Question about Kenwood KAC-9152D Car Audio Amplifier
My kac-910 keeps shuting off at high volumes after about ten minuets i have two 12s
    Problem Solver:
  • 20 Answers
I have heard that some newer Kenwood amplifiers will play 6db quieter when they become hot, I have witnessed some Kenwood home equiptment do it as well..
Posted on Jul 27, 2009
  • 113 Answers
Try a 12volt fan it sounds like it is overheating
Posted on Jul 06, 2009
    Problem Solver:
  • 16 Answers
Loose ground? shortage? overheat? sounds to me personally that problem with subs or wire touching ground...so signaling for asmp to enter protect mode?
Posted on Jul 03, 2009
How to convert from cubic meter into square meter
You don't. Cubic meter is a measure of volume while square meter is a measure of volume.
For example, consider a room that's ten meters by ten meters, The room is 100 square meters. Now consider a ceiling that's two meters high. The volume is 200 cubic meters. Then raise the ceiling a meter so it's three meters high. Now the volume is 300 cubic meters, while the area is still 100 square meters.
Oct 30, 2016 | Office Equipment & Supplies
Ihave a keenwood kac 7252 amp that is running two mtx thunder 4500 12`s but amp fuse keeps blowing at higher volume why?
1.-check proper heat sink, or dissipation.
2.- check speaker impedance. Must match between amp and speakers.
3.-low power line on the house may cause low efficience work on the amp, overheat, and finally fuse protection.
4.- finally, check speaker wires. Thin cable overheat amp too.
Nov 23, 2014 | Kenwood Kac-7252 2-channel 1000watt Power...
My 95 Jeep Grand Cherokee keeps shutting off while driving. Sometimes I can put it in neutral and restart the engine while rolling. Most times, not. After 5-10 minuets and as many times cranking, it will...
54 - Sync Pick-Up Signal Not Detected (Camshaft Position Sensor/Ignition Pickup). recheck to see if power to sensor. make sure wire is in good shape, to cam sensor. 11 - No Crank Reference Signal At Power control module, crank shaft sensor. check to see if your getting signal from pcm. Good-day!
May 20, 2014 | Cars & Trucks
What's your problem?Kenwood kac-6295 shuts off then turns back on at high volumes
You got a (Problem) I have never heard of a amp doing that, In the 40 pus years, That i was a certified electronc technician, But like they stay you learn something new everry day,
Nov 06, 2012 | Car Audio & Video
I HAVE A ONKYO TX-910 RECEIVER THAT I PURCHASED IN 1993. IT PRESENTLY HAS NO SOUND. SHOWS POWERED UP & REMOTE CONTROL WORKS. HAVE CHECKED ALL THE SPEAKER WIRE CONNECTIONS & THEY ARE FINE. CAN THIS...
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead
Apr 09, 2011 | Onkyo TX-910 Receiver
HAVE A KENWOOD AMP MODEL KAC-9102D . iT KEEPS SHUTTING OFF WHEN i TURN THE RADIO LOUD. ANY SUGGESTIONS
either bad ohm load or over heat if the ohs on the speaker wires to the amp are lower than specified use in the manual it will act funny cause it is pusing harder than its meant to and if it gets too hot either bad location or bad amp you can try turning the gain down a little until the amp stays on constantly at high volume
May 18, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Why does my KAC-8404 cut off at high volume bass?
amp 101
1/0 wire to the amp or the amps will loose power
check the connections mainly the negative
wiggle the wires see if you get a cut out or not
a cap will help you give constant power to the amp and not allow them to drain on long bass notes
hope this helps
Dec 26, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Amp keeps overheating
Try to turn down the volume??? LOL No really most likly the voice coil is overheating on the speaker, or the unit is over heating. Try to add a fan on top of the unit as I found this on high powered units, that they are being push hard and getting hot. Is the amp really hot when it does this? If it is then its a normal thing as not enough venilation. if its not hot then theres a problem in the amp and should be bench checked by a pro with load resistors and a tone generatoe as well as a scope to check if theres a clipping problem in the output stage.
Sep 02, 2006 | Kenwood KAC-9102D Car Audio Amplifier
Kenwood KAC-9152D Car Audio Amplifier Logo
192 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
