Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
My Jenn-Air convection oven fan will not turn off. I have rebooted the range, but there is no button that directly activates the oven fan. The fan remains on 24/7 and has been running for about 2 weeks now. Has anyone had thhis problem and knows how we can resolve this issue? Thanks
  • 126 Answers
SOURCE: JENN-AIR Oven shuts off and comes back on after several minutes
they are equiped with a heat sensor it could be a bad thermastat(sensor) or
ventalation problem
Posted on Dec 10, 2007
  • 146 Answers
SOURCE: oven panel
First try unplugging or turning off the breaker and see what happens. If that fixes it your good to go if not you probably need a control board. Some of the boards have a fuse but no one changes it as it is soldered onto the control board.
Posted on Dec 21, 2007
aborcass
  • 2651 Answers
SOURCE: I need instructions for using
heres a link explaining hte usage of probe
http://shared.whirlpoolcorp.com/assets/pdfs/literature/8113P345-60.pdf
Posted on Mar 23, 2008
aborcass
  • 2651 Answers
SOURCE: I have lost my instruction
may not be exact manual but should operate teh same, perhaps a button in diifrerent position
SOURCE: Jenn-Air Gas-Electric Grill Ranfe with Convection Oven M# SVD48600
if possible, squat down in front of the range and put your ear as close to the bottom of the control panel/top of the door when you close it. there is a small motor that pulls the door in when you use the self-cleaning function. perhaps that motor is running all the time? its quite, more of a humm. this could explain why its locking itself. other than that, my convection oven JennAir has a small fan in the back that runs when the oven is on, regular or convections mode. you can see this fan squirel cage in the back wall of the oven. if you were to pull the range out, you will notice (atleast on mine) that there is another much smaller fan on the backside of the range behind the removable metal panel. what the smaller fan is for, i have no idea. so there are two fans, plus if you have the down draft feature, thats 3 total. hope this helps somehow.
Posted on Jul 25, 2008
Cooling fan below range top goes on and stays on even when oven is off
That sure cools...
Jenn Air Oven SVD48600B continuous fan - ApplianceBlog
www.applianceblog.com/.../12231-Jenn-Air-Oven-SVD48600B-continu...
Dec 10, 2007 - 10 posts - ‎4 authors Turned the oven on to 250, and the cooling fan (not exhaust fan, not convection ...What part number would this be for our Jenn Air SVD48600B range? ... It may only be that the fan comes on and stays on when not needed. ... Caveat: the same thermometer says my Jenn-Air wall oven is also 50* below the ... Jenn-air JDS9860AAP Oven won't turn on - ApplianceBlog
Mar 24, 2013
Jenn-Air SVE47600 Downdraft Fan Not Working
Nov 30, 2010
Jenn Air Oven SVE47500B oven light and fan stay on ...
Nov 20, 2010
More results from www.applianceblog.com
Nov 21, 2015 | Jenn-Air Kitchen Ranges
Jenn air convection fan squeals (JGS8850BDS)
turn power off remove gill in oven remove fan blade now remove back panel and remove convection fan motor and wirers Now revere procedure to install new fan motor Cheers
May 05, 2012 | Jenn-Air JGS8850 Gas Kitchen Range
Jenn-Air coolimg fan problem
Good Morning!
What youre experiencing could be a result of a faulty oven temperature sensor, a faulty oven control board or relay board. Youre more than welcome to send both the main control board and relay board for evaluation. Fixyourboard will test and repair both as needed for less expensive than buying new, and include a two year warranty.
5700M662 60 Jenn Air OVEN CONTROL BOARD
May 15, 2017 | Jenn-Air JJW8230D Electric Double Oven
Error code
I have a jenn air range gas cooktop electric oven model # svd48600b the convection fan will not turn off and when you attenpt to use oven an error code F-3 appears and beeping sound what part is defective?
Aug 02, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Jun 21, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Convectin fan in Jenn Air Stove
sounds like the fan or motor is not working at all. have a technician replace it.
Mar 09, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Jenn-Air electric range
my jen-Air has a problem with it continuing to beep. Ive tried to get it to stop by pushing all the buttons. When I pust the off/cancel button it just keeps beeping. Tried the stop timer button and same thing. When I turn on either the bake or convection bake button it automatically just shuts off by itself. It is approx 10-13 years old. HELP, or please tell me to get a new one.
Jan 06, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Oven panel
Dec 19, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
442 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal De
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
