2007 BMW 120i Sport Logo
L
LEANDER VAN RENSBURG Posted on Jul 23, 2014
Accelerator pedal THE CAR REVS UP VERY SLOWLY. THE COMPUTER SAYS ACCELERATOR PEDALMODULE SIGNAL 1
Johnny Johnny
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 37 Answers
  • Posted on Jul 23, 2014
Johnny Johnny
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
37
Questions
0
Helped
4312
Points
92
You can try to reset / recalibrate the accelerator pedal sensor at a bmw indy shop.
If this does not help the accelerator pedal sensor may need cleaning or replacement.
Hope it helps
  • LEANDER VAN RENSBURG
    LEANDER VAN RENSBURG Jul 23, 2014
    HI JOHNNY. CAN I CALLIBRATE THE ACCELERATOR PEDAL ON THE BMW 120I MYSELF?
Motor revs fine in park or neutral but slowly accelerates to speed when gas pedal is to the floor
Are you saying when off road it has good performance and revs normally?
2006 aveo throttle body issues
What engine does it have ? Could have come with 5 different ones . If it has the 1.6 L engine . has electronic throttle control.
The throttle actuator control (TAC) system is used to improve emissions, fuel economy, and driveability. The TAC system eliminates the mechanical link between the accelerator pedal and the throttle plate. The TAC system eliminates the need for a cruise control module and idle air control motor. The following is a list of TAC system components:
• The accelerator pedal assembly includes the following components:
- The accelerator pedal
- The accelerator pedal position (APP) sensor 1
- The APP sensor 2
• The throttle body assembly includes the following components:
- The throttle position (TP) sensor 1
- The TP sensor 2
- The throttle actuator motor
- The throttle plate
• The engine control module (ECM
Check engine light lit ?
Engine revs up down while in idle
If its been without the line for over a year, I Highly doubt it. Look into IAC valve. Most are installed with 2 screws, easy to adjust. Idle Air Control Valve. Look that up, for a start.
1helpful
2answers
Car will not accelerate when gas pushed
Accelerator pedal position sensor needs testing.
3helpful
3answers
Error code p2138
Here is the definition. You may need to have someone check the accelerator pedal position sensor and the circuit.
P2138 NISSAN Description The Accelerator Pedal Position (APP) sensor is installed on the upper end of the accelerator pedal assembly. The sensor detects the accelerator position and sends a signal to the Engine Control Module (ECM).
Accelerator pedal position sensor has two sensors. These sensors are a kind of potentiometers which transform the accelerator pedal position into output voltage, and emit the voltage signal to the ECM.
In addition, these sensors detect the opening and closing speed of the accelerator pedal and feed the voltage signals to the ECM. The ECM judges the current opening angle of the accelerator pedal from these signals and controls the throttle control motor based on these signals.
Idle position of the accelerator pedal is determined by the ECM receiving the signal from the accelerator pedal position sensor. The ECM uses this signal for the engine operation
such as fuel cut.
Read more: http://engine-codes.com/p2138_nissan.html#ixzz26J3D2x8s
Wont idle or rev
theres a throttle position sensor and one part is connected to the accelerator pedal underneath,its like a rheostat in a radio,when you press on the gas pedal it sends a signal to the computer to increase the rpm's (just as a radio increases in volume),if this component opens up,it will not increase rpm's with pedal pressure or change
Top BMW Experts
vince
Steve Sweetleaf
Steve Sweetleaf
old marine
old marine
Are you a BMW Expert? Answer questions, earn points and help others
