1. always a dumb question but I have forgotten this more than once so I have to ask, does it have water in the basin?
2. A common issue with keurig's I've owned has been that some finer ground coffees will clog the spray nozzle that pokes into the top of your kcup. It's kind of a pain to clean,but if you are really careful it can be done with a very small jeweler's screwdriver.
UNPLUG THE KEURIG
lift the lid and find the groove that allows water to flow from the nozzle.
VERY GENTLY run the screwdriver across that groove being careful not to damage the nozzle by vigorous scraping. DO NOT ATTEMPT TO PUT THE SCREWDRIVER OR ANYTHING ELSE INTO THE OPENING.
Replace the water in the basin and try with a new kcup.
SOURCE: The Keurig is heating up the water, yet is does
Descale, Clean out the needles with an unfolded paper clip, Take out the K cup holder and clean it out
1. Power off machine. 2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle. 3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal. 4. Reassemble KCup cradle and reinsert it back into coffee maker.
SOURCE: My keurig is not filling up the cup with water,
Here is a tip that I wrote
that will give you some things to try that will help you get your
Keurig coffee brewer working again.
Keurig
Coffee Brewer not making a full cup of Coffee
heatman101
-llllllllllll
SOURCE: My Keurig does not brew
Keurig
heatman101
';][-0
SOURCE: my Keurig b60 is spitting water into reservoir instead of kcup
I had a similar problem except there was no water going into the K-cup. I fooled around with the machine for awhile but I had no luck. Figuring I had nothing to lose, I broke out a can of air that one uses to clean computer keyboards. I sprayed the air into the nozzle that puts water back into the reservoir and air came out of the water intake hole but not the needle that puts water into the K-cup. This meant that there was a block between the the needle and the reservoir. I plugged the water intake hole with a towel and my fingers then sprayed the air into the same nozzle. All of a sudden, a large blast of water came out of the needle. The machine worked after this. Just be careful not to put your hand in front of the needle because the water might be hot. Also, unplug your machine before doing any tinkering. Hope this might help some people.
Keurig
heatman101
-llllllllllll
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Keurig
heatman101
';][-0
Keurig
heatman101
