Question about Garden
Can't Find 8 inch chain bar for Troy Bilt pole saw
I have a Troy Bilt, Model TBPS, Pole Chainsaw. It is an attachment to my Troy Bilt Pole Gas String Trimmer. The 8 inch chain bar is worn out, and Troy Bilt does not have the replacement part and could only give the names and phone numbers of part dealers to see if they might have one. No Luck. I have also searched the internet with no luck so far. The Bar has an Oregon Part Number: 080NATA318. I contacted Oregon today and they say it was an O.E.M. part that if they had it, they are not allowed to sell it retail due to contracts with Troy Bilt. Oregon's Technical Services is doing some checking to see what can be done, It might be that I will have to buy a whole new pole saw attachment and pitch the old one. I purchased the saw from Lowe's less than one year ago. Do you have any suggestions before I toss the $100.00 attachment into the trash. I can't use it with the worn out bar. The rest of the saw is fine and in good shape.
  • 4 more comments
  • dglody Jun 29, 2009
    Lowe's does not have the part. They only sell the complete pole saw unit.
  • dglody Jul 26, 2009
    Thanks for the info. Oregon Chains also came up with a substitute 10 inch bar and chain instead of the 8 inch.
  • mark groves
    mark groves May 11, 2010
    Hi have you turned the bar over and used the other side? There is other bar manufacturers they are GB products ,ga power equipment spares . hope this helps
  • Dwain Pippen May 11, 2010
    What is the rest of the model number? There is more after the TBPS, like 41AJPS-C711 or 8 DL 41AJPS-C966. There is one that is discontinued, another still available.
  • Keith Parker May 11, 2010
    They have a book in the lawn and garden section..that they can order just about any part for any piece of equipment they sell..because they cant stock it all...and you already have the part number..so i would call and see.....Keith
    Did you check with Lowes..i have a Troy Bilt trimmer and i seen the pole saw attachment there..and i figure they would have or they could get the chain bar for you..even if they had to order it
    Sergeant:
    Habit-Forming:
  • 163 Answers
I think EARTHWISE CVPS41008 8-INCH CHAIN SAW/POLE SAW is the best for you. More details about the pole saw go to the link The Ultimate Earthwise Pole Saw Reviews
Posted on Mar 29, 2018
  • 41 Answers
SOURCE: TROY BILT TRIMMER MODEL TB70SS. HOW DO I REPLACE
Is the pull rope in the front or rear of engine.Thinking that the string is in the front,you must throttle housing and shaft from engine. remove starter housing. There sould be a screw holding the string and spring in place.
Posted on May 07, 2009
StickyBeets
SOURCE: put string on tb425cs troy bilt trimmer
there are two ways to install the string..the cool way is without pulling the inner reel off the trimmer..just leave it in place..cut (2) approx.two arms length (thats spreading your arms out like airplane wings) of .095 string..now, align the arrow of the inner reel (it turns counter clock-wise..the arrow points outward) with the arrow on the outer spool (pointing inward)..holding the spool and reel together so the inner reel doesnt move, push one of the cut strings through the eyehole in the side of the outer spool, and it should come up to the right, through a slot next to a small round hole the diameter of the string..if it doesnt, it just missed the exit (as i call it)..pull out and try again..let about an inch come thru..now take that end of the string and push the line into the little round hole until it stops, which should be about a little more than 1/8 of an inch..hold it in while pulling the excess line outside the spool to keep it in place..now do the same with the other string for the other side..once you have both lines in place, turn the inner reel counter clock-wise to draw in both lines through the eyeholes of the outer spool..you may or may not get all of the line to wind in..not a problem..you will still have enough to do what you need to do..just cut off the rest..one problem you may or may not have that i do most of the tyme is that it gets hard to turn the inner reel..one solution is to bump the top of the 'bump knob' with your fist, then pull both strings at the same tyme, then continue to turn..this method is quicker and easier than the second way of having the inner reel out and trying to wind both lines at the same tyme and trying to place the reel back in the spool..hope this works for you...
Posted on May 19, 2009
  • 10865 Answers
SOURCE: Troy Bilt Trimmer 75SS stalls at full throttle. new gas
Hello. Let me assist you. Since your trimmer runs but stalls at ful throttle it is telling you that there is a fuel problem. Not enough gas is getting through the carbeurator to satisfy the engines needs on full throttle. Most likely the carbeurator is gummed up. A common problem. Let's see if we can un gum it by getting a can or carbeurtor cleaner. Go to any auto parts store and talk to the clerk about your need.
