Question about HP Officejet J5780 All-In-One Printer
Faxing more the one page from glasswith out re dailig the #
    President:
  • 3,085 Answers
It should ask you after the first scan if there are more pages to scan.
Posted on Jun 30, 2009
Using a brother MFC-J415W printer, what are the steps in sending a fax?
How to fax :
1. Entering fax mode To enter fax mode press (Fax), and the key will glow green.
2. Sending a fax from the ADF (Automatic Document Feeder): Using the ADF to send your faxes is the easiest way. To cancel a fax in progress press Stop/Exit.
a. Make sure you are in Fax mode . b. Place your document face up in the ADF. c. Dial the fax number. d. Press Start.
The machine scans the pages into memory and then sends the document.
3. Sending a fax from the scanner glass : You can use the scanner glass to fax the pages of a book, or a single page at a time. The documents can be up to Letter or A4 size. Press Stop/Exit to cancel a fax in progress.
a. Make sure you are in Fax mode . b. Place your document face down on the scanner glass. c. Dial the fax number. d. Press Start.The machine starts scanning the first page.
For more detailed instructions, you can go directly to Section 4 - page 22 of the manual in Brother's site. Hope this helps.
Apr 14, 2011 | Office Equipment & Supplies
My feeder for my hp 6110 all in one does not work. is there a way to fax multiple pages using the glass scanner?
Yes, after you place your first page on the glass, press start fax and it will ask you from feeder or glass and you choose glass. After each page, it will ask for the next.
Nov 09, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Unwanted verticle line on fax copies
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page. If this is the cause you will also find that faxes you send to other people will also have this line (although faxes you receive are not affected by this problem with your machine).
To fix the problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 22, 2010 | Brother IntelliFAX 560 Plain Paper Fax
I get lines and can't read the right side of copies that I make with the 1270e. How do I fix this?
You have not specified why you can't read the right side of copies and I am assuming that the reason is because the 'lines' are covering the text. I can offer a solution to the lines issue.
Feb 22, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
I have a black line showing up on my faxed documents. I have opened it up, changed the film and re- set it, but the problem persists. The machine is about 5 years old.
If this is your problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 07, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
Person receiving my faxes are getting blank pages
your ccd is shot... this is the piece of equipment that actually scans the copies.... its the component under the rectangular glass ****.... a tech needs to replace it...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 11, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
Fax will only fax off glass. will not take
Isn't there a small electrical cable connecting the ADF (Automatic Document Feeder) to the rest of the machine? It is loose or disconnected.
Sep 25, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Faxing more than one page from glass.
You should be able to load the pages into the top "feeder" on the printer / scanner / fax. I think the needed to be loaded face up if I remember correctly. From there, you can dial the number, and hit fax, it should start to **** in the pages one at a time until they are all faxed.
Hope this helps!
Tim
Jul 12, 2009 | HP Officejet Pro L7380 Laser Printer
Faxing multiple pages
Faxing using the scanner glass, it would ONLY allow you to do it one at a time. You can Use the Automatic DOcument Feeder on the TOP part of your printer. load all those pages and try to do the faxing. That should work.
Please, let me know if the issue is resolve.
Thank you so much.
adonscott
Jun 27, 2008 | HP Officejet Pro L7680 All-In-One Printer
Faxing
You can't. The only way to fax more than one page at a time is through the document feeder. You can fax all the pages at one time using your software, but you'd still have to scan each page into your computer from the glass one at a time.
Oct 04, 2007 | HP Photosmart C6180 All-In-One InkJet...
HP Officejet J5780 All-In-One Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
