Question about Mitsubishi WD-52525 52" Rear Projection HDTV
My picture has veritical lines all through it.
My screen has vertical lines going up and down. kinda like an old vertical hold on old tv's. it is a 50 inch projection.
  • 64 Answers
Change the input to something else...like a DVD. Is it still there? If not, you have a signal problem either outside the tv..or perhaps a bad tuner. Do you have a computer near the tv? Or other high tech device near the unit? Try turning off any hi-tech devices in the house and check to be sure the connections are good to the tv and/or cable or satellite box.
Posted on Aug 01, 2009
Vertical white lines appear on the screen. Samsung provides the following information but doesn't say what circuitry they are referring to. Samsung says: DLP TV: I Have Vertical White Lines...
That answer I agree makes no sense.
Most of these sets have NO vertical hold and if did it will not cause the lines.
A brief educated guess:
Set has a main board that communicates and controls the screen--tests for that are not simple (checking waveforms with a scope and signal generator).
The model indicated here is a DLP that uses a lamp (let me know if model listed is not the one you have).
In DLP sets aside from main/digital board you also have a optical light engine---it processes all signal in and out to the screen.
Optical engines do fail and cause some simple and some complicated picture issues.
Some will even cause the set to "lock up" with a picture or strange looking screen---clue to this is you have to shut the set off by pulling the power cord.
The set may be old enough they do not really want to help you or even talk about it.
May 22, 2012 | Samsung HL-S6187W 61 in. HDTV
Screen black no sound or picture with line in center
this is a common problem,the vertical hold has been damaged.dont leave the teli. on,the white line will burn the middle of the screen and leave a black mark. You need a new integrated circuit(i.c.) for vertical hold.
Mar 17, 2009 | Televison & Video
TV screen bouncing up and down
look for the horizontal hold.
Jan 26, 2009 | Akai PDP4206EA Television
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Vertical line in the middle
not the picture tube; vertical failure. Vertical IC and probably capacitor that caused it to faill. In some cases just resoldering veritical IC pin connections
Jun 28, 2008 | Televison & Video
10 yr old emerson tv
The problem you are having is a vertical deflection problem. The screen is being compressed to a thin white line. It's probably a defective vertical output module or transistor. This part is not too expensive. Less likely would be a vertical deflection coil, which would be more expensive because its usually glued to the picture tube and harder to replace. You'll need to take your set to service center to have it serviced.
Good Luck!
- Jim
Feb 08, 2008 | Televison & Video
Visual
The same is true for rear projection. There may be an adjustment for vertical hold in a hole in the back of the cabinet.
Oct 06, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Horizontal line in my TV.
"Guest" obviously has no idea what he is talking about. There is no such thing as "frame section" and if the vertical IC, ramp generator or vertical hold circuits were bad, you would have no vertical at all. If you mean that there are thin white lines at the top 3 inches of the picture, and the top of the picture seems folded back on itself, it means that the pump-up capacitor is going bad in the vertical output circuit. This is a very easy thing to correct but should be done by a qualified tech.
Sep 01, 2007 | Televison & Video
Pioneer projection TV vertical lines on screen
do you have full picture and did this set have any faults before this,possible image burn on crts.from previous horizontal fault.
Aug 17, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
79 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
