Question about Kenwood eXcelon KDC-X769 CD Player
Mine goes crazy too
Cycles in and out and shows "code off" momentarily. Sometimes if I ignore it long enough (10 minutes or so), it will start playing the (already) inserted CD normally, but the next time the truck is started, it goes nuts again!
    Scholar:
  • 105 Answers
Trying doing this when it says code off
Common Kenwood Security Codes
Many Kenwood radios are configured with the same security codes:
KCAR - This seems to be a "backdoor" to some Kenwood models.
3051 - This is the security code which is printed in the manual of many Kenwood models.
1234 - This is a security code commonly chosen by Kenwood owners.
Entering Your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
Enter the security code using your Kenwood remote.
Type 2
Press the "Auto" button and "Track up" on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote
To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter -- then press the Track Up or Next Track key to send the letter.
To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in some Kenwoods
There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
Posted on Jul 15, 2009
How to disable the vats security system on my 2001 oldsmobile alero?
you cant disable it, its a pass key system not a vats system (vats reads a resistance value in the key). The ignition cylinder has a sensor in it that measures a rotating resistance (then translates into a voltage reading) that the bcm reads to let the car know to start. Usually you can try and start the car, then the security light will start flashing - leave the key in the on position for ten minutes until the security light goes out. Then turn the key off, wait, then try and restart - they usually relearn the code after the first 10 minute try. Sometimes it takes three 10 minute cycles.
Jan 01, 2015 | 2001 Oldsmobile Alero
T01 s-10 4.3 L. sometimes at the pump seems like battery died.few minutes later it starts up n goes
If you have an autozone nearby you may be able to have the battery checked as well as
the codes read. (My battery did that one time in the S-10 and then quit within days of the
warranty expiring). I would also look at the Mass air flow sensor code to see if yours is
intermittent as mine was and check for cracks in the gas cap itself on the seal. These
also have a bad habit of losing the downstream O2 sensor which is at the "Y" just
ahead of the converter. These things will show up on the code reader with the exception
of the gas cap. Hope this helps.
Jul 31, 2011 | Chevrolet S 10 Cars & Trucks
Middle of cycle message comes up "err7"
Good day, FRIGIDAIRE GALLERY SERIES 4y old well mantained and clen even strainer. the electronic system suddenly went off change of cycle does not show the change of minutes an 18h shows on screen, disconect for a wile appears to work, it starts and stops after 10 minutes and beeps ready no lights then goes crazy again. Please help email: arupro@setarnet.aw
Aug 25, 2010 | Frigidaire ATF6000ES Front Load Washer
Screen on off often for no reason
There are some common problem for this model:
1. Power cycles on off with no error codes. (not screen on off) G1 board failure. Part # 1-468-980-12
2. LVDS cable failure my cause picture comes and goes. Part # 1-832-470-11
This information reference Sony tech support.
May 14, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My computer does not always turn on... osmetimes
maybe it overheats and once your gonna do something it just goes white and turns off .... im not with that but that what happens to mine then i bought a cooling pad and it started working better.
Apr 15, 2010 | Acer Extensa 4620 Notebook
2002 grand am 2.2 turns over wont start. fuel pressure 55psi, has spark
discovered the hard way- ($85.00 later) Step 1: turn key to "on" position. step 2: open driver door. (security light should be flashing on and off) step 3: wait ten minutes with key in "on position and driver door open. step 4: when 10 minutes is up-(youll know-because security light will have stoped flashing after 10 minutes) close driver door ,turn key to "off" position, then turn key "on" to start. drives me crazy!! I have to do it to mine sometimes 2-5 times a day! GM2.gif doesnt have a fuel reset button etc. like fords do.
Aug 08, 2009 | 2002 Pontiac Grand Am
Screen goes crazy after about 1 minute
try it on tuner mode to seperate the fault from video to rf input,if gone the video pc board is at fault.
Aug 11, 2008 | Samsung HLN467W 46" Rear Projection HDTV
DVD images freeze at certain points or playback becomes choppy
sounds like you will need to clean laser, there are cleaners you can buy out of walmart for this. Don't know if they work well, I take mine apart and use soft cloth and alcohol then letting dry, works fine for me.
Dec 16, 2007 | Sony DAV-FR10W System
Kenwood eXcelon KDC-X769 CD Player Logo
120 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
