Anybody changed one?
Removal is simple if you have access to an impact wrench so you can the center retaining bolt.
When re-installing anti-seize compound needs to used on the crankshaft so the new clutch assembly doesn't seize on the shaft. To tighten the center bolt you must hold the flywheel in place by blocking it. This center bolt must be torqued to 45-55 ft fts. Also the new pto clutch needs burnishing in. Most new clutches come with instruction on this procedure.
SOURCE: how do you pull hub off & change axil seal on cub cadet zero turn mower
Sound its rusted to axle. After remove e-clip from axle use WD-40 on both sides of hub. There small key goes in hub to keep wheel from turning on axle. The WD-40 should work. I've use a hammer on sides of hub not the tire. There spilt bushing on inside of hub, you need break loose. Back and forth works most of time.
SOURCE: What would cause a Cub Cadet Zero Turn Mower to not steer to the left?
check the linkage for the pumps
SOURCE: cub cadet i1046 will not turn sharp right
check the lever stops make sure there not out of adjustment
