Power door lock mechanisms required periodic lubrication to work correctly. Without periodic lubrication, the mechanisms stick and, eventually, the lock solenoid will fail and require replacement. As a rule, the power lock mechanisms and power window regulators should be lubricated every two to three years.
Begin by removing the door panel and lubricating all points of the lock mechanism, including the solenoid plunger. If that does not correct the condition, look for broken parts and mechanical obstructions. Manually move the solenoid plunger to make sure that the mechanism is not seized. If the mechanism will not move, detach the mechanism from the actuator solenoid and see if the solenoid itself has seized.
Check that the lock solenoid is receiving 12V when the LOCK/UNLOCK button is actuated. If not, trace down the electrical fault. If the mechanism moves freely, and there is voltage at the connector when the switch is actuated, the solenoid has burned out and should be replaced.
Passenger front door lock switch
LH rear door lock switch
RH rear door lock switch
LH middle door lock switch (w/ V4U)
RH middle door lock switch (w/ V4U)
Driver door switch assembly (DDSA)
Driver door module (DDM)
Passenger front door module (PDM)
LH rear door module (LRDM)
RH rear door module (RRDM)
Left middle door module (LMDM) (w/ V4U)
Right middle door module (RMDM) (w/ V4U)
Driver door lock actuator
Passenger front door lock actuator
LH rear door lock actuator
RH rear door lock actuator
LH middle door lock actuator (w/V4U)
RH middle door lock actuator (w/ V4U)
Driver door cylinder unlock switch
Rear integration module (RIM)
DRVMDL fuse (10-amp)
PASS MDL fuse (10-amp)
RRDR MDL fuse (10-amp)
Class 2 serial data link
http://technoanswers.blogspot.com/2012/01/after-alternator-failure-keyless-keypad.html
Remote will not unlock Rear door ?
http://schematicsdiagram.blogspot.com/2011/12/remote-will-not-unlock-rear-door-on-gmc.html
Door locks or windows not working on car?
http://schematicsdiagram.blogspot.com/2011/07/door-locks-or-windows-not-working-on.html
Car door will not close?
http://howtobyme.blogspot.com/2011/11/car-door-will-not-close.html
All power door locks not working on?
http://howtobyme.blogspot.com/2011/11/all-power-door-locks-not-working-on_14.html
Repairing car Door lock Actuator?
http://howtobyme.blogspot.com/2011/11/repairing-car-door-lock-actuator.html
How to Access car door panel?
http://howtobyme.blogspot.com/2011/11/how-to-access-car-door-panel.html
Vehicle door panel components?
http://howtobyme.blogspot.com/2011/11/vehicle-door-panel-components.html
----------Front Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/front-door-dis-assembly-diagram-for.html
Rear Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/rear-door-dis-assembly-diagram-for.html
How to test Power door locks?
http://repairhelpcenter.blogspot.in/2012/02/how-to-test-power-door-locks.html
--------This will help.Thanks.
For
Doors not getting open with remote or key problem,there are help
links provided below.Click the link below to go through its
procedure and troubleshoot the problem:----
drivers side front door will not open from
inside or outside?
http://technoanswers.blogspot.com/2012/01/ford-f-350-crew-cab-drivers-side-front.html
Car door will
not close?
All power door
locks not working ?
Repairing car
Door lock Actuator?
Truck Door will not close?
http://schematicsdiagram.blogspot.com/2011/12/ford-truck-door-will-not-close.html
Where is Cars Door control
Module located?
http://schematicsdiagram.blogspot.com/2011/12/where-is-cars-door-control-module.html
Power door locks not
working?
http://schematicsdiagram.blogspot.com/2011/12/power-door-locks-not-working.html
Door ajar light stays on?
http://technoanswers.blogspot.com/2012/01/door-ajar-light-stays-on.html
Door locks not working?
http://technoanswers.blogspot.com/2012/01/door-locks-not-working-on-ford-explorer.html
Doors will not open with
Remote?
http://schematicsdiagram.blogspot.in/2012/02/lexus-doors-will-not-open-with-remote.html
How to replace
Door Hatch ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-hatch-on-acura-integra.html
How to remove Doors?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-doors-on-acura-integra.html
How to Replace Doors?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-doors-on-audi-a4-and-vw.html
Remote will
not unlock Rear door?
This will help.
Thanks.
For
inside or outside?
Car door will
not close?
All power door
locks not working ?
Repairing car
Door lock Actuator?
Module located?
working?
Remote?
How to replace
Door Hatch ?
Remote will
This will help.
Thanks.
For
inside or outside?
Car door will
not close?
All power door
locks not working ?
Repairing car
Door lock Actuator?
Module located?
working?
Remote?
How to replace
Door Hatch ?
Remote will
This will help.
Thanks.
For
inside or outside?
Car door will
not close?
All power door
locks not working ?
Repairing car
Door lock Actuator?
Module located?
working?
Remote?
How to replace
Door Hatch ?
Remote will
This will help.
Thanks.
For
inside or outside?
Car door will
not close?
All power door
locks not working ?
Repairing car
Door lock Actuator?
Module located?
working?
Remote?
How to replace
Door Hatch ?
Remote will
This will help.
Thanks.
