Question about Samsung SCX 4521F All-In-One Laser Printer
Copy Counter We were wondering if the below model has a copy counter. We seem to be going through the toner very quickly and we want to see how many copies we get out of each toner.
  • 1,113 Answers
CC is on status/config page, print via printers keypad menu
Posted on Nov 08, 2007
How do i set the counter papaer. I want to set the conter so I know how much paper and ink I am using
There is No way to set the copier to tell you the amount of toner & paper counter. Unless you make a copy of the same exact copy ever time you press the start button. The toner yield is figured out by 5% coverage of toner on a Letter size paper
May 21, 2012 | Canon Office Equipment & Supplies
Trying to clear the memory of a Xerox Faxcentre F116. Do you know the steps to accomplish this?
One needs to know what they are doing when resetting memory to the machine.
When resetting the machine, one needs to consider, the loss of memory data on the copy cartridge counter in the machine.
When resetting memory a copy toner cartridge needs to be in stock with a counter reset card.
Erasing memory will wipe out the old copy/toner cartridge odometer setting, resuling in "Replace toner/cartridge" error.
Please clarify which memory area is being erased.
Aug 05, 2010 | Xerox FaxCentre F116 Plain Paper Laser
Copy is too light after installing new toner and drum,
did you reset the drum counter after replacing the new drum? Open the front cover and press the option button... then just select reset drum counter...and press set...
Jun 02, 2010 | Brother MFC 9700 All-In-One Laser Printer
My printer drum light is lit and will not copy. I have put in a new drum and the is still lit and will not copy
Please follow the bellow instruction…
Open the front panel.
Remove the toner and the drum.
Remove the toner from the drum.
On each side of the toner, there should be a little glass. Put the piece of duck tape on one of them.
Put everything as it was.
Turn on your printer.
Now, the low toner light should be gone and the green light should be on.
Now, you can empty your cartridge.
If the Drum light is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
Open the front cover.
Locate the control panel button under the LED lights on the left side.
Pres the control panel button until all lights are lit, and then release it.
The Drum counter is now reset.
Thanks for contacting
Feb 02, 2010 | Sharp AL-1540CS All-In-One Laser Printer
Savin 9940DP ''Set Key Counter''
Key counters are used when a copy machine is set up for public use where copies are charged on a per copy basis. Key counters look like small boxes that plug into the side of the machine and they have a counter on them that looks like a cars odometer. A user plugs in the key counter, makes copies and then takes the counter to a register to pay for the copies they made. Sounds like that is what you have going on.
Nov 02, 2009 | Savin Office Equipment & Supplies
How to tell if low on ink samsung 4521 fg
if toner is low display toner low
copy counter press menu goto the report and system data
Oct 10, 2009 | Samsung SCX-4521FG All-In-One Laser...
Where is the toner counter?
The machine not avaible to toner counter only the copy counter.
Oct 01, 2009 | Sharp Office Equipment & Supplies
CC and drum Icon will not go out after changing toner cartridge
This Machine needs a copy cartridge. Replacing the toner will not clear it. The copy cartridge is the drum unit which is why the drum light is on. With the new copy cartridge a chip on the cartridge will reset the counter and clear the "CC" and the drum light. If you cant find this I can send you one. I believe on this model it is user replaceable.
Oct 31, 2008 | Office Equipment & Supplies
Brother MFC 8860DN Toner End Life Error
Open the door where the toner goes. Press the 'back' button. Press *00. Do not respond to the query about the drum. Close the door. Other models may have to press the 'Options' button located near 'Copy'. This should work.
Jul 08, 2008 | Office Equipment & Supplies
Samsung SCX 4521F All-In-One Laser Printer Logo
105 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
