My kenmore model 110.24732300 washer needs a new lid switch.how do i access the switch? thanks, Lonnie
  • 5,911 Answers
The following link explains how to access and replace a lid switch on a Kenmore:
http://www.fixya.com/support/r385198-replacing_lid_switch
If you have any questions along the way, please let me know. I hope this helps you.
Posted on Jun 29, 2009
How do you open the washer to access the lid switch on a model 22422 Kenmore machine?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Feb 16, 2011 | Kenmore 22422 Top Load Washer
I have a series 90 Kenmore top loading washer model number 110.26912691. At the end of the wash cyle it began to make a loud buzzing noise. I've tried to reset, the water will fill, but the washer...
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11026912691/0582/0153200?pathTaken=
Initial suggestion is a Lid Switch:
Dec 14, 2010 | Kenmore 15864/15862 Top Load Washer
My Kenmore washer will fill with water and oscilate, then nothingf won't spin or drain. I 'm guessing that it is the lid switch , ( relay switch ) ?? Mod # 110.94518201 serial # VLG 1601709 can this...
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11094518201/0582/0153200?pathTaken=
Look at the diagrams for the cabinet and you'll see a list of component parts (Lid Switch) with the Sears part numbers (the manufacturer authorized substitute numbers are Whirlpool) and the Sears price.
Dec 03, 2010 | Washing Machines
I need the installations instructions for a Kenmore washer Mod 11020882990 for the lid switch Stella
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11020882990/0582/0153200?pathTaken=
Oct 26, 2010 | Kenmore Washing Machines
I have a Kenmore Elite model 110.92972100 that needs a new lid switch on the washer door cover. What is involved in replacing and how easy or dificult is it to do by a homeowner?
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.92972100&pathTaken=partSearch
I'd try to bypass the Lid Switch to verify that it's bad by releasing the Console and jumping the two outermost pins on the switch.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using a short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
An easy replacement and much less expensive than having a "repair person" do it.
Jun 10, 2010 | Kenmore Washing Machines
How do I acces the lid switch on my kenmore washer
The following link explains step-by-step how to access and/or replace the lid switch on a Kenmore top loader:
Most lid switches are located under the right hand side of the top panel. Some, are located adjacent to either lid hinge. In any case, you still need to remove the washer exterior case to access it. The switch is held in place with a couple of mounting screws with a ground wire attached. This is a very simple repair, but if you experience any difficutlies please let me know. I hop this helps you.
Nov 27, 2009 | Kenmore 24032\24036 Top Load Washer
I HAVE A KENMORE WASHER MODEL 110.92284100 THAT
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.92284100
Go to the section on the Sears site for the Top and Cabinet parts and you should see #11 Lid Switch.
See the following on how to gain access to the console and how to remove the cabinet
If you un-plug the washer and pop off the end caps, you should see a screw under each endcap.
Remove the screws and the console should tilt backward. Unplug the lid switch from the console.
Using a screwdriver, snap off the clips holding the cabinet on, tilt it forward and it should come.
You should have access to the lid switch with the cabinet off and the console tilted backward.
Oct 23, 2009 | Kenmore Washing Machines
Washer will not spin sometimes/ Safety switch broken and I need to lift the lid to install new switch. Any suggestions?
If you are talking about replacing the lid switch, the following link explains how to remove the washer case to access:
The intermittent spin cycle problem is generally a clue that the lid switch may be malfunctioning in some way. If you've already diagnosed this to be your problem, then the link I provided will give you the necessary guidance to complete this repair. If you have any questions along the way, please let me know. I hope this is helpful to you.
Jun 03, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Need a diagram for a lid switch
Hello jafarrell
What is the exact model # ?
This was the part number!!
You said, you need a diagram of the Kenmore top loading washer, model 20432 lid switch.
This is a Kenmore part # you supplied, so here is where you can get it from Kenmore.
Part # 20432 lid switch as you supplied in our communications!.
http://www.searspartsdirect.com/partsdirect/retrievePartActionHome!search.action?productGroup=N%2FA&partNumber=20432&pop=flush
Thank you for using Fixya.
Huuum
Please remember to leave a rating
Sep 18, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
285 people viewed this question
Top Washing Machines Experts
