Question about HP Pavilion dv5-1000us Notebook PC
Red audio mute LED remains lit, even though LED touch-control still turns speakers on/off.
    Novelist:
  • 166 Answers
Yeah i can understand. Many HP Pavilion users & compaq users are facing same problem. Its due to the reason that the XP or Vista is not properly synchronized with their sound drivers & hence not capable to controlling that LED connected internally to sound hardware.
And also few people found out that LED is totally electrically-SHORT and hence permanently on and has no control from software.
If this solution was helpful to you then please rate 100% (or FIXYA) for this solution, otherwise don't rate at all. It was my pleasure helping you.
With regards,
Shyny Saxena
Posted on Jun 29, 2009
Why don't I have volume?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Nov 27, 2015 | Sharp LC60LE640U - 60 Aquous, Full Hd...
Turn off mute
Click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers.
Click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings.
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it.
also right click on the speaker icon in the bottom toolbar (bottom of screen) you will have an array of options select either playback or recording devices then communications make sure the mute all sounds does not have a tick in the box.
Nov 26, 2013 | MSI Computers & Internet
HP Pavilion DV7-1135nr laptop internal speakers won't play
try installing proper drivers for the AUDIO CARD! the orange led only indicates the HTK HOTKEYdrivers are working properly, it does NOT says a thing about audio card drivers! so i suggest you to install proper drivers for audio playback!
Apr 05, 2013 | Computers & Internet
I have a JVC RX 554v Receiver when it's turned on I have no sound their is a mute auto light that's lit in the window....Tried changing the speaker wires with no results...
From the remote control only: Press MUTING to turn off the sound through all speakers and headphones connected. "MUTE" appears on the display and the volume turns off. To restore the sound, press MUTING again. Turning MASTER VOLUME or pressing VOLUME +/- also restores the sound.
Sep 01, 2011 | JVC RX-554V Receiver
Can noy ged moden check shows working t wireless to work ethernet works an- looking for button to turn wireless on . Lookig for actual button to turn wireless on. Do not know where it is at - Thank You
The location of the Wireless ON/OFF switch is on the right hand edge side of the Notebook. Please see image below, it is No. 8
moz-screenshot-2.pngPlease let me know if the information provided has been helpful.
11997_ov.gif 1. Easy Access Buttons (5) 2. Stereo Speakers 3. Touch Pad On/Off Button LED 4. Fixed Optical Drive 5. Touch Pad 6. Primary Battery 7. Wireless LED 8. Wireless On/Off Button 9. Battery Charging LED 10. Hard Drive Activity LED 11. System Power LED 12. Mute Lock LED 13. Volume Controls 14. Headphone 15. Audio In 16. 1394 Port 17. PC Card Slots (1) 18. RJ-11 (Modem) 19. Air Vent 20. Kensington Lock 21. Power Button LED 22. Caps Lock LED 23. Num Lock LED 24. Keypad LED
Aug 20, 2010 | HP Compaq nx9030 Notebook
I'm getting no sound through my speakers
mcdevito75 here, You can try, click on Start on your computer then on control panel, then on sound, speech, audio, make sure the mute box is un--checked and the Volunme icon in tray box is checked. Also chech speakers for good connection at the computer and check the volume control on both speakers even though some speakers have volume control on only 1 speaker.
Jun 23, 2010 | Bose Companion III Computer Speakers
The audio light is red whether the sound is muted or not
1) Try updating your sound drivers, they probably control the light. It could be a hardware issue, and if the drivers don't work, there may not be any solution for you.
2) You should go into control panel and into your sound settings. There should be a number of devices listed. One of them is your HDMI output. You need to click on it and set it to the default sound output device. When you unplug your HDMI, you may need to do this again to get your regular computer speakers working.
Jun 22, 2009 | HP Pavilion dv7-1130us laptop
Hp dv 7-1135nr speaker won't work, headphones do
I suddenly got the same problem on my dv4-1120us today.. However by updating the audio driver to this one it started working again:
ftp://ftp.hp.com/pub/softpaq/sp41501-42000/sp41616.exe
You better take a look at HP's website.. maybe you will need a slightly different driver, since your computer is not exactly the same as mine. I'm sure the sound card is the same, but better safe than sorry. good luck!
Feb 25, 2009 | HP Pavilion dv7-1132nr Notebook PC
Laptop LED Locked Mute
go to compaq.com and reinstall the hot-key software for your laptop. seems to be a bad driver, could also be bad hardware though, if it is bad hardware you may be looking for someone to take it apart to fix it. more than likely though it is a driver which can be fixed with just installing new software.
Nov 27, 2008 | HP Compaq nx6125 Notebook
"Mystery" indicator and no audio
The problem with the audio must be a problem with how the speakers are connected. You do not need to turn on the internal amplifier in this radio, it is always on. You said you connected the four speaker wires to the two speakers. You may have used the wrong wires. The front speaker wires from the radio are the white, white with black stripe for one speaker and the grey, grey with black stripe for the other front speaker. make sure each speaker you are connecting has the matching colors from the radio connected to it. meaning that one speaker will have a white wire and a white with black stripe wire, the other speaker will have the grey wire and the grey with black stripe wire. The purple and green wires should be seperated and insulated off from each other so that nothing can touch them that has any conductive surface.
The red led indicator is just for knowing that the radio is on. No other function for that. The muting for these is called "ATT" for attenuation and is located in the top left of the face.
make sure your speakers (terminals only) are not grounded to the chassis of the car, this can blow up the internal amplifier of the radio and this can result in no sound. If you can measure the voltage of the speaker wires coming out of the radio, they should measure at about 6 to 7 volts. If any one of the 8 speaker wires is not at that level, you have a blown amplifier IC in the radio. They all should measure the same give or take a few millivolts, if not the amp is bad.
Let me know if this help you at all. and a good rating would be appreciated for this free help.
Thanks,
Dave
Jun 19, 2008 | Kenwood KDC-MP528 CD Player
HP Pavilion dv5-1000us Notebook PC Logo
117 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
