Question about Simplicity SE3 Computerized Sewing Machine
Fabric stuck in hole where bobbin is underneath
Am in middle of embroidering and the fabric is stuck in the hole where the bobbin is. How do I get the fabric unstuck? Thank you
    Genius:
  • 1,116 Answers
Turn off the machine and remove the needle.
Lift the presser foot and remove the inner hoop and then the rest of the hoop.
Move the fabric to one side and cut the threads with a seam ripper.
Open the needle plate.
Remove the bobbin and bobbin case.
Clean away any thread or lint in this area.
You should repeat the last three steps routinely as lint and thread snips can accumulate in these area and cause mis-stitching.
Replace the bobbin case, bobbin and needle plate.
Use a new needle.
Posted on Feb 20, 2010
My top tread going in the small hole to bobbin keep on breaking.it embroider normal for short periods and the break.
First, install a brand new needle. Verify that it is the correct needle and needle eye size for the thread and fabric you are sewing. (Change needles frequently. Needles are the most inexpensive sewing accessory and most the most common repair for a malfunctioning sewing machine.)
What you are experiencing sounds like the thread is shredding at the needle eye and eventually breaking. Sometimes, a top stitch needle will work better because the groove in the back of the needle shields the thread better as the needle pierces the fabric multiple times. A piece of thread can pierce the fabric over a dozen times before it forms a stitch, so friction and rough fabric will take its toll.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwiJoKX42oLNAhVWb1IKHczKD9EQFggjMAE&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q&cad=rja
All About Needles
Use only good quality threads--AVOID old thread and bargain bin threads. They are cheap and there is a reason why they are--because what they make up for in price is paid in frustration!!!! Polyester thread used to be the bane of sewing machines, but polyester thread has greatly improved and is now a favorite for experienced sewists. It is thin and strong. Threads that are fuzzy (cotton-wrapped polyester of old Coats & Clark variety) threads are not the best for your machine or project. Check out better quality threads, ie Gutermann, Superior, Sulky, Aurfil, Isacord, and multiple other brands. Make sure you are buying the correct type of thread for your project--don't use embroidery thread to sew your garment unless you want the seams to pop open while you're wearing it.
Remove the thread from your machine. ALWAYS RAISE the presser foot and then rethread from the beginning. The raised presser foot releases the tension disk so the thread will seat properly.
Check that the upper tension is set somewhere around the midway point. This is a factory standard although most machines may require some adjustments. Test the stitch on your fabric. The tension is ideal when both upper and bobbin threads meet in the middle of the fabric. If the bobbin thread shows on top of the fabric, the upper tension is too tight. If the upper thread shows on the underside of the fabric, the upper tension is too loose.
If the thread is still shredding, then there's a likelihood there is a burr or nick somewhere on the needleplate or in the bobbin/hook area. If you wrap your index finger with fine fabric (like old hosiery) and rub you finger around, you may find the burr. If it is small, you can lightly smooth it with a fine emery board. If it is a large one, you may need to replace the part.
May 30, 2016 | Sewing Machines
I have a new Brother se400. Recently, when I am embroidering, the machine is picking up the white bobbin thread and either stitching the entire design in the bobbin thread or putting colored thread in the...
Sound s like top tension too high, bobbin tension too loose, or a needle issue - dull or incorrect one for the fabric.
Change the needle, check tensions.
Have you stabilised the fabric?
Oct 15, 2013 | Brother Sewing Machines
Why are no embroidery stitches showing up, the needle moves in and out of the fabric but no stitches stay
here are some suggestions, if the suggestions don't help then the
machine needs to be checked to see if there is a adjustment or
timing problem
1. try changing the needle
2. try rethreading the machine top and bobbin
3. make sure the bobbin is turned the right way in the bobbin
case
Jan 18, 2013 | Brother PE770 Computerized Sewing Machine
The top thread on my Janome 300E is getting caught in the bobbin. It starts bunching up on the back of the fabric that I am trying to embroider and it gets stuck. When I pull it off all the top thread is...
If your thread is getting caught underneath it's usually the UPPER thread is threaded wrong or not correctly through the tension discs. This can also happen if you're using Sticky Back stabilizer. Make sure you have a new needle in case there's a burr on the old one which can also cause this problem.
Aug 22, 2010 | Janome Memory Craft 3000
I have the futura ce-100. When embroidering it
This annoys the heck out of me, cause it happens a lot more than it should. There can be some valid reasons as to why it happens, though.
Your top thread could be broken or about to break; your bobbin thread could be broken, about to break or empty/about to become empty and is loose around the bobbin; you could have a birds' nest (a mass of thread just under the fabric/presser foot and/or within the feed dog and bobbin) forming and causing a jam; or it could be your Futura having a little bit of a hissy fit. Obviously, if you've checked for broken thread you need to move on. Check for a birds' nest by removing the fabric and clip your threads. If you find one, clear it, rethread your bobbin and begin sewing again. If there's no birds' nest, then place the fabric back in and try sewing/embroidering again. If the machine acts up again, I recommend removing the fabric/hoop, rethreading your top and bobbin threads, replacing fabric/hoop and resuming where you left off. If the machine still gives you trouble, try hitting the start button for a couple of times and seeing if the problem doesn't simply resolve itself. When you're embroidering areas that have a few small, short stitches only, the machine seems to act up a little and then behaves fine once you bypass the area. Be sure to take all of the other steps first, though, because a birds' nest will RUIN a beautiful seam or embroidery.
Mar 22, 2010 | Singer CE-100 Futura Computerized Sewing...
Sir I am owning a Janome Memory Craft 10001 but recently it's not working properly in ordinary sewing mode the top side of the fabric the stitch looks okay but underneath it is loose and while embroidering...
Usually If the underneath is loose it is the top tension that is the problem. If it is the top stitching that is loose it is the bottom tension. Hope this helps.
Jan 24, 2010 | Sewing Machines
Bobbin thread tangling up
are you doing embroidery? if so turn off jump stitch cutting if possible. is the machine threaded correctly (pull needle thread out of machine and thread again with presser foot raised.
check for foreign matter in needle tension assembly. ensure there is sufficient needle thread tension.
the thread you see caught up underneath the fabric will be needle thread and indicates insufficient needle thread tension or something preventing the needle thread from being pulled up into the fabric (maybe a damaged bobbin case, or bobbin case position finger, or damaged needle plate hole).
goodluck,
scott
Jul 27, 2009 | Baby Lock Ellure
Singer ce350 bobbin thread on top
Be sure when you are threading the top thread that you ALWAYS RAISE the presser foot. This releases the tension disk and allows the thread to seat properly.
Have you gone back and re-tested on your test fabric? Does it work okay on the test fabric? If so, then there's a suspicion that it has something to do with the fabric, needle & thread of your project. Is your project fabric very dense, heavy... Are you using a stabilizer? A hoop--is it taut, not stretched? Make sure the fabric is not trampolining. Could be an incompatibility. The needle & thread may be having difficulty piercing the fabric. Try a different weight needle, perhaps a microtex or embroidery needle.
Mar 23, 2017 | Singer CE-100 Futura Computerized Sewing...
Simplicity SE3 Computerized Sewing Machine Logo
241 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
doylesouders
Level 1 Expert
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
