Question about Dometic Rooftop RV Air Conditioner
Rooftop a/c not cooling as well as it used to.
I have a duo therm 13500(57915.331).each year it seems like it cools a little less.this year it is 100 degrees in my shop and i can't get it to cool down to 72 degrees.coils are clean.what could be the problem?thanks,LC
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 127 Answers
How old is this unit? In the Duo-Therm Brisk Air Models, they were notorious for a small leak in the capillary tube that runs into the evaporator part of the AC. There are two small tubes that are run together, take the top off of the evaporator coil and pull the lines apart gently. Look for noticeable signs of leaking in the area. If the lines have been looking or look like they have rubbed together for an extended period of time, you need to have someone replace the lines or buy a new air conditioner. I would price both before committing to either one. Hope this helps.
Posted on Jun 29, 2009
Is it common for a rv rooftop air conditioner to leak water on to the roof? I have a Dometic Duo-Therm unit 579,590,595 series.
All AC units create condensation from the cooling of air (cold/cool air hold less water than warm air), it is worse in areas of humid air like the Midwest for example.
May 12, 2017 | Dometic Heating & Cooling
My Duo-Therm AC on my 2001 Sandpiper Lite does not get cold in the afternoon win really starts to get warm. When it's on max the unit will barely cool and the seems to bog down fan slows down
check voltage coming in at that time also check see if air vents on faceplate open will cool that area close to get flow through unit check air temp coming out should be 20 degrees different from ambient room temp if not check fins on unit see if dirty if ok cooling unit going
Jun 20, 2016 | RVs
Duo therm rv air conditioner repair
Sounds like thermostat is failing. There is a factory set resistor that helps the thermostat keep a 2 degree accuracy. Second possibility is that you have a fan or direct airflow from the cooling system, being devirted, that is allowing the cool air hit the thermostat on the wall.
Aug 17, 2013 | Heating & Cooling
Duo Therm Fan Blows, No cool air. Worked yesterday, not today?
most likely compressor running could be capacitor, breaker,relay,or compressor it self start by checking power to unit
Aug 22, 2009 | Heating & Cooling
Indoor temp doesnt go to my punched in setting of 68 on therm
if it is around 93-97 degrees outside,thats all the cool your going to get
Jun 23, 2009 | Honeywell Programmable Thermostat Heater
How many amps does ac draw?
Im taking this is a RV Heater and Air.
Amps 14.7 cooling (at 95 degrees ambient), 12.7 Heating w/optional heat strip
Jan 20, 2009 | Dometic Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
492 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
