Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Brigss 14 hp singe cylinder---fuel filter runs dry, fuel lines clear, tank clear, no debris in system, have to blow into fuel tank to refill filter then it runs for 20 minutes until filter is empty again, looks like a non fuel pump unit, gravity fed carb ? in a yard man tractor. can you assist ?
  • kentforster1 Jun 30, 2009
    THANK YOU !!! I will try this tonight, great idea.
  • 57 Answers
I wold say the vent is plugged in the tank or cover try running it with the gas cover very loose and see if that helps it if it does get a new cover
Posted on Jun 29, 2009
No fuel in fuel fiter
Try draining the fuel tank completely into something gasoline proof that will allow you to see the gas. Look for any debris in the drained gas. You may also need to disconnect the fuel line and blow carburetor cleaner back through the hose and into the fuel tank. Generally there is a small screen protecting the intake to the fuel line and this may have become clogged. Try this and then put new, clean fuel back into the tank, make sure that fuel is running out of the fuel line, through the fuel filter and then connect the fuel line back to the carburetor. Hopefully you understand the inherent danger of fooling around with all of this highly flammable gasoline so take every precaution to avoid the possibility of ignition! Good luck.
Sep 16, 2014 | John Deere Garden
Gas will not flow from tank to motor while running
Everybody had a crack at this problem, another thing would check is these engines sometimes have a primary fuel filter inside the tank itself. Drain the fuel and gently blow compressed air back through fuel line towards tank then rinse the tank out with fuel, refill and try run engine again
Aug 07, 2014 | Honda 8 HP Engine
RAN OUT OF GAS, I THINK..PUT GAS IN STILL WONT START... FUEL PUMP MAYBE ?
When older vehicles are driven to the point of running out of fuel, the deposits in the tank are sucked into the line and clog the filter and the line. On a 13 year old vehicle, I'd say you probably had this happen. You may be able to clear the debris by removing the gas cap and putting a small amount of compressed air backwards through the system by removing the line that feeds your fuel rail. put the air into the line slowly and have someone listen near the tank. After a while the debris will be cleared of your lines and backflushed through the filter. Gas should flow freely after that. Change your fuel filter asap though after it's running again. Or yes, it could be the pump.
Nov 14, 2010 | 1997 Jeep Grand Cherokee
I put petrol in a 2.5 liter desil turbo delica mitsi van 95 wat do i do to fix it
drain gas tank, fuel lines. replace fuel filter. refill gas tank with diesel. bleed fuel lines and fill fuel filter with clean diesel.
Nov 10, 2010 | 1990 Mitsubishi Minivan
MTD 5hp. Starting and running only while I spray
Remove the fuel line from the carb. Drain fuel tank and blow thru fuel line until clear. If you use compressed air be very careful to use LOW pressure. I just use my mouth. reinstall fuel line replace the fuel filter, add a new spark plug for good measure and refill gas tank
You should be chipping away right soon!
Mar 04, 2010 | Garden
Mower engine cuts out at exactly 1/2 full tank of gas
When that happens loosen the fuel cap and see if it stays running. If this is a gravity feed system make sure you have the correct fuel filter on it,the clear paper filters can allow vapor lock to happen,put the small briggs and stratton filter in it,which has a small chamber and a stainless screen.Also make sure there is no excess fuel line that would cause a dip or a high spot for a vapor lock to occur.
Aug 05, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
14 hp briggs runs fuel filter dry every 15 minutes. have to blow into fuel tank to fill filter up then it runs for a while again. whats up ?
Sounds like the tank is not venting. Try leaving the cap a little loose and see if it stays running. If it does, either the vent for the tank or a vented gas cap is plugged
Jun 26, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Water in the fuel tank of my Zodiac dinghy with Yamaha 2001 50 HP
I'd add a little dry gas to **** up any remaining water and give it a shot
May 26, 2009 | Sport & Outdoor - Others
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
434 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
