Question about Dryers
RE: Roper Electric Dryer, front load
After activation and after the dryer runs for abpout 3-5 minutes, the circuit breaker pops off. Resetting the circuit breaker hasn't been successful, as the machine continues to pop off the circuit breaker after running for a few minutes. Any ideas or suggestions??
    Sergeant:
    Champion:
  • 235 Answers
You have a ground fault or short . Disconnect dryer and remove small panel that holds the cord. Check if any wires are frayed, loose or touching any other metal objects.
Posted on Jun 30, 2009
It will run good for a while on hot heat and then shuts off for abut 5 mins but it doent shut off on cold cyc
why does my roper electric dryer shut off after five or ten minutes of running fine. then wait five or ten minutes, restart and it runs fine for another five or ten minutes, and so on....
Dec 29, 2012 | Roper REX4634KQ Electric Dryer
Why does it shut off after 2 or 3 minutes
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 17, 2011 | Roper REX4634KQ Electric Dryer
The dryer heats up for a few minutes the continues to run with no heat it is a Roper dryer model number RGS7646KQ3
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 25, 2010 | Roper RES7648E Dryer
I started my dryer for 10 minutes. opened the door, put another load in to dry and my dryer does not work now. what is wrong?
might be the door switch or a wire in the front panel or some other things, here is a website that may help, Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 24, 2010 | Roper REX4634KQ Electric Dryer
I have a Roper Dryer Model REX3514PQO. The dryer
Sounds like you have a broken drum belt.
If you have to replace your drive belt and if you have a front loading machine.
First you will need to unplug your dryer from the electric.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
If the belt is not broken, then I would check to see if the timer switch is working properly, if not then you may need to replace it.
Good luck,
I hope this helps
Oct 06, 2009 | Roper REX3614KW Electric Dryer
Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
Jan 20, 2009 | Roper REX3614KW Electric Dryer
RES7648KQ0
roper dryer model # res7648kq0 will not run. but has power
Jun 14, 2008 | Roper RES7646KQ Electric Dryer
Roper Dryer
May have bad split coils .When the dryer is running for say 35-40 minutes ,are you feeling any heat if you open the door??If not ,most likely your split coils are bad.
May 21, 2008 | Roper RGX4634KQ Gas Dryer
My roper dryer stopped working
right above the door where it closes, there should be a door switch actuator, although your closing the door it might not be activating door switch.
Feb 24, 2008 | Roper REX4634KQ Electric Dryer
Roper Dryer
i have the same dryer it runs but doesnt heat and the timer wont move. its only 3 yrs old
Nov 28, 2007 | Roper REX3614KW Electric Dryer
Dryers Logo
59 people viewed this question
Top Dryers Experts
