Question about Gateway HD2200 LCD Monitor
Same There is just something wrong with the backlighting. I have the same exact problem as everyone else except if i turn my monitor on and off about 20 times it will eventually work untill i turn it off for more than 2 or 3 hours. If you turn it on and you see the backlight and then everything blanks out, you can look very closly at your monitor and see your login screen or desktop or whatever you had up. I was able to logg in and open progames, but still completely unusable as i had to sit 2 inches from the screen and squit at my monitor
  • 105 Answers
Hi There
If you feel comfortable to take the back off and check for loose connections or dry joints if you dont understand what im saying you may be better finding a local techie, tv repairman or radio ham to have a quick look
Regards AL
Posted on Jun 29, 2009
Occasional odd coloring and backlight flickering
Please check it monitor color adjust button. If ok then you check it monitor cable if change possible then change it or power cable also proper connect. If not solved contact Good Monitor technician.
Thanks.
Feb 17, 2014 | Apple Cinema Display 23" HD Monitor
Benq fp222w monitor switches on but black screen no backlight what parts need replacing to fix pls
If there's no backlighting but you can see the image anyway, then your monitor might have a defective inverter. The inverter is responsible for providing power to the backlight, so if it is defective, the light won't work and it might need to be replaced.
An LCD inverter looks something like this:
You can easily find inverters for sale online, but be careful: you have to find the exact same inverter for your monitor, or it may not work.
Mar 02, 2011 | BenQ FP222W LCD Monitor
Using my hanspree jm01-22 through vga cable alls fine except lack of brightness on the screen,ive turned the brightness and contrast up on the monitor and its still fairly dark,appreciate any help
It does sound like it had logic issue that seding the dimming command to the backlight inverter circuits to dim down the lamps. Yoy may have to look inside.
Please look here to see what ususlly goes wrong with the monitors: http://s807.photobucket.com/home/budm/allalbums
Mar 31, 2010 | Hannspree 19" Widescreen LCD Flat Panel...
My monitor takes quite a while to light up when I turn my computer on.....It is fine once it lights up....but it takes so long...Is something wrong with it
it could be the backlight system is taking its time to turn on
you could try and replace it but to be honest i dont think you will find the exact one for your monitor
Jan 15, 2010 | Smart Modular SV3170A
Screen turns on and then goes away
This is most likely a backlight related problem. If the power light stays on after the screen "goes away", then it is most likely one of two problems:
1) Something is wrong with your power/inverter board. Most likely you will need to replace bulging or bad capacitors on the power board. They will like have voltages between 16-25V and capacitances of 470-1000uF. You will need to disassemble the monitor, remove its power board, and inspect it. If you notice bad capacitors, you will need to desolder them from the board and solder on new compatible ones. This should solve the problem.
OR
2) If replacing the capacitors doesn't solve the problem, the problem may be with your backlights themselves. If you are able to test them, that would be best. Replacing them is a pain as you will have to disassemble the LCD panel itself to get them out. You will then have to replace them with compatible backlights of the same size, which you can salvage from similarly sized broken monitors.
Keep in mind that the suggested actions above are for individuals with some experiences in soldering and repairing circuit boards or LCDs. Also be sure to wear anti-static gloves or wristband and keep the monitor unplugged when performing the above stated actions (except of course when testing voltages).
Jan 12, 2010 | Westinghouse L1928NV Monitor
I'm using a Samsung T240HDTV. The screen goes to very dark frequently so that I can hardly see the image, after I turn it on. I guess may be something wrong with the backlight. Can somebody help me out...
The problem is probably not with the backlight, rather the inverter that powers the backlight. If you open the back of the lcd so that you can see the circuit board you might see several bulging, or blown capacitors. This is a common problem with lcds. If you replace the capacitors the problem should go away.
Sep 11, 2009 | Samsung SyncMaster T240HD 24" TFT LCD...
Backlight out on Philips 200WB monitor
It sounds like the inverter is out on the power supply for the backlights. If you can open the monitor and take a few pictures of the boards and send them to tech@ccl-la.com I will try to cross reference the boards and give you a repair solution.
Buddy
Corporate Computer
www.ccl-la.com
Sep 05, 2009 | Philips 200WB7 (Silver) Monitor
Backlight on Acer Aspire 7720-6395 gone instantly
bud there is a chip in the back of the monitor which enables the back light it a fix only a pro ca do its cheap enough but monitors now are fairly cheap so i look into repair but if not then sry a new one is needed
Jul 26, 2009 | Acer Aspire 7720-6569 Notebook
Hello. I have a Dell Inspirion 5100 Laptop that runs XP. The laptop was overheating and as a result, would shut off randomly. So, I took the keyboard off and cleaned the heatsink of all dust and dirt. ...
if the screen's backlight comes on then you may have damaged something on the motherboard such as the video card/adapter. if the backlight on the monitor doesnt come up it should just be a connection issue or the monitor itself is bad and you need to order the oem part and install it.
Apr 25, 2009 | Computers & Internet
Problem with the acer al1916w
Sounds like the backlight or inverter might need replaced. It's pretty common on LCD monitors. It's best to call a local repair shop to do that unless you know what you're doing.
Jul 31, 2007 | Acer AL1916W 19" LCD Monitor
Gateway HD2200 LCD Monitor Logo
139 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
