Question about Creative Labs Sound Blaster Live! 5.1 Sound Card
Sound card problem Dell
Im so confused.. please help.. i went to the creative website it says it cant find a driver this is the info i found on the dell site for my service tag
Assembly, Card, Planar, Dimension8200, No-Riser 1 9K795 Processor, 80532, 2.0G, 512K, 400FSB, Socket N 1 7N242 Keyboard, 104 Key, UNITED STATES..., Silitek, LC, MIDNIGHT GRAY... 1 735HE Mouse, PERSONAL SYSTEM 2..., 6P, 2 Button, Wheel 1.3A, MICROSOFT..., MIDNIGHT GRAY... 2 4T234 Rambus Inline Memory Module, 128, 400M, 64X16, ERROR CORRECTION CODE..., 4C, 40 2 9578D Card, Printed Wiring Board, Memory, Rambus In Line Memory Module, Continuity, Rambus 1 20CKU Kit, Speaker, 120V/60H, HARMAN KARDON CHAMPAIGN 2.1..., Customer Install 1 181UR Card, Multi-Media, audio, Creative-4780, FRONT AUDIO JACK... 1 1G952 Modem, V.92, Internal, Data/Fax/ Voice, Steel 2, Dimension 1 5740C CABLE..., AUXILIARY..., INTERNAL..., MODEM..., 4C 1 2P011 Compact Disk Drive, 128K, I, F5 48X, LTN-486, CHASSIS 2001... 1 4N857 Card, Graphic, 64MB, GEFORCE3TI..., DIGITAL VIDEO INTERFACE... 1 1K304 Floppy Drive1.44M, 3.5'' FORM FACTOR..., 3MD, No Bezel, TEAC..., V3, CHASSIS 2001... 1 9P519 Hard Drive, 80G, I, Half Height 7.2K, 40G/P, SEAGATE SNOWMASS... 1 6K223 Kit, Software, WKS-STE2K2, F5 OEM, English 1 3R352 Kit, Software, Overpack, WXPH CDWD, English, A02 1 7C712 Card Network, Ethernet, 10/100 CNET, REVISION... 1 8J854 Display, Cathode-Ray Tube, 17, D, E771A, Midnight Gray, Dell Americas Organization 1 7N956 CD Read/Write, 680M, I, 5.25'' FORM FACTOR..., 24X, Liteon, Revision, CHASSIS 2001... Assembly, Card, Planar, Dimension8200, No-Riser 1 9K795 Processor, 80532, 2.0G, 512K, 400FSB, Socket N 1 7N242 Keyboard, 104 Key, UNITED STATES..., Silitek, LC, MIDNIGHT GRAY... 1 735HE Mouse, PERSONAL SYSTEM 2..., 6P, 2 Button, Wheel 1.3A, MICROSOFT..., MIDNIGHT GRAY... 2 4T234 Rambus Inline Memory Module, 128, 400M, 64X16, ERROR CORRECTION CODE..., 4C, 40 2 9578D Card, Printed Wiring Board, Memory, Rambus In Line Memory Module, Continuity, Rambus 1 20CKU Kit, Speaker, 120V/60H, HARMAN KARDON CHAMPAIGN 2.1..., Customer Install 1 181UR Card, Multi-Media, audio, Creative-4780, FRONT AUDIO JACK... 1 1G952 Modem, V.92, Internal, Data/Fax/ Voice, Steel 2, Dimension 1 5740C CABLE..., AUXILIARY..., INTERNAL..., MODEM..., 4C 1 2P011 Compact Disk Drive, 128K, I, F5 48X, LTN-486, CHASSIS 2001... 1 4N857 Card, Graphic, 64MB, GEFORCE3TI..., DIGITAL VIDEO INTERFACE... 1 1K304 Floppy Drive1.44M, 3.5'' FORM FACTOR..., 3MD, No Bezel, TEAC..., V3, CHASSIS 2001... 1 9P519 Hard Drive, 80G, I, Half Height 7.2K, 40G/P, SEAGATE SNOWMASS... 1 6K223 Kit, Software, WKS-STE2K2, F5 OEM, English 1 3R352 Kit, Software, Overpack, WXPH CDWD, English, A02 1 7C712 Card Network, Ethernet, 10/100 CNET, REVISION... 1 8J854 Display, Cathode-Ray Tube, 17, D, E771A, Midnight Gray, Dell Americas Organization 1 7N956 CD Read/Write, 680M, I, 5.25'' FORM FACTOR..., 24X, Liteon, Revision, CHASSIS 2001...9K795 Processor, 80532, 2.0G, 512K, 400FSB, Socket N
the problem i am having is no sound and i think its a driver
  • 10 more comments
  • chays23 Jun 30, 2009
    thanks dor the reply.. i went to the site.. couldnt find a driver for creative 4780.. so i downloaded a soundblaster full version card but after install it said it would find a soundblaster card on my system
    *********couldnt find a card SB card on my system
    ok i tried that.. when it was trying to install it said no supported device found... i think this is becoming a lost cause.. but i am thankful for your help.. i hate computers or maybe they hate me
    here is what windwos media player says when i try to play a song
    Windows Media Player cannot play the file because there is a problem with your sound device. There might not be a sound device installed on your computer, it might be in use by another program, or it might not be functioning properly.
    no yellow by any of them...
    sound,video and game controllers
    -audio codecs
    -legacy audio drivers
    -legacy video capture devices
    =media control devices
    -unimodem half duplex audio driver
    -video codecs
    it is weird that when i right click i dont have the option to uninstall but on any of the other devices i do.. i even tried turning up the volume under control panel and it wont let you do that its all "greyed" out
    the sound wasnt working before i installed xp again.. i re installed it hoping it would fix it...
