Question about Mitsubishi VS-45607 45" Rear Projection Television
No picture I have an old TV it's a VS-405R.  The tv turns on however there is no picture.  I didn't know if there were any suggestions other than trashing it
  • Anonymous Dec 13, 2007
    We're having the same problem. The TV turns on, there's static and sound, but no picture.
    Genius:
  • 1,153 Answers
Do the self test first ctechnicians.com
Posted on Dec 22, 2007
Samsung plasma TV sound but no picture
Both Vs and Va voltage should be checked. As far as audio is OK, the possibility of main digital board fault.
Sep 01, 2016 | Samsung Televison & Video
I have a 46 inch 1080 P Toshiba TV the green light came on the TV didn't come on then the green light didn't come on anymore what could be the problem I had the TV for a month today
If set is new and only a month old have it repaired under warranty. If no light for power at all now I need to know the model number to give suggestions as to what is wrong.
Apr 22, 2012 | Toshiba Televison & Video
Gradually lost picture; Mitsubishi VS-50501A
you need to buy a new lamp and replace the old one thats your only problem its about $200 for the lamp
Mar 27, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Picture rolling horizontally and vertically
tv needs repair c2c52 and c2po5 need to remove .both should be on the signal pcb
Nov 16, 2008 | Mitsubishi VS-50605 50" Rear Projection...
VS-50609 no picture no sound
Seems to be the power button is stuck on the tv itself
Jun 24, 2008 | Mitsubishi VS-50609 50" Rear Projection...
IS THIS TV PLAYING OUT
Color separation is called convergence mis-alignment......that
problem can be repaired...............Blurry,darker when cold may
be a bit of difficulty..............Have a skilled tech give it a look.....T.
Nov 15, 2007 | Mitsubishi VS-50607 50" Rear Projection...
TV has sound but no picture
Everything is worth fixing provided the price is right.  However, in this case it's probably not cost effective to repair the unit.  Start with the easier fixes, such as bulbs, etc.  Even then, some of the components can be quite expensive, or simply unavailable.  I would suggest getting a quote from a local repair shop in order to make an informed decision before you get to far into it.  You could end up spending just as much to repair it as you would on a new unit.
Oct 19, 2007 | Mitsubishi VS-60703 60" Rear Projection...
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
TV Board Flashing
High Voltage Transformer, FLYBACK try www.bluestar-online.com
Aug 03, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi VS-60705 - picture flutters vertically and horizontally
This sounds like one of the 9 volt regulators on the small signal board is going bad, supplying less than 8 volts. I have seen this is several of those sets. The IC needs to be replaced and if you do not have experience in servicing projection TV's then I suggest letting a qualified tech handle it for you.
Jul 09, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
35 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
