Beep on magic jack as well as static and cut out
I was working on a bottom levl 750k down 250k up cable modem connection threough cox in orange county and I am connecting to a pc that uses a 60 foot hard cable to my router. I am getting the beep and static and eventual cut-off after say 20 minutes of talkin.
1. how do I get rid of the beep?
2. Does the proximity to my router matter?
3. will it help if I upgrade to a 12MB down and 1MB up speed?
4. Can I compare Magic jack to acn iris 3000 quality, vonage, skype, et al...?
SOURCE: Philips VOIP841 Cannot connect to Skype - Adsl problem?
Right. I've fixed it!
Here's what I did.
- You need to upgrade to the latest firmware. This is available from the Philips website. Make sure you select exactly the model of your phone. There are some instructions about how to upgrade the firmware in the manual
- Then you need to perform a reset of the system. ie: get a sharp tool and ram it into the tiny little hole on the black box which comes with the phone. If you don't do this after upgrading, it doesn' t work.
- One other tip is to check the firewall settings on your router allow the traffic in/out as well.
I called the Philips service center, and they were a bit useless, but they said if it doesn't work you could try taking the batteries out of the phone for 4 hours. Hmmmm... only try this if the above doesn't work!
Good luck.
Posted on Nov 12, 2007
dante777
  • 623 Answers
SOURCE: Linksys And Vonage Setup Through Comcast
I will try to make this as clear as possible, but if you have nay questions, please come back here and let me know.
You will need 4 things: 1 Surfboard Modem, Wrt54G, vonage router, computer. Put them next to each other without having plugged in anything ( no ethernet, no power cable!). Make sure that the WRT54G router is back to default settings by pressing the reset button on the back of the router for 10 seconds.
  1. Connect the power cable to the Modem. Power light on?
  2. If yes, connect the coax cable from the wall to the modem. (The one that looks like a TV cable)
  3. Connect the power cable to the router and wait until the power light is on steady.
  4. Connect your modem to the router. Plug an ethernet cable first into the modem and THEN into the WAN port (the label says "Internet") of the router.
  5. Plug an ethernet cable into one of the router LAN ports and connect it to your computer.
  6. Power on the computer.
  7. Open the Control panel and the Network Connections applet.
  8. You should see something called "Local Area Connection".
  9. Double-click on it and click the Properties button.
  10. Double-click on "Internet Protocol (TCP/IP)" and make sure both radio buttons are set to "Obtain...automatically".
  11. Close all Windows by clicking "OK".(The second one takes a moment, because it applies the settings.)
  12. In the open window choose the Support tab and you should see your IP address, your Default Gateway (192.168.1.1) and your DHCP server (192.168.1.1)
  13. Open Internet Explorer and type "192.168.1.1" in the address bar.
  14. If you have reset your router to factory defaults, leave the username blank and type "admin" in the password field.
  15. On the first page (Setup), you should set the Internet Connection Type to "DHCP", unless you get a static IP from comcast (which i doubt).
  16. Go to the Wireless tab and ensure that wireless is enabled.
  17. Go to the "Security Tab - Wireless Security" and ensure that NO security is enabled for now.
  18. Open a new browser window and see if you can open a web page. Use an address that is unlikely to be in cache - try "http;//www.mit.edu" or so.
  19. Close your browser for now and come back here later to setup your wireless security etc.
  20. Now power on your vonage router and wait until the power light comes on steadily.
  21. Connect an ethernet cable from a LAN port of the router to the WAN port of the vonage router. (Plug it into the router first!)
  22. The vonage device should blink and establish a connection (Internet light is steady on). This might take a moment, because the device is downloading the newest firmware as well.
  23. Once the vonage router is on and the lights are steady (you didn't say which vonage device you have, so I can't tell how many lights there are), plug normal telephone ( not a wireless one) into the vonage router and see if you can get a call signal.
  24. If you were successful - sit back for a moment, enjoy the triumph and treat yourself with a nice drink!
There are a couple of things you still have to do, but the main thing is done.
  1. Make sure that you can access the internet from your wireless laptop before you start changing settings.
  2. Get a manual for the router here.
  3. Go back to your router's web page and set up wireless security (don't use WEP - that is not secure enough)
  4. You will have to setup QoS (Quality of Service), in order to prioritize your VOIP traffic, so calls go through clear even when you are surfing/downloading.
  5. You can setup QoS via IP or MAC address. Use your vonage router's MAC address (you'll find that on the bottom sticker), because it creates less overhead.
  6. If you plug in anything else into your vonage router, it might be on a different subnet and might not be able to communicate with your other computers (vonage router often use 192.168.15.x as their IP address)
  7. Once you're up and running and feel familiar with the settings for your router, I would change to a different firmware, because QoS is a crucial point for VOIP and I never was really satisfied with the Linksys firmware. I use tomato, for the simple reason that I was afraid of other more complicated firmware and you can always go back to Linksys, of you don't like it.
So...my fingers are bleeding now, but I hope this helped you out.
If so, please come back and let me know. Others might have a similar question.
If not, just tell me where you got stuck and we will go from there. According to the movie 'Galaxy Quest':
"Never give up, never surrender!"
Posted on Jan 04, 2009
compucure
  • 61 Answers
SOURCE: Belkin N1 wireless network not working
It might be an idea to upgrade the firmware which can be downloaded from manufacturers' website
Posted on Mar 20, 2009
dante777
  • 623 Answers
SOURCE: How to connect Wireless router to Cabel Modem and Vonage Modem?
First of all: it would be good to know which devices you are using. This would help to be more specific.
