Question about Dryers
I have a Roper REL4636BW dryer. It will not start. The timer runs and the on off switch tests ok, and the door switch works also
  • 5,911 Answers
The first step in troubleshooting would be to unplug the dryer and remove the cover on the terminal block. This is where the dryer power cord is installed. Plug the dryer back in and then take a voltage reading across the two hot (RED and BLACK) wires on the AC Voltage scale. You should read about 220-240VAC if good. If the voltage is bad at the terminal block, unplug the dryer again and check the wall receptacle across the LEFT and RIGHT slots. If good at the receptacle, but bad at the terminal block, you have a bad power cord. If bad in both places, you have an electrical problem with the receptacle of distribution source.
Now...barring a defective drive motor, improper source voltage at the wall receptacle, or defective power cord, the most common cause of a dryer that will not run is a blown Thermal Fuse.
The Thermal Fuse is located on the air blower fan housing in the back of the dryer. It is a small white plastic component with two wires attached to it. To access, simply remove the back panel of the dryer. The Thermal Fuse will be located on the blower fan housing on the lower left hand side of the dryer. Make sure the dryer is unplugged and disconnect the wires before making any resistance checks. The fuse should read about zero ohms if good. If bad, replace it. You can purchase replacements on line at searspartsdirect.com, appliancepartspros.com, or repairclinic.com. Just use your model number for your search criteria. The Thermal Fuse is listed under the "Bulkhead" heading as item number 8.
NOTE: If the Thermal Fuse is blown, it usually blows for a reason. Verify all your ventilation ducting and blower fan assembly is clear of any clogs. Failure to do so, will result in repeated failures of any components you may replace.
If you have any questions, please let me know. I hope this helps you.
Posted on Jun 29, 2009
My roper dryer wont start
Sid you test the thermal limiter fuse in line to the dryer motor.
Oct 06, 2017 | Computers & Internet
Dryer continuously runs- and starts when you close door
ok, make sure to test the door pressure switch for its operational value. if the switch is in good condition and it doesn't appear to be faulty and, the wires are connected firmly, replace the timer/control. In most cases,your door switch will need to be replaced. these switches will develop shorts overtime.
Jun 07, 2009 | Maytag Dryers
Dryer will not start
if you are sure that your door switch is ok than you have a bad motor
but double check the door switch  the door switch has two wires take them off and connect them together if that makes the dryer work its a bad doorswitch if it doesnt help you have a bad motor
Jun 07, 2009 | Roper RES7648E Dryer
Drum will not turn
ok power to the motor but is motor spinning? also check pully make sure its secured to motor shaft.
Apr 14, 2009 | Dryers
Roper electric dryer replaced timer
check the door switch if that is bad it will not start if that is ok there is a white fuse on the blower houseing in the back check it with an ohms meter
Mar 16, 2009 | Roper REX4634KQ Electric Dryer
Dryer won't start
Dryer does not work at all
Hope this may help;
DON'T FORGET TO RATE:
Aug 22, 2008 | Roper REX4634KQ Electric Dryer
Roper dryer won't shut off
The timer motor isn't moving the timer. You'll need to replace the timer. Turning the timer **** to off should stop the machine.
Exception: If the shutting the door automatically starts the motor, then the start switch/relay is probably shorted.
Mar 10, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
74 people viewed this question
Top Dryers Experts
