I had a Niveda graphics card installed in my Dimensions 3000 in order to be able to run the Sims 3. Over the past month it would crash during game play and the only way to recover the computer was to turn it off manually. Sometimes the colors would go completely crazy and the same thing: turn off the computer. I tried to fix it and it seemed to be working fine, but now when I try to turn the computer on, it goes from the boot up screen straight to a black screen. I can see the mouse and I can change the monitor settings, but it won't get past this.
try re-installing your windows to remove some malicious software if does . or try restore your windows to a early state it working find try using your recovery disc or recovery diskette to recover your lost system setting to back into early state you use find no problem. Hope it help you out ^_^
Was this helpful?
Yes
No
Popular Solutions for ATI RADEON HD 2400 PRO Graphic
When my ATI drivers are installed on my computer to get HD signal the color Red stops coming up....
(More)
When my ATI drivers are installed on my computer to get HD signal the color Red stops coming up. When the ATI drivers are uninstalled the VGA signal works and all the colors come through but no longer get HD signal to monitor. Have downloaded all the updateds for both the Acer Flat Panel monitor. And the latest updates to the Raedon X4350 that i just purchased a week ago.
nie mogä? zainstalowaä? programu do karty graficznej ATI his radeon 9550 brakuje...
(More)
nie mogä? zainstalowaä? programu do karty graficznej ATI his radeon 9550 brakuje mi VGA card
I have the exact same problem as yours. I tried to so many solution, it does work sometime. I tried...
(More)
I have the exact same problem as yours. I tried to so many solution, it does work sometime. I tried to plug in the default VGA cable to the on board graphic, it works perfectly. But when I swap back to the Radeon 2400 from the DVI cable, it happens again sometimes. I would like to resolve this problem, it is so frustrating.
ati radeon 4670 video card is stating issues with sketchup pro 7. What issues is the software having...
(More)
ati radeon 4670 video card is stating issues with sketchup pro 7. What issues is the software having with this graphics card and can it be fixed. This is the best video card that this studio xps 16 has.
