Question about Sirius Hoods SIU3 90 SS Island Range Hood
My Sirius remote control unit stopped communicating with the fan unit in the hood. Battery not the problem. Ideas?
  • ldobson500 Jun 30, 2009
    There is no wireless phone nearby, and the distance is in line. The remote was working and then suddenly went dead. The light cannot be acvtivated by the remote as well. More suggestions to try?
    President:
  • 2,923 Answers
You need to isolate the problem. Since you're sure that the battery is not the problem, you need to check the following:
1. Make sure that there's no possible interference between the remote and the fan. Example, wireless phone that might interfere with the wireless signal of the remote going to the fan.
2. Check the distance, make sure that you know the recommended distance of the remote from the unit.
If you get the same problem after checking the things mentioned, there's a possibility that the crystal (transmitter either on the remote or the unit itself) is no longer working. You may need to contact the manufacturer for second opinion.
Have a great day!
Posted on Jun 29, 2009
  • 615 Answers
I think there is a component failulre in the serius remote. Usually contains one major contlolling IC(chipset) and one major resistor. Some time IC fails to work, may be manufacturer defect, may be due to over heat,or cold and also some aspects by external damage.
I think Your remote IC Failed. You must replace the ic or buy the new sirius remote or Universal remote.
Posted on Jun 30, 2009
We have sirius 900 built in. Lights (both) stopped working and apper fine upon inspetion. Fan works fine. I can also hear the light switch click every time switch is depressed. Help. Thanks.
You need to trace the path of the current (voltage) Start at the light and work backwards. Check for 110Vac at the socket. If its there you have a bad bulb, if not keep going backwards towards the switch until you find 110Vac. When you find it the problem will be in between the last 2 points you checked.
Aug 13, 2014 | Sirius Hoods SIU3 90 SS Island Range Hood
We have a sirius model sut900w/su900m built in range hood and all the sudden nothing works on it. Never had a problem for three years. lights nor the fans will work. Is there something on it we should...
the fuse on the unit may have broke or the breaker for the unit ay have tripped, check the breaker and if thats fine check the manual to see if there is a fuse and where it is located. If it is the fuse you can get a replacement at your local hardware store.
Jun 17, 2011 | Sirius Hood Built-in Powerpack, SU900
Hello, have a sirius range hood 600-cu.ft./min of power, 4-speed fan, electronic controls, halogen lighting. its not working at all. press controls, nothing, power is going to it, checked that. what you...
Check for power in and out of the main control board...sounds like the main board has fired...if you have power going in, but none coming out then the board is bad..
heatman101
May 02, 2011 | Sirius Hoods SU3
I have a Sirius range hood SU3. It sound like the right side of the fan blades are off-balance, because it's making a scraping noise. It is starting to get annoying. I looked at it and I don't see a way to...
Yes, I am on my third motor in a SU 4/ Sirius is brutal to deal with. All of the motors are **** and they are always back ordered. here in Canada the distributer change around 2008. They are through Maroline and a crappy company to deal with unlike the othe people in Oakville. Service sucks for such an expensive and beautiful stainless hood. Good luck and the motor does come off...
Jan 05, 2011 | Sirius Hoods SU3
Sirius hood fan maintenence
I do just spray with degreaser first then rinse off.
Then you can wash in the machine without worry of clogging up the unit.
Feb 27, 2010 | Sirius Hoods SIU401-22 SS Island Range...
I have a 2004 tacoma. Remote starter doesn't work. Dash lights on right side of the dash are dim. Remote starter was pro installed 4 years ago. Any ideas? Thanks
look under dash for the unit, remove the 2 fuses in red jackets wait 2 minute then replace fuses
if you have a 4 BUTTON REMOTE CONTROL:
You will need to take the unit out of safety mode, to do this you will
need to ground the hood pin switch wire, then put your foot on the brake,
next hit any button on the remote and the clicking will stop. Then you will
need to take the hood pin switch wire off of ground and take your foot off
of the brake and see if the remote will work with the unit
if you have a 2 BUTTON REMOTE CONTROL:
need to put your foot on the brake, next hit any button on the remote and
the clicking will stop. Then you will need to take your foot off of the
Dec 15, 2009 | Bulldog Remote Starter & T-Harness Kit for...
Remote control stopped working
Under the dome (where the electrical connections are) is the receiver unit for the fan. It could be that it is no longer working. Also the remote may have dip switches to change the frequency channel (sometimes located behind the batteries) check that these have not been changed or check they correspond to the receiver unit on the fan.
Jul 22, 2007 | Hampton Bay 24750 Huntington III Ceiling...
Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Sirius not working after taking to dealership for unrelated problem
How did the dealership resolve the battery draw issue. Did they rewire the Sirius for you. If so they could have wired the unit wrong. If you have a newer vehicle most of the wires in the dash are a very light gauge and most fuctions are controlled by, what's called a Body Control Module. Some of these wires are not a very good place to draw power from not onlt could it damage your Sirius Radio it could damage the electronics in your car as well. I suggest getting it looked at by a professional. Then go from there.
Jan 11, 2007 | Sirius Satellite Radio Sirius Starbase...
Sirius Hoods SIU3 90 SS Island Range Hood Logo
468 people viewed this question
Top Sirius Kitchen Ranges Experts
Thomas Perkins
Thomas Perkins
Zeagle
Level 1 Expert
Are you a Sirius Kitchen Range Expert? Answer questions, earn points and help others
