Question about Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ...
How to diasemble the diverter tee
I have the replacement for the diverter tee, but stuck on how to remove the old one? the hose and water supply lines are presure fitted with plastic cupplink and o-rings. Please help to wife off back!
    Problem Solver:
  • 4 Answers
    Problem Solver:
  • 4 Answers
The video is helpful, but doesn't tell you about the other 2 connections. The "spout" connection and the connection to the right (the "t" part) is simply a wiggle off. Then after those are off (with lots of water coming out - get towels ready), then you can crawl back from under the sink and get the sprayer off. The sprayer procedure is in the video (push up/in hose) then pull down gray collett. These faucets were discontinued in 2005; a plastic disconnect is now available for newer models. Also, we had to replace the cartridge and the aerator to keep it from leaking out of the handle. The problem we originally had was not having equal pressure with the faucet and the sprayer. The faucet would be running and then the pressure would go down. The sprayer would be weak when the faucet was on - never getting full pressure from the sprayer, just a trickle. It was "moody."
Posted on Nov 28, 2009
How do I disconnect a price Pfister quick connect?
There is a tool that presses on the collet at the tend of the fitting. It look like an open ended wrench.
https://www.youtube.com/watch?v=dCbXw5bP9I8
Price Pfister Quick Connect Sprayer Hose Removal - YouTube
? 1:50
Feb 1, 2014 - Uploaded by brianmcdrummer
In a few easy steps I'll explain how to remove your sprayer hose from your diverter. ... Pfister Faucets 17,981 ...
trick to removing price pfister quick connect sprayer hose - YouTube
? 0:23
https://www.youtube.com/watch?v=vTJefezIvwg Aug 14, 2012 - Uploaded by Biren Patel
This shows you how to remove the price pfister "quick connect" hose on the end of the kitchen sprayer head ...
Pfister - How To ' Remove a Sprayer Hose Connection
www.pfisterfaucets.com/support/faqs/sprayer ... Order Parts, FAQs. FAQs. Resources. Step by step instructions on how to remove a sprayer hose connection for the Price Pfister 529 Series faucet.
Pfister - How To ' Remove a Diverter Tee Connection for the 26 Series
www.pfisterfaucets.com/support/faqs/diverter ... Information · Order Parts, FAQs. FAQs. Resources. Step by step instructions on how to remove a diverter tee connection for the Price Pfister 26 Series faucet.
Pfister - Removing quick connect HELP ' Terry Love Plumbing ...
terrylove.com > Home > Forums > Plumbing Forum, Professional & DIY Advice Dec 13, 2006 - 6 posts - ‎5 authors
Purchased a replacement sprayer (with hose) for a Pfister Contempra faucet. How the heck do you remove the old hose from the handle assy? How do disconnect price Pfister quick connect Google Search
Jan 08, 2017 | Price Pfister Plumbing
Where does the hose. top-front of carb connect to ?
It probably broke off from a Tee fitting. Three hoses connect at one junction point. After it breaks off, you will only see two hoses that look like a single hose, but with a plastic connector holding them together. Also at that junction point, you will have a hole in the plastic connector, where the hose that came off the carb belongs. This broken Tee fitting creates a vacuum leak. Purchase a new Tee fitting, disconnect the old part, then install the new one.
Jun 07, 2014 | Cars & Trucks
Price Pfister hot water runs slow
Check the supply line and valve to see if any dirt or foreign.matter got into the line or valve when you changed out your faucet. if this is not the problem you may have a faulty faucet. You may be able to back flush the faucet with a garden hose by leaving the hot side open, but you will get wet. If you used Teflon tape on the supply line and it is a compression fitting, some of the tape could be blocking the water. for more info go to waterheaterflush.com
Oct 16, 2012 | Price Pfister Plumbing
The heater hose from the heater core to the engine has a tee fitting witch is crimped on to that hose. the nipple to another hose broke off causing the van to overheat. my question to you is how do you fix...
you half to buy a new hose as the presure in that line a clamp will not hold. will hold for few mins but then will blow right off as the presure builds in the engine and the temps of the fluid gets hotter
Aug 01, 2011 | Oldsmobile Silhouette Cars & Trucks
Have Kohler diverter, GP 75878 but no instructions as to how it should be installed. Is it under sink where sprayer hose is attached?
