Question about Dryers
Will not heat
All other functions work but unit will not generate hot air for drying.
  • 57 Answers
You need to replace the heat coil can be done by a home hanyman
Posted on Jun 29, 2009
Unit is turned on air cond. and heat coils are also on
How can you tell the heat coils are on? Is it just the heat generated during the coolant boil and compression process? Or are you getting hot air?
Jul 06, 2017 | Heating & Cooling
Amana ALG443raw gas dryer
sounds like the thermostat is shot..do you fix this sort of thing yourself?
Mar 17, 2008 | Amana ALG443RAW Gas Dryer
I have a washer dryer combo DWC LD1013 it stoped drying. My clothes are more wet when put in to dry. The clothes would be extremely hot but all wet. It works 1 cycle and then stops. Please help ????
In order to dry cloths, you need two things, heat source and air flow. Sounds like you have heat but no air flow. If you can, pull unit out and check vent for washer. Look around unit and make sure there is nothing blocking any vents. If you don't see any thing, try drying with vent not installed. I run into a lot of homes with clogged vents inside walls. By drying with no vent installed, it might tell you if you have dryer problem or a home issue. Good Luck
May 25, 2016 | Washing Machines
Whirlpool AWZ 410 washer dryer is not generating any hot air when drying. The dryer drum is tumbling but with cool air only.
Unplug the unit and take the top with the screws holding the lid on. Take a look at all of the wires on the top of the machine. You might notice broken/burnt wires on the safeties that are close to or that directly activate the heating element located in the blower housing located at the top of this washer/dryer condensing unit.
Nov 26, 2013 | Whirlpool LER4634J Electric Dryer
Frigidaire diswasher not drying dishes properly
Make sure you have the heated dry setting selected, use rinse aid at all times, and make sure the unit is getting hot. If it is not, or there is no steam generated when you open the unit after cycle - have a professional diagnose the heating element.
Aug 01, 2012 | Frigidaire Dishwashers
How long will my AC work for, if placed inside the room
I assume that we are talking about a "window" unit. No, you cannot just place it in the room. The machine is actually two parts; one part delivers the cool air to you, the other part ejects the heat out of your house. If you just had the whole unit inside, the room wuold actually get warmer, not cooler. The reason for this is that the compressor and motor generate heat also. The "heat of compression" generated has to be ejected from the room in order for the air conditioner to work. Put it in the window.
Best regards, --W/D--
Aug 10, 2009 | Heating & Cooling
Gas dryer/ whirlpool
well your generating heat which is a good sign, either there is a blockage in your venting() most likely source of issue!) but you say ou replaced, i would then look to replacing the valve coils, 279834, about 20 bucks, easy to replace... its possible that they open the valve upon start up allowing heat, but after being on 20-30 min they overheat and no longer open not allowing heat to generate..
Apr 03, 2008 | Whirlpool LGV4634JQ Gas Dryer
Dishwasher not drying
Same problem here. I read the manual very carefully. "OptiDry", "ExtraDry", "EcoDry", "condensation drying" -- lots of fancy words to cover the simple fact -- they DO NOT DRY the dishes. There is no heating element. I wish they would just state this up-front. Air drying the dishes for 24 hours after each wash is not workable for most users...
Nov 12, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Clean light flashing
The clean light should be blinking 7 times, pause, then repaeat if it is doing this -- it is a water heating fault. Use one of the following key dances to clear fault
a) Heat Dry - Normal - Heat Dry - Normal
b)High Temp-Air Dry-High Temp-Air Dry
All the Leds should light up now just press cancel and Unit should operate. If it shuts down again the heater isnt working properly. Some times the door doesnt get shut well and that causes the fault. But the dishes arent very clean if the heater is not working.
Oct 16, 2007 | Whirlpool 24 in. DU1055XTPS Stainless...
Dryers Logo
35 people viewed this question
Top Dryers Experts
Marvin
Marvin