But anyways:
  1. Connect a normal Ethernet cable from your DSL or Cable modem to the Internet (or WAN) port of your vonage router.
  2. Then connect another Ethernet cable from one of theLAN ports of the vonage device to the Internet (or WAN) port of your Linksys (The one that is separated from the 4 LAN ports.)
  3. Make sure that the Linksys is set to DHCP (Dynamic IP Address), soit can get it's IP address from the vonage router! (Look at your manual. If you don't have one, you can get it here. Choose the right version number - you can find that on a sticker at the bottom of the router - and download the user guide)
  4. Connect your computer to one of the LAN ports on the Linksys.
If you have any more questions or this desciption is not clear to you,just come back here and leave a comment - I'm happy to help.
Posted on May 23, 2009
FixinFax
  • 3085 Answers
SOURCE: Problem faxing using magic jack
It won't help. Magic Jack is DIGITAL your fax machine is ANALOG
Posted on Jun 04, 2009
Connect magic jack
WHAT MAGIC JACK DO YOU HAVE IF YOU HAVE THE PLUS TAKE THE MODEM PLUG INTO THE MODEM AND TAKE THE OTHER END AND PLUG INTO THE ADAPTER THEN TAKE THE PHONE PLUG AND PLUG IT INTO THE PHONE ADAPTER AND THE OTHER PART INTO THE PHONE
Feb 01, 2014 | D-Link Dlink Dir-615 Cable/dsl Router...
Magicjack doesn't always work right sometimes the phone works , sometimes I get an error 3002 message when I try to call out.
Actiontech what, they many vast models, and routers, and mix.
what are you exact connections here>
NO PC stated, HP model number, this is HP forum. so.....what?
no OS stated, opr. system , windows WHAT?
No modem models stated.
No ISP service stated,
what ISP, what service,? DSL> must I GUESS that?
My guess is not DSL no land line but it is possible to buy DSL
with Landline, disabled, I did for years.
or cable modem, ? uses COAX ! not 2wire twisted like DSL.
or are you doing the MAGIC jack , with NO COMPUTER owned
yes?
The magic jack does not plugin to any modem ethernet port
ever. its usb.
t
Broadband, high-speed internet, cable internet, DSL - WiFi, Fios fiber. and more , dial up? nah you dont have LAND LINE./
error codes,. the first page in the manual states !
Contact your Internet service provider to verify your modem allows more than one device to access the Internet if you receive error 3002 when trying to use MagicJack Plus. Some modems and modem/routers-in-one may not be compatible for use with MagicJack Plus if multiple devices are connected to your network.
We dont know what ISP you have nor the connection type
cable tv modem, DSL, FIOS what?
nor the modem you have , you never said,
this is far more complex
its not magic at all,
fire walls set wrong
ISP blocks you, at your mixed, router and modem
using the routers, USB port is a FAIL.
if you want great help answer what you have and what is connected
in details.
the MAGIC jack as 3 ways to connect,
USB or ethernet.?
Jun 11, 2017 | HP Computers & Internet
I run 3 computers connected to the internet using the Linksys EtherFast EZXS55W 5x10/100 switch. Switch is connected to COX cable broadband. Any issues with "crashing" on this switch? Seems...
Hi, I would recommend downloading the latest firmware for this device and then se if your "crashing" goes away.
If you plug directly into the cox modem do you have problems?
If that doesn't work I would replace the Cat 5e network cable from the switch to the cox modem.
If that doesn't work replace the coax cable from the cox modem.
If you continue to have issues replace the switch.
Dec 02, 2010 | Linksys EtherFast EZXS55W 5x10/100 Mbps...
Cox says my SB5120 is resetting 12 pulse times a
May be firmware get corrupted due to power-cut or an excess voltage or surge problem.
At times when there is thunder-storm a lot of excess volatge is generated on the phone wire which is link down to the modem
Ok
try to download recent firmware from manufacturer and see if it can be updated.
Cheers
Uttam
Jan 14, 2010 | Arris SURFboard SB5120 Modem
We re booted the computer and have to use a usb
Not sure what the problem is, but from what i am reading i am suprised that anything worked at all. A modem jack in your computer is for telephone lines, and the cable modem needs a cat 5 network cable as well as a ethernet card attatched to your computer. ethernet card in your computer cat5 cable runs from the card to the cable modem. Magic jack requires a usb connection as well as a broadband connection to work.
Dec 01, 2009 | Acer Computers & Internet
Can I use 2WIRE 2701HG-B router in COX internet connection
No. A router has 2 main interface types WAN (for the internet connection side, and LAN (for the home network side) the 'LAN' side often has up to 4 ports and wireless connectivity for the home network.
The most common routers available at electronics retail use a CAT-5 connection for the WAN ports and the LAN ports. Your DSL modem/router uses a phone line input for it's WAN port, which uses a signal type that is incompatible with the cable modem output.
If COX doesn't offer a router with the cable modem package, you can go and purchase and common brand of home networking router, and attach it to the output of the cable modem.
Feb 28, 2009 | 2wire 2700HG-B Router (2700HGB)
CAN A 2WIRE DSL ROUTER WORK WITH A CABLE INTERNET CONEECTION
The 2wire dsl modem/router cannot be use with a another cable modem , since this 2wire device is also a modem/router and its made for the DSL conenction that's why it wont work with Cox cable, the best thing that you can do is to ask Cox to give a wireless modem/router like this 2wire so you can still use the wireless connection of your computer..
Hope that helps..........
Sep 06, 2008 | 2wire (1000-400108-001) Router
Computers & Internet Logo
530 people viewed this question
David Payne
David Payne
