton of cooling so your old 2.5 ton system would have required 1000 cfm and your new 3 ton requires 1200 cfm. This is not a big change, but if your ductwork is too small it could cause problems. The best way to check to see if airflow is the problem is to check the temperature of the air going in to the system and then check it when it comes out. Take a temp reading with a reliable digital thermometer at the return grill ( the vent that is physically the closest to the furnace that is sucking air in). Then take a temperature reading at the vent that is physically closest to the furnace and that is blowing air out. The target range is for the air coming out to be 18-22 deg F colder that the air going in. If the air is coming out is more than 22 deg colder then there is not enough air moving through the system. If the air is coming out is less than 18 deg colder then the problem is with the system. Potential problems range from improper refrigerant charge or incorrect refrigerant metering to wrong coil/volume ratio which is essentially mis-matched equipment. It sounds to me like you have a company that doesn't really have much of a clue what they are doing. When the company I work for changes equipment in a house to a larger capacity, we always check the ductwork and do the math ahead of time to make sure that things will work rather that throwing things at problems later. Also, when you check your temps turn the system on and allow it to run for about 10-15 min first so that everything has a chance to stabilize and the ductwork has a chance to cool down.
Jun 30, 2008 | Carrier Heating & Cooling
Goodman CKL36AR36 Air Conditioner Logo
118 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
