Question about JVC AV-27530 27" TV
Black box taking up over 1/2 the screen.
I have a 8-10 year old JVC TV, not sure on exact model number. There is a black box centered in the screen approximatly 1-2 inches from the very edge of the screen. The box is 21 inches across by 9 inches.whatever entertainment is actually displayed on the screen (TV/Xbox/dvds)that's not covered in the box works correctly, and when the input is changed the box dissappears for a second and then reappears. when the TV menus are open, you an see behind the box, but only through the menu box. went through all functions in settings and all remote functions... The closed caption is off. It makes watching TV impossible.
Caption box selection is on. disable caption
Posted on Jun 29, 2009
  • mike blox Jan 14, 2012
    thank you som much you the best. i was already so freaked out after just spending 300 $ on my xbox. again thanks so much.
    thanks so much greatly appreciated.
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
'Black box' appears on JVC TV screen/blocks picture
Any chance of a model number to enable accurate description?
Dec 21, 2007 | Televison & Video
Dark shaded square area in center of tv picture - how do I get rid of it? I am at mothers and she has what looks like a 36 inch tabletop JVC tube tv probably about 10 plus years old. not able to remove tv...
I have heard complaints from some of my customers, “There is a black/gray box on my television, but I can still see the picture around the edges”. This happens to all of us and is a common symptom and can be fixed very easily. If you have a black/grey box in the picture, on the older sets they would be perfectly centered on the screen, but, on some of the newer sets the black/grey box can be in different places and can be different sizes on different sets.
Most likely the Text mode is on in the Closed Caption menu.
The way you can test if it is in Closed Caption Text mode, when you change the channels, the black/ gray box will not appear right away but it will take some time to show back up. This is a very good indication that the Closed Caption “Text” mode is turned on for your television. It just needs to be turned off.
To turn off the closed caption go into your menu and turn off closed caption (CC). This will vary from manufacture to manufacture; it should be in the options menu.
I have seen on some sets like Mitsubishi puts it under the Video adjustments button. So you may have to look around for it.
You may even have a CC button on your remote, which will make it much easier. Just press the CC button until the display indicates that CC it is off.
I hope that this tip helps you and that you enjoy your televisions for years to come.
Thanks for using FixYa
asnowman
Apr 19, 2010 | Televison & Video
Lcd tv has black cloudy line from top of screen about 1 inch wide and 4-5 inch long down the screen
This problem is not just for Philips. I've found similar complaints online for JVC, and my Vizio 32" LCD has the same problem. In my case the TV is about 3 years old and has a lot of hours on it.
Oct 23, 2009 | Philips Televison & Video
Black screen on EVERY input/channel
Turn off the closed capition
Jun 19, 2009 | JVC AV-27530 27" TV
Black square appearing on tv
turn off closed captioning
Nov 29, 2008 | JVC AV-27530 27" TV
Screen stretched on JVC AV-28WT5EKS TV
There are some parts that have failed in the horizontal scan amplifier. You will have to have the set serviced by a TV service tech to determine the exact failed parts and have them replaced.
Jerry G.
Jun 27, 2008 | Televison & Video
JVC TV 27" Black line on top of screen
This is for the original problem.. Not the second post.
It's a problem in the horizontal deflection circuit. The parts will be available, but you will be in for some daignostic repairs also to find out why it failing or if it has failed on it's own.
There should be a few caps near the IC (an LA7840) that could also be causing the problem. Click the link, it will make it easier to locate the part inside.
This is the kind of repair best left to a TV tech, but get it done now and it won't cost anywhere near as much as it will later.
Apr 18, 2008 | Toshiba 42H81 42" Rear Projection...
2005 Panasonic LCD TV Model# TC-26LX20
I am also having problems with the same year and model number panasonic, it is at the repair shop now. I think it is a lemon tv. won't buy panasonics anymore. Tried all the fixes recommended by panasonic. It happens after the tv is on for longer than 1/2 hour. It happens with dvds and different hook ups. my samsung is fine on all the same connections.
Aug 16, 2007 | Panasonic TC-26LX20 26 in. HD-Ready LCD...
Top of the screen Picture Problem
sound like you have 1 or a couple of leaky/bad capacitors in the tv's vertical circuit, typically, there sould be 5 to 10 caps. in all, but you just need 1 bad one to cause your problem. good luck.
Mar 13, 2007 | JVC AV-27230 27" TV
JVC AV-27530 27" TV Logo
318 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