  • chays23 Jul 01, 2009
    problem solved thanks!
    problem solved thank you!
  • 255 Answers
Download from this link
www.lostmydrivers.com/
select sound card driver
select creative
select your model name and model no
Posted on Jun 30, 2009
  • 3 more comments
  • Mohammed Ehsanullah
    Mohammed Ehsanullah Jun 30, 2009
    download from this link
    select creative
    http://drivers.softpedia.com/get/SOUND-C...
    select
    Dell XPS M2010 Creative Labs Integrated Sound Blaster Audigy ADVANCED HD Audio Driver A02
    do this steps,,,, hope your problem will solve
    1. Right click on Mycomputer, select properties
    2. Select hardware
    3. Select Device manager
    4. double click on the sound,volume and controller
    5. if any yellow color pointed is displayed on any option then right click on the option and uninstall it
    6. then select Action from the menu bar on the top and select scan for hardware changes
    **** after doing this.. you can check the follwoing steps for trouble free ******
    7. double click system device
    8. if any yellow color pointed is displayed on any option then right click on the option and uninstall it
    9. then select Action from the menu bar on the top and select scan for hardware changes
    10. then it will start scanning your new hardware and ask for the installation drivers
    Mohammed Ehsanullah Jul 01, 2009
    try this which i send you early steps.... all the best
I am cant access driver for my sound card model ct4780 please help me to access this diver for free down load .
Go to Creative Labs website under support put in the model number and download the driver specific to your computer OS and install. It should work after that.
Aug 25, 2011 | Creative Labs CT4870 / CT4780 Sound Card
I want creative sound blaster live Ct4780 drivers
I found this on the Creative forums posted by a Creative Forum Moderator:
http://us.creative.com/support/downloads/download.asp?DriverLang=1033&searchString=LiveDrvUni-Pack%28ENG%29.exe&Image1.x=22&Image1.y=8
It says Windows 2000/XP, but it will most likely be fine for Vista too.
May 03, 2011 | Creative Labs CT4870 / CT4780 Sound Card
I want to know what driver is pciven_8086&dev_24d5subsys as it is missing & where I can locate it? Thanks
It is a sound card driver for your motherboard. May I know what model is your motherboard?
The best suggestion is to look the driver on the website of your motherboard. The support/download section.
here is a sound driver for some known brand of motherboard (other sound drivers are realtek AC97, soundmax and creative.
1. R105155.exe for Dell motherboard
Please give the brand of your motherboard so I can help your further.
Jul 21, 2010 | Compaq Creative Sound Blaster PCI 128...
Creative sound card! no sound!
Check whether you plugged in the speaker wire into the correct jack at the back of the computer (it should go into the green colored jack on the sound card).
Did you try playing a sound file? Does media player show the file as playing, but you can't hear anything? Or do you get any error? if there's any error, please mention the error.
If the sound plays but you can't hear anything, again, check the speakers are connected to the correct sound jack. Next, try connecting a pair of headphones or earphones (lower the volume before playing any sound  or music file).
If you still can't hear anything, click Start and type the command "dxdiag" in the Run box and then press the Enter key. In the dxdiag window, click the Sound tab. Check the Notes box, if it gives any error info. If your card is working, it should say 'No problems found." You can also test the sound using the "Test Directsound" button.
If you still can't hear any sound, you should check and reinstall your sound card driver manually after removing it first.
There may be other problems. For more information, check this nice blog post about sound problems.
Hope that helps.
Regards,
Raspal
Jun 14, 2010 | Creative Labs SB0400 Audigy 2 Value Var...
Under devices, it reads no drivers listed
You didn't say what model your computer was; but for Dell....start here:
http://support.dell.com/support/downloads/index.aspx
Put in your model and operating system and it should take you to a list of drivers for your machine.
Please rate me if you found this helpful.  Thanks.
Mar 08, 2010 | Dell Computers & Internet
Sound card craeative live SB0200(driver)
Hi imadnan...
Sound card craeative live SB0200 drivers can be found at driverupdate us
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Feb 02, 2010 | Creative Labs Creative Sound Blaster Live...
Sound card driver
http://drivers.softpedia.com/get/SOUND-CARD/OTHER-SOUNDCARDS/Dell-Optiplex-GX270-Creative-Audio-Driver.shtml
May 02, 2009 | Dell OptiPlex GX270 PC Desktop
Creative X-Fi Xtreme Gamer XP SP2 drivers
what the hell are you talking about, the card isn't "vista only"
Jan 25, 2008 | Creative Labs Sound Blaster X-Fi...
Creative Labs Sound Blaster Live! 5.1 Sound Card Logo
1,208 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
