Question about Sport & Outdoor - Others
My mower quit mowing i pull switch and my blades do not engage
  • 57 Answers
Sound like your electric pto clutch has a problem check to make sure it is getting power first remember you will have to sit on the seat with the tractor off and the key on to test
Posted on Jun 29, 2009
Pull switch that engages blades doesn't do anything..
the switch or the relay is probably bad. maybe the clutch itself is bad. need to test to see what is bad. check the wires going to the connections and the fuse to be sure they are connected good.
Aug 20, 2016 | Garden
What causes fuse to blow every time I try to engage blades?
To engage the blades is it a knob to an electric switch that you pull?
If so does the wire from the switch activate a electric clutch?
Is the wire damaged and shorted to the frame, is the clutch shorted. If you provide the brand name and model number I might be able to find a schematic for your mower.
Video shows an electric clutch but yours may be different but this should give you an idea of where to look. Riding Mower Electric PTO Clutch Won Engage When Hot Problem Fix
Oct 02, 2014 | Garden
Pto won't engage blades
ether switch bad fuse blown behind dash or pto bad if pto 300.00
Sep 12, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Cut...
Looking for the location of the clutch safety switch on an older toro commercial 11-32
Anytime your engaging blades it pulls quite a bit of juice from the battery, so you need to be absolutely sure your battery is good.
Jul 26, 2014 | Toro Garden
My mower will die everytime i engage the blades to mow
Check to see if one of your deck spindles isn't seized. Disengage the blades and turn each blade to see if its free. Sounds like either a spindle is seized or your electric clutch on the motor has a problem.
Jul 20, 2013 | Yard Man Yardman Riding Lawn Mower 38in...
Tractor quits when engaging the blades
unhook clutch and see if blades stop turnig and then try engage clutch with the switch if motor stays running bad clutch
Jun 01, 2013 | Mtd Garden
Cub Cadet 2166 series. Mower will not engage.
Unfortunately, the circuit is a little complicated - it involves the "PTO switch" (the switch you pull on to engage the mower), a "reverse switch" that senses if you've put the mower in reverse, and a relay operated by the reverse switch. The reverse switch is there to disengage the blades if you try to reverse while mowing. A failure in any of those items, or the connectors and wiring between them, will prevent the blades from engaging. Unless you want to "shotgun it" and replace parts one-by-one on a guess (which many repairmen to do save time, but at your expense) you need to use an ohmmeter or test light to trace and isolate where the failure is.
Jul 10, 2010 | Cub Cadet Garden
Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Jun 27, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
LTX1000 42" 18HP Kohler - Blowing fuse after 2-4 min mowing.
sounds as though you are on the right track
but be sure to check the wiring directly from the electric clutch on the front of the motor back to the switch
a wire could be pinched in the frame and shorting out intermittingly
look around and find those wires and move them around and look for chaffing and tightness
and what you could also do is to unhook the clutch at the connection to it at the front of the motor and engage switch and ride around and see if fuse blows and if not you may have an electric clutch issue
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blades won't engage
I have a john deere 185 was mowing and my blades Quit turning with the switch still on,any quick fix?
May 16, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Sport & Outdoor - Others Logo
118 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
