The water will not stop running
This is an older Hotpoint Heavy Duty two speed with Handwash model. The water will not stop running it just keeps going and eventually overflows. Im thinking the sensor has some issue but dont know where it is located on the machine. Thanks for your help.
  • blueextc3221
    blueextc3221 May 11, 2010
    Your water fill valve solenoid has failed in the open position. You must replace the solenoid or valve to correct this issue.
  • 221 Answers
Just after the pace where water pipe connects there's inlet valve [plastic moulded coil, dimmensions about 1"x1"x1"] it sits on the water intake line and there's twi wires connected to it.
Just replace it, As it's foulty and doesn't respond do actual open/close commands
Good luck
Posted on Jun 29, 2009
My washer works perfect except in the heavy duty fast/fast setting It agitates and seems to be working very hard then stops. it starts for awhile then stops again. There is also a smell of hot metal.
Double check your coupling work first then try the drum bearings by reaching in through the front and see how much movement the drum has? Does it rotate smoothly? Have you run it with the access panel off and listened close up?
Feb 16, 2016 | Washing Machines
Will not stop regenerating water keeps running
What model is it? If it is running to the drain it is most likely stuck in backwash or rinse cycle. We need more info to help.
RJ
Oct 09, 2010 | Culligan Sediment Water Filter Heavy Duty
Scooter runs then stops I turn offf the key and then it runs again and then will stop again also the scooter seems to have lost speed over time
the batteries are worn and problably need replaced , the computer will stop running the scooter at threshold voltage, older batteries and will hit this threshold voltage and slow the scooter
Jul 09, 2010 | Electric Mobility Mobility Electric Power...
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Check the units drain filter. If clogged up it will make this unit run constantly
Jan 24, 2010 | Culligan Sediment Water Filter Heavy Duty
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Washer will not go to the rinse cycel.
check cold water line...onthejob,,,im assuming no rinse cycle only..onthejob,,,no mater the cycle
Jan 31, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore heavy duty dryer
You didn't mention if the motor runs or if it heats. If it does both of these, you'll need a new belt.
Mar 09, 2008 | Dryers
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