Posted on May 20, 2009
  • 1114 Answers
SOURCE: line stuck inside head of troy-bilt trimmer
Take an awl or small diameter screw driver, same size or a bit smaller dia. than the line dia., and push it through the hole from the outside of the line head. This should push the piece of old line through the hole.
Recommendation: Leave at least one inch of line on the inside of the head, so you can grab it easily when you have to replace the line. I'll carry a pair of long nose pliers on me when I use my trimmer, so I can easily grab hold of the inside piece to pull it through.
Posted on Jun 21, 2009
bastoe
  • 34 Answers
SOURCE: need a manual for my troy-bllt (new) only
Try the Troy Built site, this may be your model, there are others listed ,
http://www.troybilt.com/webapp/wcs/stores/servlet/product_10001_14102_92351_55009_-1
Good Luck
Posted on Jul 07, 2009
How do I pick the perfect pole saw?
Want to saw up high, but think it's dangerous to saw on a ladder? Good thinking. So how can you get your saw to reach those high branches while keeping your feet planted on the ground?
Take a lightweight chainsaw, add a stick, and you get a pole saw.
TYPE There are three types of pole saw. You can choose any one of them based on your requirements.
CORDLESS POLE SAW Cordless pole saws are said to be the handiest pole saw as it removes the hassle of carrying wires and cords during pruning. It operates through a rechargeable battery. But, due to its battery pack, its operation time is very specific. If you want to extend the time for heavy duties, you can use extra battery packs.
One of the best advantages of cordless pole saw is its need for low-maintenance. You would hardly need to maintain its well-being.
GAS POWERED POLE SAW Gas powered pole saws are mostly chosen by the professionals for its heavy-duty bars and chains and have the power to cut huge and large branches with ease. This pole saw can be extended up to 9 inches so you might distinguish its expertise in trimming high rise trees. It is good for regular use. It is heavier than the electric one and noisy also. Despite being heavy, you would not face any problem working with it as the pole saw is easy to balance.
ELECTRIC POLE SAW Electric pole saws are preferred for small branches trimming as it has blades of 6"-10". It weighs about 10 pounds that means you can carry the saw effortlessly. It does not require high maintenance as well. Plug the long extension cord before you start, aim at the branches and begin pruning with this electric pole saw.
More details
Guide on How to Pick the Perfect Pole Saw
Apr 16, 2018 | Garden
Need Parts
For the pole saw parts go to the link Pole Saw
Apr 22, 2014 | Maxtra Trimmer 30cc 2-stroke Gas Pole Saw...
Parts
this pole breaks because the gear inside is made of puter and when it gets warm enough it melts or breaks the teeth the only solution is to take it out and find some place that makes them to replace it
How to tighten chain on black and decker cordless pole saw
A properly-tensioned chainsaw chain should still be just a little loose on the chainsaw guide bar, but the chain needs to be tight enough that you can't pull the drive links out of the bar nose.
More details how to tighten the chain on black and decker cordless pole saw go to the link Practical Black and Decker Pole Saw Review
Jul 21, 2013 | Black & Decker Black Decker NPP2018B 18...
Remington pole saw
Problem is most likely in the trigger switch on pole. Bypass switch and test bu plugging lamp into power cord coming from pole
Jan 07, 2010 | Remington Electric Pole Saw
I need a new 10 inch blade
A new chain can be fabricated by a local chainsaw shop. A new bar requires a model number to answer, a make couldn't hurt. Tag; you're it.
Lou
Oct 22, 2009 | Remington Electric Pole Saw
Does my remington chain saw model #m15014AS go with the remington ext.pole model #rps96
No, the largest electric pole chain saw that can be attached to a pole with the Remington Pole Saw kit, is a 10" saw.
You can go to Master Distributors to find out more detailed info about your situation and speak with one of their reps.
http://www.remingtonchainsaw.com/
Hope you found this very helpful, best regards!
Aug 07, 2009 | Remington Electric Chain Saw
Troy bilt pole saw will not lubricate any more
I assume you are talking about the oiler for the chain and if so it sounds as if the oiler is either blocked with chips or it is broke. You can go to ereplacementparts.com and put the model and model number in and it will show a drawing of the saw and you can then fix the problem.
Apr 11, 2009 | Troy -Bilt String Trimmer/Blower...
Garden Logo
1,088 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
