Question about Garden
Help needed to replace idler wheel bearings of my digger
Hi, I need some help to replace the bearings on the collapsed idler wheel of my bobcat 5 tonne digger (home self-build!) This maybe a job for a workshop as the spring pins that hold the shaft in place seem imposible to drive out.Any suggestions? (nr Redditch West Midlands)
thank you
martin
  • 235 Answers
Its cheaper and easier to replace the whole wheel . Try DIGBITS or any of the UK undercarridge firms .
Posted on Jan 02, 2010
How to remove front idler on bobcat 331 mini excavator
Bobcat 331 Mini Excavator, Front Idler Assembly
www.loaderpartssource.com/bobcat-331-mini-excavator-front-idler-asse...
Loader Parts Source, Inc. offers this Front Idler Assembly for Rubber Tracks (W/ Holes in idler) for replacement on the Bobcat 331 Mini Excavator. Serial Number ...
Bobcat Idler: Construction Equip Parts ' eBaywww.ebay.com/bhp/bobcat-idlereBayBobcat 325, 328, 331, and 334 Front Idler - Undercarriage, Mini Excavator, ... BobcatT140 T180 T190 T200 T250 T300 T320 T650 T630 T750 864 Front Idler ...Undercarriage Parts Can Help You:Eliminate Unwanted Machine Downtime.Front/Rear Idlers - Mini Excavator Partswww.miniexcavatorparts.com/productcart/pc/viewCategories.asp?...14Aftermarket front and rear idlers are available for Bobcat track loader and mini excavators, Kubota miini excavators, and ... Aftermarket Bobcat® Front Idler - Bobcat CTL ... Aftermarket Idler - Bobcat 325 328 331 334 430 335.
Dec 25, 2015 | Mini Cars & Trucks
Belt is broke and plastic wheel is worn into .
plastic wheel = Idler pulley
a bad bearing in your idler pulley may have stopped the idler and broken your belt to repair replace idler pulley and bearing and belt
Apr 05, 2008 | Dryers
Replace rear wheel bearing 773 bobcat
you must unbolt it from inside chainbox. Raise cab, and remove about 8 bolts that hold a plate that is back toward the engine, in line with back axle. Inside you will see 2 large chains and sprockets, and a bolt that holds the sprocket to axle. Use a 1-1/8" wrench to remove bolt, then axle may be removed. Replacing outer bearing and seal is now possible
Sep 23, 2012 | Bobcat 773
I have a freelander 2001, got a rumble when driving and when going round roundabouts the noise transfers to passenger front and sounds like thudding. Noise in time with road speed not engine. Have changed...
first check tyre tread, remove objects in tread as these can cause some of the symptoms, others are the bearing and tracking and steering idler, also can be a lose wheel, another thing to check is the discs look for broken or warn pads stones can get in and damage the pad or twist the pad in turn can make a rumbel. ( if you brake and the rumble stop it can be this part that's wrong) bearings and tracking jack up the wheel and test with a wiggle from 12-6 and 9 to 3 on the wheel if makes a sound or moves excessively then this can be the bearing has failed and needs replacing if this is fine check the the tracking and idler pull on the tracking arm if you feel a clunk then its weak and needs replacing same on idler. hope this helps
Nov 28, 2017 | 2002 Land Rover Freelander
Serpintine belt came off after a couple of days of a squeaky grinding noise from that area. no issues with power or electric or cooling before it came off. could it be more than just the belt
Hello bigfish.
We often see this on the Chrysler vans in the shop.
You will need to check all the pulleys and bearings that the belt runs on.
Alternator, AC compressor, tensioner pulley, idler pulley, power steering pump.
Also the tensioner has a heavy spring in it that keeps tension on the belt and pivots on an aluminum pin.
If it wears it go crooked and tilts pushing the belt off.
All these parts are available through your favorite auto parts store.
I would recommend a Goodyear Gatorback belt if you are replacing it, they seem to work the best.
If you would like further advise with this, please ask me in comments.
Thank you.
KL
Feb 20, 2011 | 2002 Chrysler Voyager
Have 2006 buick rainier....when i back up and turn my wheels sharply i hear a grinding crunching sound in the back underneath the car... anyone else with this problem
hi, if your vehicle is 4wd then the problem your having is going to be that one of the bearings have collapsed inside the differential, if this is the case then please get this looked at sooner rather than later as you could destroy the gearbox and propshaft witch would then cost a fortune to repair.
If on the other hand its not 4wd then it could be one of 2 things it could be that the brake shoes have collapsed and needs replacing or it could be that one of the wheel bearings have collapsed on one of the back wheels and will need replacing asap as it could seize up causing an accident and leaving you car un drivable ok.
Let me know how you get on or if you need further assistance ok
Nov 12, 2009 | 2006 Buick Rainier
Power Wheels Grave Digger - Need Replacement Wheel
I think that WalMart sells them still... maybe you could go there and ask if THEY know how to get replacement parts for it and see if they have another similar model that can take the same wheel?
Apr 25, 2009 | Toys
Metallic squeaking from Amana Dryer
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley
Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides
Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing
Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel
Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Good luck.....
Mar 28, 2009 | Amana Dryers
Dual 1228 turntable platter not spinning, the motor will not turn
If the motor is not spinnig then it is probably seized. These motors are very robust and rarely need replacement parts. Remove both the top and bottom bearings, clean shaft and bearings with solvent and then fill bearings with light machine oil. The bearings have a sponge inside which will soak up lots of oil for years of trouble free use. Once reassembled, tap the bottom bearing while the motor is spinnig and the bearings will centre themselves. If the idler and it's mechanism is working ok as well then you should feel lots of torque from the from the platter when it is spinning.
Dec 19, 2008 | Audio Players & Recorders
Where is the belt adjuster to relaese the belt from pulleys
This engine configuration probably uses an adjustable idler bearing and wheel assembly to apply tension to the serpentine belt that drives almost all the accessories. You'll need to loosen, (DO NOT REMOVE!) the hub bolt, then turn the adjusting bolt behind the wheel to provide the slack you need.
Or, did you mean the timing belt? That one has an oil-filled tensioner that requires clamp compression to collapse down the right clearance. Did that help? Let us know...accordianman
Dec 16, 2008 | 2000 Dodge Caravan
Garden Logo
285 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