Shut off water supply Under Sink: · Unscrew brass connector for spayer hose · Disconnect single water line to faucet bysqweezing lever on connector and Gently pulloff. · Loosen two screws on faucet base washers thenunscrew the washers on thebrass faucet shaft ( NOTE: Have someone hold the fauct so it does Not accidentlyfall in sink when the support washers are removed) · Take faucet out of sink · Unscrew brass collar at base and remove · Remove Set Screw on lower body of faucet · Pull out Brass Mechanism from faucet · The Diverter is located in the Brass mechanism · Remove the Washer · Pull off the small top valve in center of theDiverter, if still there · Using a large wood screw that fits/screw intothe exposed hole In the center of The plasticdiverter, screw it in and pull out the remaing part of the old diverter · Flush out Faucet to remove any remaining debrie · Replace with new diverter and replace washer · Grease all areas that where greased when mechanismwas removed Remove & clean the faucet Airrater and replace only afterEVERYTHING has been Completed soyou can flush the faucet out again into the sink, then replace.
Dec 20, 2010 | Kohler Model 10430: Fort® Single-control...
I have a Bissell 1690 carpet cleaner and it is leaking water very quickly out the back. How can I fix this problem?
I had the same problem with my bissell proheat carpet cleaner. My cleaner would leak water out the back when i turned it on. I opened up the cleaner and found there was a broken tee connector. The tee connector was a small black plastic three way connector shaped like a letter "T" with three plastic hoses plugged in to each end. One hose had broken off from the tee, the tee connector itself had snapped. Bissell has a couple hoses that run up through the upright porsion of the cleaner, i believe if that hose gets pulled too hard by over extending the cleaner upright portion it can snap the tee connector.
I purchased a vacuum line tee connector at the local auto parts store for a buck and replaced it. The vacuum line connectors are for rubber lines on a vehicle related to the engine, but they work fine for the Bissell. The size i purchased was 3/16"x3/16"x3/16". The cleaner works great now!!!
Here is how i took it apart:
I removed the water reservour, the soap dispenser, and the cap for the air flow indicator (red spinny thingy).
I removed the two screws in the very back, the two in the middle on each side of the water resevour and the two in the front. I carefully lifted the top of the cleaner off.
Inside you have to watch for a black plunger piece that might fall out, it belongs to your (heavy traffic/light traffic/water only) turn knob. If the plunger falls out reinsert it back into the underside of the cleaner lid right next to the knob, you will see how it fits in there...hopefully. Inside the bottom portion of the cleaner you will see a few hoses. Check them all and make sure none of them are disconnected or broken off from the tee connector. I would almost bet that this is what your problem is if the machine is leaking. replace the valve, reconnect hoses and carefully reassemble the cleaner.
Hope this helps...
Jun 25, 2010 | Vacuums
Why do I have low pressure on sprayer and still have water coming out of faucet when I am spraying.
Get the replacement parts in about 10 days FREE from PP. Call 800-732-8238. The flow is the diverter tee. I had the cartridge and aerator replaced. And then I replaced the diverter tee. I ordered the parts on a Saturday; got them the following Saturday. Below is a video to remove the diverter tee. The video is helpful, but doesn't tell you about the other 2 connections. The "spout" connection and the connection to the right (the "t" part) is simply a wiggle off. Then after those are off (with lots of water coming out - get towels ready), then you can crawl back from under the sink and get the sprayer off. The sprayer procedure is in the video (push up/in hose) then pull down gray collett. These faucets were discontinued in 2005; a plastic disconnect is now available for newer models. Also, we had to replace the cartridge and the aerator to keep it from leaking out of the handle. The problem we originally had was not having equal pressure with the faucet and the sprayer. The faucet would be running and then the pressure would go down. The sprayer would be weak when the faucet was on - never getting full pressure from the sprayer, just a trickle. It was "moody."
