Question about Motorola Mobility RAZR V3x Cellular Phone
V3x screen fix
I have a motorola v3x and I am attempting to replace the inside screen that has gone blank. Will I need a flex cable as well as a new screen to fix it?? Does a new oem screen usually have the flex cable with it when purchased??? Thanks...
  • 1 more comment
  • khalaf Nov 12, 2007
    yo, on my V3x which was dumed in water, i had water inside the screen,
    first to take off the screen:
    unfold your phone,
    2, see the tiny motorola logo? there is a place to put a tiny scrow driver,
    and just take it off
  • x_buyer_x Nov 14, 2007
    Thats awesome, thanks alot. Im changing my housing too... Any tips?? Thanks again....
  • sleepeatlive Dec 28, 2007
    The front screen of my motorola v3x is not working. It's a total blank. I don't remember dropping it or anything. Please help!
Guys! my fone got blocked . when i turn it on it says SIM Blocked...what do i do? then it says PIN1 UNBLOCK code:?
Posted on Apr 07, 2008
I have blank screen on my motorola razor. It lights up but no images is there anything I can do?
Hi,blank screen for Motorola phones are usually caused by the flex of the phone.
Sometimes it might appear in white screen display too.
The flex of the phone is located inside the phone, it controls the functions of the screen an also the keypads of the phone.
The flex is a thread like object that is located inside the phone. To see the flex, you will need to disassemble the phone to get to the flex of the phone.
After replacing the phone flex, your done.
Also it might be the screen of the phone. But in other to know if it's the screen, you will need to test a new flex.
You can get a replacement flex from any of the phone repair stores around you.
The screen blank might also be from the screen itself. But to confirm if it's the screen,you willneed to replace the flex first,and after replacingthe flex,if it doesn't display,then you will know that it's the screen that is damaged.
Hope it helps.
Thanks for using fixya...
May 28, 2011 | Motorola Mobility RAZR V3m Cellular Phone
My display screen has gone black.
Hi, Motorola Phones displaying blank screen is always caused by the flex of the phone. The flex of the phone controls the display of the and it makes the screen of the phone display.
The flex is a thread like object that is located inside the phone.Comes with the keypad functions too.
When you replace the flex of the phone,the display will be normal again.
Sometimes, the screen also might be the fault.The only way you can test if the screen is working is only when you have replaced the flex first.
Hope it helped.
Feel free to pass on your comment.
Jan 15, 2011 | Motorola Mobility RAZR V3
Blank screen nothing shows
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Jun 24, 2010 | Motorola Mobility RAZR V3x Cellular Phone
Blank screen
hi you got to clean ur phone curcuit board , mayb change ur flex cable, and your lcd.
May 21, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Blank or White screen on new Motorola Krzr k1 cell phone
If the phone still works, check to see if the left side of the hinge (when the phone is open and facing you) is loose. If you can wiggle the top 1/2 of the phone, the hinge is damaged, therefore damaging the flex cable that runs through it. If that is the case, replace the hinge assembly and the flex and you're good.
The K1 is no joke to take apart. Flex replacement requires full disassembly. I would recommend checking out, or to have it done professionally, less than Motorola will charge you.
Or give it a shot if you want, you need a T5 Torx and lots of patience and care.
Jul 31, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola v3xx got wet
you may have short circuited the flex cable connecting your screen to your mainboard, in this case you will have to buy a new flex cable
Apr 03, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Blank screen
this happens either when u r razr was dropped or have gotten wet...If it fell u need to remove the four screws on the screen and pry the cover off with a possibly thin knife.The flex cable is located at the top left hand side of the screen. you need to take this off and reseat it again.try powering on the phone before u close it back again to ensure that it works.If this doesn't work either your screen or flex cable is gone, then u need to check a phone repair need either a t6 or a t4 screw driver set to remove the four screws located under the the 4 rubber fillers on the inner screen.
sam !
Feb 19, 2008 | Motorola Mobility RAZR V3
Motorola v3x white screen help
get the new display for ur cell and fit it ... or try to remove the current display and reconnect it ... if it doesnt works then u buy new display ... no need to change the cell...
may it may charge aroung 200 -300 rs thats all.... just go 4 it...
Feb 06, 2008 | Motorola Mobility RAZR V3x Cellular Phone
RAZR V3x Mobile Phone
Try "hard"-booting the phone -- pull the battery out, wait at least 30 seconds, then put it back in and try to turn it on. If that doesn't work, try putting it on the charger and see if the screen lights up. If it does work while charging, go to the settings menu and look for "master clear" or "master reset"; this will reset the phone to its factory settings which can often fix problems like these.
If you can't get it to light up at all, then you'll have to contact your cell phone provider for technical support and possibly a warranty replacement.
Dec 10, 2007 | Motorola Mobility RAZR V3x Cellular Phone
Blank screen
if it is not breaked might be ur connecting cable is not working. get it replaced. reply me if u need more detail with pic
Dec 03, 2007 | Motorola Mobility RAZR V3x Cellular Phone
Motorola Mobility RAZR V3x Cellular Phone Logo
200 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
