Question about Yard Machines 158cc Push Lawn Mower #11a 034f200
Pull cord pulls out so far and then stops like it is stuck
  • 1 more comment
  • chicki Jun 29, 2009
    nope, the cord will not pull any further and will take up something like an inch that's about it
    I tilted the mower over on its side, and gave the blade a wind, put it back right side up and it started right off after pulling the cord, it smoked a little, mowed for a few minutes and did the same thing, this time it kind of spit some oil, I am letting it cool before starting it again......thank you all.....
  • chicki Jul 04, 2009
    I did NOT report this as an abuse, these guys helped me....
  • 57 Answers
Make sure the safety brake is off while pulling
Posted on Jun 29, 2009
  • nuttbysteve Jun 29, 2009
    engine could be seized is it full off oil or did you hit something before it quit you may have to ke the starter off and see if you can turn the engine over by the blade
  • nuttbysteve Jun 30, 2009
    the pvc valve is plugged it is on the side of engine about 1.5 by 3inches
My recoil starter won't pull out it is stuck
Just take the cover bolts for the pull cord off. Then see if it works. There are usually two cogs that engage into the shaft of the engine. These cogs push outward when you pull the cord, engaging the shaft of the engine.
Oct 01, 2014 | Garden
I tried pull the cord stuck took it apart spring ok.the shaft from engine stuck,
Sounds like you have a bearing failure, eithe big end or crank shaft bearing. When they go they quite often knacker the piston and cylinder too as it can put them off square. Remove cylinder and the problem will be easy to locate as you can see the big/small end bearings and check for cylinder damage. Often the cost of repair far outweighs the value of the equipment.
Apr 07, 2013 | Husqvarna 128 LD Weedeater
Toro pull cord won't rewind
You have to open up the starter and reattach the spring that works with the pull cord. A royal PIA.
Sep 16, 2017 | Toro Personal Pace CARB Walk Power Mower
My pull cord is stuck. It will only pull so far and it stops
Remove the top cover to your engine, along with any attachments. Your cord is in the top of this cover. You will be able to see where the problem is when you pull the cord.If you find that the cord has tangled somehow, you will need to untangle the cord. Be careful not to damage the cor in the untangling process. GOOD LUCK.
Sep 24, 2011 | Garden
I have a Poulan PRO LINK PP 335 and the pull rope is only coming out about 8 inches. It's stuck...what should I do?
Remove the starter and pull the cord, if the cord still only comes out so far it is either the cord is too short ( replace the cord ) or the rewind spring is coil bound ( release some of the tention )
Apr 23, 2011 | Poulan Garden
Pull cord getting stuck
Pull starter rope wheel is Jamming against casing usually some lube n check for ware will fix it
Mar 21, 2010 | Karcher 2500 PSI Pressure Washer
Cord getting stuck, won't come fully out.
Hi Karen. Chances are your cord has a kink in it which is preventing it from coming all the way out. Pull the cord out almost as far as it will come and then twist the cord one way or the other and pull to get the kink out of it. Once you have it all the way out you can start closest to the machine and smooth out the entire cord to be sure that the kinks are more or less permanently gone.
Apr 30, 2009 | Dyson DC08 Hepa Allergy Bagless Canister...
Pull-cord will not retract.
If you put a longer cord on it , then it will not retract as far and get stuck.
Jan 24, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Yard Machines 158cc Push Lawn Mower #11a 034f200 Logo
646 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