26 Series:
Removing Diverter/Quick Connect:
Dear Customer,
Thank you for contacting Price Pfister, here is a link to a video that will guide you through the steps on how to either remove the quick connect or the diverter.
http://www.pricepfister.com/about/diverter.aspx
You can go to PP's website and see and "Exploded View" of the model you have. If in the model number it states "XX" that is the finish - for example, mine states Marielle Kitchen Faucet "26-3NXX" The "3" is the number of holes (put a 4 in its place for 4 holes). The XX is SS for Stainless steel - even though it's chrome.
Oct 29, 2009 | Price Pfister Marielle Kitchen Faucet with...
The faucet continues to run when using the side spray.
under the neck of the faucet is a small cone in the side of the body.this is your spray diverter,it may be clogged,it may be spring loaded or a presure valve you must remove and clean. then it will work right.
Jul 25, 2009 | Price Pfister Marielle Kitchen Faucet with...
New Pfister Avalon Install: Spray Hose Works, Faucet doesn't
sounds like your diverter is stuck or improperly installed ,try tapping at diverter location to free up diverter the other thing to try is remove the little device on the end of spout make sure its not clogged with debri
May 04, 2009 | Price Pfister Marielle Kitchen Faucet with...
New kitchen faucet ''jerks''
It's neither you nor an unusual problem. It's the faucet. We just installed a similar 2 handle $168 Pfister and had numerous similar and other problems. After 2 hours of expletive laden sweat, bruises, and continuous dumbfoundedness over the incredibly poor design of the cheap plastic pipe fittings and the poor english instructions, we turned it on and immediately had many problems.
1. It jerks the pipes every time you turn it on.
2. It sputters with irregular flow.
3. Pressure is 50% of our corroded 18 year old faucet.
4. When you turn it off, it drips for 10 seconds.
5. The flow out the spout is uneven and dribbles.
These problems are from its chinsy fittings and poor piping design.
1. The fittings are unstable plastic snaps held together only by pressure, O-rings, and cotter pins. No screw fittings at all. This is also dangerous since simply pulling the hoses and pipes such as when stuffing things under the sink could break the seals and cause a flood.
2. The flow diverter block that mixes the hot/cold and side feeds the separate sprayer is nothing more than a small block of plastic with very tiny holes infeeding the hot/cold lines and outfeeding the spout and sprayer. In other wrods, a 2 in, 2 out distributor.
3. The hoses that feed the hot/cold to the diverter take their feed from circular collar that seal the water with plastic-on-plastic pressure, held in place by more cotter pins. The holes in these collars that feed the hoses that lead to the diverter block in the center are also very small so they reduce pressure drastically and cause intermittent and sporatic flow.
4. Due to the very tiny holes in the diverter block, the feed collars, and the spray hose at the diverter block, any sediment or minerals in the water will soon render the faucet completely dysfunctional.
5. The design of the unit makes uninstalling very difficult. The sprayer feeder hose, for example, is made to push in without threads or pins so it has to be ripped out. The large thin ring washers with no gripping edges that hold the hot/cold faucet stems were very difficult to tighten and will be twice as hard to remove. The plain old wind nut style nylon washer-nuts used on l\more utilitarian econoical units are far superior. Shame on Pfister.
Answer: Due to all the above, the answer to your problem, unfortuntely, is the same as for us. To wit: There is no solution other than switching to another brand that doesn't place all its design effort in its looks at the expense of proper function. We feel ripped off. There is nothing uglier than a pig with lipstick.
Bottom line: These Pfister units are all show and no go. Return them if possible and choose another brand whose piping is hopefully more evolved and rugged rather than this plastic toy with only good looks.
Nov 13, 2008 | Plumbing
Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ... Logo
1,831 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
