Daewoo PD-46C10 Television
Problem for Daewoo PD-46C10 Television
TV has sound but NO PICTURE
By layingnissan on Jun 29, 2009
Solution #1
posted on Jun 29, 2009
Not Rated)
dsacco86
Rank: Guru
Rating: 94%, 909 votes
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Was this helpful?
Yes
No
Popular Solutions for Daewoo PD-46C10 Television
Questions and Unsolved Problems for Daewoo PD-46C10 Television
Do you recommend Daewoo PD-46C10 Television?
Answer
Answer
the picture has a green tint to it. Adjustments not effective
Answer
Samsung LNS4051D. Originally had red blotches replacing dark/Black areas. Now colors have gone... (More)
Answer
I have a Panasonic GAOO tv and i get sound but no picture what is the cause of that?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Daewoo PD-46C10 Television:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
