Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
Mitsubishi rear projection TV, Model VS-464R, intermittently has a snowy picture. When I first turn the TV on, it works fine. After about 20 minutes, the picture becomes snowy for at least a half hour. Then the picture returns, and the TV works fine. What is causing this problem?
  • 3 Answers
I have the same problem i am looking to solve it
Posted on Aug 11, 2009
Mitsubishi vs-55707 or vs-50707????? bouncing horizontal lines weird color
If the picture looks like a 3D then you have a convergence failure.
I would suggest to visually inspect the STK Ics for dry or crystallized solder joints.
IC8C01 - STK392-110
IC8C02 - STK392-110
Dec 11, 2008 | Televison & Video
Mitsubishi VS-5046
i have a 50in mitsubishi tv model vs5046 the screen protector is crack the tv works fine but need to know where can i purchase a protector or its there a number. also how much will this cost.
Oct 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Snowy picture
Usually a snowy picture means that you have a bad ground connection. You should see that some channels are beter than others. Verify that the cable connection is good. Try a different cable if you can. If that has no effect, than we need to start looking at the tuner itself. If you can change channels but just have a poor picture, chances are that a resolder of the tuner section will resolve the problem.
Keep us posted.
Dan
Jul 29, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Tv problemsMitsubishi VS-60705 60 in....
My Mitsubishi Model VS-60705 did the same thing a couple of years ago...A TV repair facility replaced the Video card. Any repair facility facility that works on rear-projection TV's should be able to repair your set.
Jul 10, 2008 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi VS-60705
I have a Mitsubishi VS-60705 and the picture flutters vertically and horizontally i need to be fixed
Dec 04, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi VS-4551A TV Problem
This rear projection t.v. will turn on and the audio works fine, but there is no picture of any sort just audio
Oct 17, 2007 | Televison & Video
Mitsubishi vs 5051 rear projection tv sound but no picture
No video but good audio Mitsubishi VS5051. Check R509 and R 519, 100 ohm resistors located on the main PCB near the flyback transformer. Also bad connections on any of the yokes and the vertical output IC will cause the same problem.
Sep 19, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Only Picture in Picture Works...????
Its possible some of the surface mount capactors has failed on the pip board is so the unit will need to be replace or repaired.
Mar 18, 2007 | Mitsubishi VS-45603 45" Rear Projection...
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
274 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
