Question about Whirlpool 3.2 cu. ft. Plus Washer
WHIRLPOOL LXR7244JQ1 CLOTHES ARE STILL SOAKING WET
WHIRLPOOL LXR7244JQ1 WE JUST REPLACED THE LID SWITCH & THE
CLOTHES ARE STILL SOAKING WET WHEN CYCLES ARE FINISHED IT SEEMS THE TUB IS NOT SPINNING FAST ENOUGH
  • gloriadtipto Jul 03, 2009
    it was the clutch
    we replaced & it spins great
  • 138 Answers
More than likely motor has lost a stage in it. I would replace it.
Posted on Jun 29, 2009
Soaking wet clothes after spin cycle
Check and choose a longer spin cycle and see if the fault changes. If so the SPIN cycle is too less or there is less action or speed in the cycle, check the motor speed, check the capacitor to the motor, the spindle friction - if so reset the spindle and drive.
Jan 17, 2013 | Washing Machines
Washer is completing all cycles, but water from wash cycle.is left.in washer and clothes are still soaking wet. No water drains out.
check the Lid safety switch, if its shorted the spin cycle won't work, so your left with wet clothes ,, you can jumper the 2 wires together to test the switch , if that makes the cycle work, Replace that switch
Jul 06, 2011 | Washing Machines
My dryer is making my clothes soaking wet every time I put clothes in. How do I turn the warer off on the steam mode (I guess)
Same problem here....I have had my brand new Whirlpool Duet Steam front load washer for a whole 4 days... It has worked perfectly until now. I checked on the clothes because it seemed like they just kept going and going... they were soaking wet!! When I took the clothes out the dryer had a huge puddle of water in it..Can anyone offer any help?
Sep 30, 2010 | Whirlpool Duet Steam WFW9700V Front Load...
Clothes are soaking wet after washer is done
maybe your clutch is slipping not getting full spin speed,,,,or could be a problem with your basket drive assy
Feb 21, 2010 | Whirlpool LSB6200KQ Top Load Washer
Spin Cycle Not Working
the most common problem when this occurs is the lid switch has broken inspect it if not click when lid is closed replace the switch you see if you can get local it saves some shipping cost unless they are outragious then order on line
Aug 07, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
The model# is LXR7244JQ1...I PURCHASED A NEW switch-lid
Pop the lid open from the front or sides of the top panel. This should expose the switch. Pretty simple task. Just remember what you do. Don't forget to disconnect power cord before servicing.
Jun 30, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Clothes are soaking wet because it doesnt spin.
check the door switch for broken or damaged wires. get a jumper wire to go from one wire to the other wire on the switch. If the jumper wire is connected and the washer spins out, then the door switch needs to be replaced
Jul 11, 2008 | Washing Machines
Will not drain properly-clothes are soaking wet
I had same problem and Whirlpool factory service had to replace motor position sensor board. He is info from another posting:
446a518.jpg By wizard_s.gif eagle338
Rank: Wiz
Rating: 75%, 482 votes
there is a motor rotor position sensor(RPS) failure.
Refer page 10 of the manual below
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567036.pdf
Dec 10, 2007 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool 3.2 cu. ft. Plus Washer Logo
602 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
