Question about Drifter Poolmaster Detroit Pistons Luxary Pool Raft
Luxaire AC will not start, it just humms
Model: HABA F036SA
I just had the HVAC guy check it out and got the thumbs up and less than a week later its not working.
Any thoughts.
Our 2012 Arcadia danali is blowing hot air out of the drivers side ac and cold air on passenger side. This just started since we had the batterery replaced a week ago. Any suggestions
Sometimes the system will reset if you pull out the hvac fuse, wait a while, and put it back in. If not, the blend door actuator will have to be checked.
Nov 17, 2017 | AC Cars & Trucks
What does the acronym HVAC stand for?
Heating Ventilation and Air Conditioning
Jan 30, 2013 | Heating & Cooling
I need the instructions for the Animal Upon Animal Game Preschool game by Haba.
Here you go, the English instructions start on page 6 of the PDF.
http://www.haba.de/medias/sys_master/8797181706270.pdf
If that's not the right version, click the link below and type in "Animal Upon Animal" in the keyword box and you should be able to find it.
http://www.haba.de/haba/home.htm
Have fun!
May 14, 2011 | Toys
Driving 2004 intrepid after it was sitting in drivway for 2 weeks. engine light came on, after about a mile, car just died. unable to start. just clicking from starter. lights dim out when trying to start....
Check the alternator,it should read at the battery 13.65 to 14.25 volts with the headlights on,and ac on high blower ,it should not read less than this,if it does the alternator is bad.
Jun 06, 2010 | 2004 Dodge Intrepid
Luxaire AC unit control works but the ac unit will not turn on
Sounds like it could be your transformer. See if you can locate it. It should be in the air handler indoors. Check the voltage going to the transformer and check the output of the transformer. You should have around 24 vac on the output of the transformer. If you don't have voltage on the output make sure you have it on the input (120vac). If you don't have it on the input you need to find out why. If you have it on the input but don't have an output then your transformer is likely gone bad. Let me know what you find.
May 18, 2010 | Heating & Cooling
The transformer on my central AC/heater (luxaire model # A236A344T LH) keeps going out. There are 4 settings on the wall. Cool, off, heat and EM. Heat. The setting switches to EM. Heat each time the...
You might have some thermostat wires that are touching meaning the insulation has been broke off and getting a direct short. Check the wiring going to the outside unit and replace any wire that is in bad shape. let me know okay. Ken
Dec 11, 2009 | Honeywell Programmable Thermostat Heater
Do you need to have batteries on charge everynight even if you have not used the scooter as ive been told that with the travelite you do i borrowed one in process of buying it from friend
If you use the scooter then charge it. You need to charge the scooter at least once a week even if you don't use it. More importantly is that you charge the scooter for at least 8 hours at a time. If you charge it less then it will start killing the batteries.
Oct 28, 2009 | Haba Drive Mini Phantom Three Wheel...
AC blows hot air
it will be more seals or a very hard to find leak in the evaporator core or condensor
Jul 28, 2009 | 2003 Saturn ION
What ton is my old Luxaire AC unit? it is model EESQ36
Sure but you need ot have an AC man to replace it and vac down the system plust change the dryer/reciever.
Jun 12, 2009 | Weather King 10AJA3601AH Air Conditioner
The air quit blowing cold for two weeks then started again, three weeks later quit then a week later started working.
Sounds to me like its time to go to a service shop and have your AC recharged, it could be that the amount of refrigerant in your AC system is low, possibly depleted. I would go have that checked out, there is not much that you can do personally unless you are liscensed to handle/recharge refrigerant systems, if in that case your in luck.
May 04, 2009 | 2006 Chrysler PT Cruiser
Drifter Poolmaster Detroit Pistons Luxary  Pool Raft Logo
174 people viewed this question
Top Drifter Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Drifter Boating Expert? Answer questions, earn points and help others
